المشاركة الأصلية كتبت بواسطة MMamdouh
its a valid solution indeed but it has one big problem... once you have done that the left travel of your steering box will not be the same as your right travel
in other words if a steering system got 3.5 steering wheel turns from lock to lock then theoretically it should have 1.75 turns from center to right lock and 1.75 turns from center to left lock
now assuming that after alignment you got 0.25 of a turn deviation to the right and you fixed it by removing the steering wheel then you will end up with 1.50 turn from center to right lock and 2.00 turns from center to left lock
