Due to the fact that stability control can sometimes be incompatible with high-performance driving (i.e. when the driver intentionally loses traction as in drifting), many vehicles have an over-ride control which allows the system to be partially or fully shut off. In simpler systems, a single button may disable all features, while more complicated setups may have a multi-position switch or may never be truly turned fully off.
الاجابة ببساطة لأن لو فيه حد حابب يعمل دريفتينج بالعربية او يسوق سواقة رياضية شوية فال ESP مش هيساعده يعمل كده....فى هذه الحالة يمكن إلغاؤه للتحكم اكثر فى السيارة
تحياتى
