Regarding, Elthabaat,at a speed of 120-150 Km/hour, it is good and stable, howevere, at this speed you must drive carefully (same situation when you drive your lanos)
Regarding, El3afshaah, the Egyptian streets are very bad, apart from high-way streets, so that you must drive carefully even if you drive a military Tank.
