اقتباس:
المشاركة الأصلية كتبت بواسطة ACE
علامة عبارة عن ترس احمر
Red warning is serious (SHOULD GO TO BAVARIAN) and it’s either one of the following GEAR BOX problems:
1-Transmission overheated. After gearbox has cooled down, continue driving. If gearbox overheats
Again, have the problem checked by the nearest BMW Service.
2- Or Transmission malfunction which I reckon is the closest to your case because it affects the acceleration since the car goes on Emergency program. YOU HAVE TO CHECK WITH BMW SERVICE
