we know that a car can run with 5% of oil and 95% of water.
https://encrypted-tbn2.gstatic.com/i...ft70r4WgM6Mrpw
https://encrypted-tbn1.gstatic.com/i...o7xyHAymy3xTLl
http://overunity.com/9785/obsure-ref.../47821/image//
http://overunity.com/9785/obsure-ref.../47826/image//
الرابط
Obsure Reference YOU CAN BUILD GEET Reactor SAFE
System discovered during the 'oil crisis' of 1973, the 2 French men just saying : "You see it's not so difficult !" (means to run a car without oil ...)
already talking about an oil crisis. But at that time I missed many things to do it. Jojon was one of my customers at the car workshop; electronic is his passion. And you know, the modern mechanic is nothing without the help of electronic, like an horse without rider. We had talks, and the result is that.
…there is 2 parts in the system; one is mechanic, the other electronic The mechanic part is a 'cracking room' like a Seguin's marmite. The electronic part is where we send a High Tension, few kilovolts, at few pico-amps, at High Frequency. the concept is that water cracking occur at 2000-2300 degree, so we need to reduce this cracking temperature, like they do in the Big Reactors at very high temperature or through 4 to 5 reaction at 730 or 1050 degrees to crack the water.
… we thought like this; we can easily obtain 700 to 800 degrees. Then we must find an easy and cheap way to sustain this reaction and then crack the water. We thought about alcohol because it's easy to mix with water (soluble in water)… So we have a mix that goes in the admission pipe at 750 degrees and meet a barrier of potentials, I mean 3 elements, first a frequency in a way created by the light (!?! The translator doesn't understand), and secondly a High Frequency at High Voltage to crack the water, and third a Low Frequency that contain the reaction in a definite area.
… we know that some metals, like Nickel, or alloy like Stainless Steel based on Nickel, are catalysts to obtain a cracking at lower temperatures … commentary from the website chronicler, Rene.
… By our experiences, we know that a car can run with 5% of oil and 95% of water.
… We reject only water and carbon dioxide, that's all, and that's not much pollution… soon we could be able to run in closed loop, by using back the water coming out from the exhaust, needing only little add to compensate the energy loses, because no system is perfect.
… we spent nights, Sundays, and full holydays on this engine. Today it turns well, we are paid already !
see also: CHERCHEURS 1/3
Remark : Plasma is the very powerful 4th state of matter, and elements going trough it can transmute
http://tesla3.com/free_websites/chambrin_jojon_2.jpg
http://tesla3.com/free_websites/GEET_transmutation.jpg
http://tesla3.com/free_websites/GEET...audin_plan.gif
How to Build Your Own Water Car at Home 100% WATER ONLY
لو حد هنا مهندس كهرباء يقدر يعمل الريليه او الكتاوت ده يبقى نخلى اى عربية تمشى بالماء 100% !!!
:049:
http://www.greenoptimistic.com/images/watercar2.JPG
https://encrypted-tbn3.gstatic.com/i...xFQ-MlGFmAkL7x
In July 2005, an American mechanic released most of the details of his simple conversion system which allows an ordinary car to use water as the only fuel.
A long time has elapsed since then and it is highly probably that the inventor has been intimidated into silence since mid-August 2005. This has left the information as only a partial disclosure of this system. Some years ago, a similar system was developed by Adam Crawford of Scotland.
This vehicle was demonstrated to, and tested by, Automobile Association automotive engineers and shown on Scottish Television. Also, the scientific papers which accompany this document include several which show conclusively that explosions can occur in fog, water mist and under water, so there is no doubt at all that the principle behind the system shown below is definitely valid.
Since then, two other people have managed to get engines running briefly on this system, in spite of the lack of some important information, and it is expected that full success will follow as these excellent results are very recent. Many people have delayed, waiting to see if additional information would be given, before starting an attempted implementation of their own. A very small amount of extra information has now been given and is shown at the end of this document.
The inventor’s car, is run on a daily basis. It is a restored, eight-cylinder 1978 Chevy ‘Camaro’ with stock 350 (5.7litre) engine, no computer controls, automatic transmission, stock 4-barrel carburettor and stock fuel pump. The fuel tank has been replaced with a metal water tank with the filler cap vented to release heat and pressure. The exhaust was replaced with a new 2 inch pipe which is ducted into the water tank. The water tank has baffles inside it which also muffles the exhaust noise. The stock exhaust manifolds were used, but they will rust on the inside – custom stainless steel pipes would be best but these were not used due to their cost.
All of the stock ignition system is used and no changes have been made. A second battery was placed on the opposite side in the engine compartment. A 400 watt (800W peak) 110 volt 60Hz DC inverter was placed in the engine compartment on the passenger side and a fresh air duct located behind the grill directs air into covers placed around the inverter to keep it cool.
When the ignition switch is on, a relay turns the inverter on, the relay lead contains a 20 amp in-line fuse. This relay only turns the inverter on and off and has no other function. The inverter is connected to the battery via a positive wire and a negative wire (not the chassis). The inverter is not grounded to the car at any point and instead, is carefully insulated to ensure that accidental grounding never occurs.
The wire which would normally go to the spark plug is replaced by a wire which is taken to a box containing one pre-war mechanical twin-coil relay or vibrator per cylinder. Each of these wires drives its own dedicated ‘relay’, the current energises the relay coil but the other side of the relay coil is left unconnected. The wiring arrangement is shown in the diagrams below.
It is important that the electrical feed to each plug is fed via one wire to the plug cap and a second wire connecting to a washer clamped under the spark plug. This wiring is repeated for each of the spark plugs. To emphasise this, each spark plug should have two wires running to it, one to the cap and one to the washer clamped between the body of the spark plug and the engine block. The wiring is done with “12-2″ wire which is 2-core solid copper wire American Wire Gauge size 12 which has core diameters of 2.05 mm giving 3.31 sq. mm. per core, the nearest SWG size is 14. The under-plug washer can be made by bending the end of the solid core into a circle of appropriate size and then flattening the wire slightly.
In the relay box, the relays are positioned with a one-inch gap between them. It is important that the physical construction insures that all of the high-voltage connections are fully insulated should anyone open the relay box when the inverter is running. The batteries used are deep-cycle types with high cranking current ratings – this is important because the inverter must stay on when the engine is being started and it will cut out if the starter motor current drain pulls the battery voltage down excessively. The alternator is the stock 95 Amp type and it charges both batteries simultaneously. When the engine is started, the relays are heard clicking until the cylinders fire and after that, no sound can be heard from the relays. It is distinctly possible that the relays take up a fixed, immobile position when the engine is running. The diagram below marked ‘Effective circuit’ is based on that assumption, and it should be stressed that all of the diagrams are only what I understand from the information provided to date.
The engine timing has to be retarded for the car to run off water. This adjustment should be made to the point where the engine runs the best and this is likely to be different for each make of engine. The Chevy ‘Camaro’ engine runs best with the timing retarded by 35 . The spark plug gap used to be 65 thou. but is now set to 80 thou. (0.08″). The plugs used are the cheap ‘Autolite’ (25) copper core type. Using carburettor jets two sizes larger than normal, allows the engine to produce more power and rev higher than tick-over.
The engine tends to knock when first started from cold but it is likely that this can be overcome by using a heater on the water feed to the carburettor, raising the water temperature to say, 120 degrees Fahrenheit and fitted with a thermostat to disconnect the heater when the engine reaches its normal operating temperature. This car has been run 30,000 miles on water alone and covers some 300 miles per gallon as much of the water vapour in the exhaust condenses in the water tank.
The disadvantages: the car runs with slightly reduced power and the exhaust system will rust unless stainless steel replacements are used.
The inventor of this conversion wants to go on living a quiet life and does not want the nuisance value of high levels of interest. Consequently, he wishes to remain anonymous. He says: “I didn’t build this to sell or to get a patent on it, or make big bucks from the information. I did it because I could and I did. The only thing I can add is ‘just try it’.
Some points of note:
A car with this modification produces NO carbon dioxide and NO carbon monoxide, but since air is mixed with the gas combustion, it is likely that the greenhouse gas Nitrous Oxide is produced. But Nitrous Oxide dissolves reasonably well in water, so since the exhaust gasses are passed through the header tank which contains the water fuel, it is likely that this engine arrangement is a good deal greener than most.
http://www.greenoptimistic.com/images/watercar4.JPG
How to Build Your Own Water Car at Home 100% WATER ONLY !!
الطاقة الدائمة المجانية ما تم إخفائه عن العامة !!!!
في أواخر ثمانينيات القرن التاسع عشر كانت الصحف و المجلات المتخصصة في العلوم الكهربائية تتنبأ بظهور ما يعرف بالكهرباء الحرة Free electricityفي المستقبل القريب . ففي تلك الفترة بدأت الاكتشافات المذهلة حول طبيعة الكهرباء تصبح شائعة و مالوفة و كان نيكولا تيسلا Nikola Tesla يقوم بعرض الإضاءة اللاسلكية وعجائب أخرى مرتبطة بالتيارات العالية التوتر . لقد كان هناك حماس للمستقبل لا مثيل له من قبل . ففي غضون عشرون سنة سوف يكون هناك سيارات ، طائرات ، أفلام سينمائية ، موسيقى مسجلة ، أجهزة راديو ، كاميرات تصوير ... و غيرها من شواهد تثبت حصول نقلة علمية خاطفة لم يسبق لها مثيل في تاريخ البشرية . فالعصر الفيكتوري قد مهد الطريق لشيء جديد كليا ، إنها المرة الأولى في التاريخ التي يتم فيها تشجيع العامة على تصور مستقبل مثالي يدغدغ خيال الناس . مستقبل فيه أنظمة مواصلات متطورة بالإضافة إلى وسائل اتصالات تفوق العجب ..... وظائف للجميع ، مساكن و طعام للكل .... أما المرض فيتم السيطرة عليه تماماً ، وكذلك الفقر.
بدأت الحياة تتحسن بشكل غير مسبوق ، وهذه المرة يبدو أن الجميع سيحصل على حصته من الغنيمة . لكن .... ماذا حدث ؟.. أين ذهب ذلك التقدم المفاجئ في علوم الطاقة ؟! و ماذا عن الانفجار التكنولوجي و غنائمه الموعودة ؟!.
هل كل هذه الإثارة حول الكهرباء الحرة والتي حدثت قبل بداية القرن الماضي كانت جميعها مجرد أفكار غير واقعية ؟ عبارة عن جموح في خيال المنظرين و الباحثين الذين تنبؤا بهذا الواقع القادم من المستقبل ؟ هل هو مجرّد أمنية شعوب متلهفة تتوق للتهرّب من واقعها لكن تم دحض الحلم في آخر الأمر من قبل العلم المنهجي الرسمي الذي اثبت عدم واقعيته ، فعدنا إلى الواقع من جديد .. إلى الحالة السائدة للتكنولوجيا التي نألفها اليوم ؟.
في الحقيقة ، إن الجواب على هذا السؤال هو" لا" ، إن العكس هو الصحيح ، فقد تم تطوير تقنيات مذهلة للطاقة . تطورت جنبا إلى جنب مع التطورات التقنية الأخرى . فمنذ ذلك الوقت تم تطوير أنظمة و وسائل متعددة لإنتاج كميات ضخمة من الطاقة و بأدنى مستويات الكلفة . لكن هذه التقنيات لم تتمكن من الوصول إلى السوق الاستهلاكية المفتوحة ، سوف أقوم بإثبات صحة ذلك لاحقاً .
لكن في البداية أرغب في أن أشرح لكم قائمة صغيرة من تقنيات الطاقة الحرة والتي أنا مطلع عليها الآن و تم إثباتها فوق أي شك منطقي .
الميزة العامة التي تربط جميع هذه الاكتشافات هي أنها تستخدم كميات قليلة من الطاقة ( باشكالها المختلفة ) للتحكم أو إطلاق كميات كبيرة من أشكال أخرى من الطاقة . و بعضهم ابتكر وسيلة لاستقاء الطاقة من المجال الأثيري اللامحدود ، بطريقة ما ، هذا المصدر الغامض للطاقة تم تجاهله تماماً من قبل العلم الحديث .
1 ـ الطاقة المشعّة Radiant Energy : ( طاقة كامنة في الأثير )
مثل : جهاز نيكولا تيسلا Nicola Tesla المكبر ، أداة هنري موراي T.Henry Moray للطاقة الإشعاعية ، محرك إما EMA لصاحبه أدوين غراي Edwin Gray ، وآلة تيستاتيكا Testatika لصاحبه باول باومان Paul Baumann ، جميعها تعمل على الطاقة المنبعثة ، هذه الطاقة الطبيعية التي من الممكن تحصيلها مباشرة من الجو ( الهواء المحيط بنا ) و التي دعيت خطاء بالكهرباء الستاتيكية ( السكونية ) static electricity ، مع أن هذا غير صحيح . كما يمكن الحصول عليها باستخراجها من الكهرباء العادية بطريقة تدعى ( الفصل الجزيئي ) Fractionation .
فالطاقة المنبعثة تستطيع أن تصنع ذات العجائب التي تؤديها الكهرباء العادية ، لكن بمعدل 1% من النفقة التقليدية ! أي مجاناً !. لكن هذه الطاقة لا تسلك سلوك الكهرباء التقليدية تماما ، مما ساهم في سوء فهم المجتمع العلمي لها و لخاصياتها .
يملك مجتمع المثيرنيثاMethernitha ( دير رهباني يتبع مذهب مسيحي الخاص ) الموجود في سويسرا خمسة أو ستة نماذج فعالة من الأجهزة الذاتية العمل والتي لا تحتاج إلى الوقود بل إنها تستمد الطاقة مباشرة من الهواء ! و تغذي كامل المكان ( بكافة تجهيزاته الكهربائية ) بالطاقة الكهربائية .
2 ـ المغنطيس الدائم Permanent Magnets :
طور الدكتور روبرت آدمز D.r Robert Adams من نيوزلندا تصميمات لمحركات كهربائية و مولدات وسخانات تعمل جميعها بواسطة المغانط الدائمة . أحد هذه الأجهزة تتلقى 100 واط كهرباء من المصدر ، وتولد 100واط كهرباء لإعادة شحن المصدر . كما يستطيع إنتاج ما يفوق 140 BTU من الحرارة في خلال ثانيتين فقط !.
أما الدكتور توم بيردن Dr. Tom Bearden من الولايات المتحدة الأمريكية ، فقد امتلك نموذجين يعملان بواسطة المغانط الدائمة الحركة ، و قامت بإمداد محول كهربائية بالطاقة . هذه الجهاز يستخدم 6 واط 6-watt من الكهرباء التي يتزود بها ليؤثر على المجال المغناطيسي لقطعة مغناطيسية دائمة ، و يقوم بتوجيه الحقل المغناطيسي في داخل قنوات ، بوصلها أولا بوشيعة مخرّجة ، و من ثم إلى وشيعة مخرّجة ثانية ، وبتكرار العملية مرارا بأسلوب كرة الطاولة "Ping – Pong" ، يستطيع الجهاز أن ينتج 96 واط 96-watt من السعة الكهربائية بدون أجزاء متحركة !. يسمي بيردن Bearden جهازه هذا بمولد الطاقة الكهرومغناطيسية الساكن "Motionles Electromagnetic Generator" . قام جين لويس نودين Jean – Louis Naudin باستخراج نسخة مطابقة من جهاز MEG الذي صممه توم بيردن . و الحقيقة ان التصميم الأساسي لهذا النوع من الاجهزة يعود لفرانك ريدشردسن Frank Richardson من الولايات المتحدة الأمريكية ، و الذي ابتكره في عام 1978م .
3 ـ السخانات الميكانيكية Mechanical Heaters :
هناك نوعان من الآلات التي تحول مقدارا صغيرا من الطاقة الميكانيكية إلى كميات كبيرة من الحرارة . أحد أفضل التصميمات الميكانيكية الصرفة هو نظام الأسطوانة الدوارة rotating cylinder system المصمم من قبل فرينيت Frenette و بركنيزPerkins من الولايات المتحدة الأمريكية .
في هذه الآلة نجد إحدى الاسطوانات تدور داخل اسطوانة أخرى بوجود 8 إنشات مسافة حرة بينهما ، هذه المسافة مملؤة بسائل كالماء أو زيت ، و هذا السائل الفعال هو الذي ترتفع درجة حرارته بدوران الاسطوانة الداخلية .
و في نظام آخر يتم استخدام مغانط مركبة على عجلة لتقوم بإنتاج تيارات دائرية موجّهة على صفيحة من الألومينوم مسببة بذلك ارتفاع درجة حرارة الألمنيوم بسرعة . هذه السخانات المغنطيسية تم عرضها من قبل مولر Muller من كندا وآدمز Adams من نيوزلندا و ريد Reed من الولايات المتحدة الأمريكية . جميع هذه الأجهزة تستطيع إنتاج ما مقداره عشرة أضعاف معدل الحرارة التقليدية المنتجة من الأنظمة القياسية المستخدمة للمقدار نفسه من الطاقة .
4 ـ خلايا تحليل كهربائية شديدة الفعالية Super Efficient Electrolysis :
جميعنا نعلم بأنه يمكن تجزئة الماء إلى هدروجين وأوكسجين باستخدام الكهرباء . لكن كتب الكيمياء الرسمية تدعي بأن هذه العملية تتطلب طاقة أكثر من الطاقة الناتجة عن فصل هذين الغازين . قد يكون هذا صحيحا فقط في أسوء حالة مفترضة ، و هي الحالة ذاتها التي يوصفها لنا العلم . لكن عندما يتم صدم الماء بتردد متجانس مع ترددات جزيئاته مستخدمين نظاما تم تعديله من قبل ستان مييرز Stan Meyers من الولايات المتحدة الأمريكية والذي قام بتطويره مؤخرا كسوجن باور Xogen Power . سيتداعى بعدها الماء مباشرة ليتحول إلى غاز الهدروجين وغاز الأوكسجين !. و كل ذلك باستخدام مقدار قليل من الكهرباء !. كما أن استخدام مواد محفّزة مختلفة ( إضافات تجعل اتصال الماء بالكهرباء أفضل ) ، سوف يغير فعالية هذه العملية بشكل أفضل .
من المعروف أيضا أن اشكال هندسية محددة و أنواع من المواد و الخلائط المعدنية تساعد في تسيير هذه العملية بفعالية أكثر .
الخلاصة هي أنه يمكن توفير كميات غير محدودة من وقود الهدروجين يمكن صنعها لتقوم بتشغيل المحركات ( كالموجودة في سيارتك مثلا ) بنفس كلفة الماء ( أي بعكس ما يدعيه الجهات العلمية و الاقتصادية على السواء ) .
والأكثر عجباً من ذلك كله هو أنه تم التوصل إلى صنع سبيكة معدنية ( معدنا شائبا خاصا ) يمكنها ، و بطريقة تلقائية ، أن تقوم بتجزئة الماء إلى هدروجين وأوكسجين دون الحاجة لمزود كهربائي خارجي ودون التسبب بأي تغيرات كيمائية في المعدن نفسه . كل ما عليك فعله هو تغطيسه في الماء.
سجلت عدة براءات اختراع تتناول هذه الطريقة بالذات ، مثل براءة الاختراع التي تعود إلى فريدمان Freedman من الولايات المتحدة الأمريكية في عام 1957. و روثمان تكنولوجي ، و إيوجين أندرسون .هذا معناه إن المعدن الشائب يستطيع صنع الهدروجين من الماء مجانا وإلى الأبد .
5 ـ الانفجار الضمني / الدوامة Implosion/Vortex :
جميع الآلات الصناعية الرئيسية تستعمل الإطلاق الحراري مسببا توسعا وضغطا لإنتاج الحركة ، كما في محرك سيارتك .
إن الطبيعة تستخدم العملية العكسية . فهي تستخدم التبريد لإحداث السحب والإفراغ لإنتاج الحركة ، كما يحدث الإعصار .
كان فيكتور شوبرغر Schauderger Victor ، من النمسا ، الأول من بنى نماذج فعالة لمحركات ذات الانفجار الداخلي في ثلاثينيات وأربعينات هذا القرن . منذ ذلك الوقت قام كالوم كوست Callum Coast بنشر العديد من الدراسات حول أعمال شوبرغر المتعلقة بمبادئه العلمية الغير مألوفة ، و التي وردت في كتابه الشهير " الطاقة الحيّة " Living Energies .
و قد نجحت عدة مجموعات اختبارية حول العالم في بناء نماذج مطابقة لتصاميم شوبرغر ، و هي عبارة عن محركات توربينية ضمنية الانفجار . هذه المحركات لا تستخدم المحروقات لكنها تنتج طاقة هائلة عن طريق السحب الفراغي vacuum .
كما أنه يوجد تصاميم أكثر بساطة و تعمل على طريقة الحركات الدورانية اللولبية vortex motions فتستمدّ مزيجا من قوة الجاذبية مع القوة النابذة من المركز لإنتاج حركة مستمرة .
6 ـ الانصهار البارد Cold Fusion :
في آذار 1989 قام كيمائيان من جامعة بريغهام يونغ Brigham Young في يوتاه ، الولايات المتحدة الأمريكية ، بالإعلان بأنهم قاموا بإنتاج تفاعلات إنصهارية ذرية في أداة بسيطة موضوعة على الطاولة !. لكن هذه الادعاءات تم دحضها مباشرة ! و في غضون 6 أشهر فقد الرأي العام ( الجماهير ) الاهتمام بهذا الإنجاز ! لكن على الرغم من ذلك ، فإن الانصهار البارد حقيقي جداً !.
إن الإنتاج الزائد للحرارة ليس وحده ما تم توثيقه من خلال التجارب المتواصلة ، بل أن التحول الجزيئي للعناصر قد تمت فهرسته أيضاً ، و يتضمن العشرات من التفاعلات المختلفة !. يمكن لهذه التكنولوجيا الثورية أن تنتج طاقة منخفضة الكلفة ، بالإضافة إلى عدد هائل من الاستخدامات الاقتصادية الأخرى .
7 ـ مضخات الحرارة المدعمة بالطاقة الشمسية Solar Assisted Heat Pumps :
إن الثلاجة الموجودة في مطبخك هي الآلة الوحيدة التي تعمل بواسطة الطاقة الحرة والتي تملكها حاليا . إنها عبارة عن مضخة حرارية تعمل بواسطة الطاقة الكهرباء . إنها تستعمل كمية معينة من الطاقة (الكهرباء) لتحرك ثلاثة كميات من الطاقة ( الحرارة ) . هذا يعطيها " قمة الأداء " "CO-Efficient of Performance" بمقدار 3 .
إن ثلاجتك تستخدم مقدارا واحدا من الكهرباء لتقوم بضخ ثلاث مقادير من الحرارة من داخل الثلاجة إلى خارجها ، هذا هو استخدامها النموذجي ولكنها أسوأ طريقة ممكنة لاستخدام هذه التقنية ! و فيما يلي سنشرح السبب :
إن مهمة أي مضخة حرارية هو أنها تقوم بضخ الحرارة من "مصدر" الحرارة إلى "المساحة" أو المكان الذي يمتص الحرارة . لكن قبل السير قدماً ، وجب التعرف على حقيقة ثابتة هي : أن مصدر الحرارة يجب أن يكون "حارا" بشكل واضح أما المساحة أو مكان تفريغ الحرارة فيجب أن يكون باردا لكي تتم هذه العملية بشكل أفضل .
أما في ثلاجتك فإن الحال معكوسة تماما ، حيث أن مصدر الحرارة يكون داخل الصندوق والذي يكون باردا أما المساحة أو مكان تفريغ الحرارة فدرجة حرارته هي ليست سوى درجة حرارة الهواء الموجود في مطبخك والذي هو أكثر حرارة المصدر . لهذا السبب تكون " قمة الأداء " COP منخفضة في لثلاجة مطبخك .
لكن هذا ليس صحيحا بالنسبة لجميع مضخات الحرارة ، حيث تكون " قمة الأداء " تتراوح بين 8 و 10 ، والتي يتم إحرازها باستخدام مضخات حرارية مدعمة بالطاقة الشمسية . في جهاز كهذا ، تقوم المضخات الحرارية بسحب الحرارة من مجمع شمسي ثم يقوم بإلقاء الحرارة في حاو طويل تحت الأرض تبقى درجة حرارته مستقرة على 550 فهرنهايت ، فيتم استخراج أو استخلاص طاقة ميكانيكية في عملية التحول الحراري .
هذه العملية مشابهة تماماً للمحرك البخاري الذي يقوم باستخلاص طاقة ميكانيكية من المرحلة الانتقالية من حوض الغليان إلى المكثّف المكثف ، لكنها تختلف عن المحرّك البخاري لاستخدامها سائلا "يغلي" بدرجة حرارة أقل بكثير من درجة حرارة غليان الماء .
لقد تم اختبار نظام كهذا في سبعينيات القرن الماضي ، وقد أنتج قوة 350 حصان ، جرى قياسه بمقياس القوة الميكانيكية Dynamometer . و قد كان جهازا تم تصميمه خصيصا ليناسب جامع حرارة شمسية بمساحة 100 قدم مربع . تمكن هذا الجهاز من إنتاج طاقة أكثر بـ 17 مرة من الطاقة التي يستهلكها من أجل العمل .
يمكن لهذا النظام إمداد حي سكني بكاملة مستخدما التقنية ذاتها التي تستخدمها في البرادات التي تحافظ على الأطعمة باردة في مطبخك . هناك حاليا نظام صناعي للمضخات الحرارية في شمالي كونا North Kona في هاواي Hawaii ، والتي تولد الكهرباء من خلال الاختلافات الحرارية اجارية في مياه المحيط .
هناك عشرات من الأنظمة المختلفة التي لم أذكرها ، بعضها قابلة للتطبيق و مجرّبة بشكل جيد ، كالتي ذكرتها أعلاه . لكن هذه القائمة القصيرة كافية لإثبات وجهة نظري . جميعها تثبت حقيقة أن تقنية الطاقة الحرة موجودة .. الآن ... و يمكن لها أن تقدم لنا عالما خاليا من التلوث ووفرة في الطاقة لكل إنسان وفي أي مكان ... أصبح من الممكن الآن وقف إنتاج "الغازات الصناعية السامة " وإغلاق مفاعلات الطاقة النووية . نستطيع الآن أن نزيل الملوحة من كميات هائلة من ماء البحار ، و بتكلفة رخيصة جداً ، للحصول على كمية كافية من الماء النقية ، حتى أصبح من الممكن نقلها إلى مناطق سكنية بعيدة و نائية .
يمكن لتكاليف النقل ( المواصلات ) والإنتاج ( التصنيع ) أن تنخفض بشكل كبير جدا ! كما أن الطعام سيكون من الممكن زراعته في بيوت زجاجية تعمل على الطاقة الحرّة . فنستطيع إنماء المزروعات في أي وقت من السنة و أي مكان !.
كل هذه المنافع الرائعة التي يمكنها أن تجعل الحياة على هذه الأرض أسهل وأفضل للجميع ، لكن ... تم تأجيله منذ عقود ! و مرّت سنين طويلة من البؤس و العذاب !.. لماذا ؟ .. من هو المستفيد من هذا التأجيل ؟.. و ما هو حجم تلك الفائدة الذي يجعلها تستحق كل هذا التأجيل ؟؟.
العـدو الخـفي
هناك أربع قوى جبارة عملت معا لخلق هذا الوضع البائس . و إذا اكتفينا بالقول انه كان هناك ( ولا يزال ) مؤامرة مبيّتة لطمس هذه التقنية ، فهذا فقط يؤدي إلى فهم سطحي للعالم و الظروف الدولية الحالية ، و نظرية المؤامرة تضعنا دائماً خارج دائرة اللوم .. مع أنه إذا كان هناك مؤامرة ، فنحن المشتركين الأساسيين و اللاعبين الرئيسيين فيها .
العقبة الأولى :
القوة الأولى التي تعترض طريق انتشار تقنية الطاقة الحرة هي رغبتنا في البقاء جاهلين ! و عدم التصرف حيال هذا الظرف الذي سيسود دائماً طالما نحن نعاني من حالة "القبول الأعمى" ( أي أننا نقبل كل ما ننهله من علوم و حقائق علمية و نعتبرها مسلمات لا يمكن تجاوزها ، طالما كان مصدرها يمثل السلطة العلمية السائدة ) .
بالإضافة إلى أننا " شعوب خاملة غير مطالبة" ، فما هي القوى الثلاث الأخرى التي تعترض انتشار تقنية الطاقة الحرة ؟
في كل نظرية اقتصادية قياسية يوجد ثلاث مراتب في الصناعة و هي رأس المال ، البضائع ، و الخدمات . و ضمن المرتبة الأولى التي هي رأس المال ، يوجد هناك ثلاث مراتب أخرى هي :
1 ـ رأس المال الطبيعي : و هي مرتبطة بصنف مادي ( مثل منجم ذهب ) و مصادر طاقة ( مثل سد توليد الطاقة الكهربائية بواسطة الماء ، أو بئر نفط ) .
2 ـ العملة : و هي مرتبطة بطباعة ورق العملة و سكّ العمل النقدية . هذه الفعالية تعتبر غالباً على أنها عمل الحكومة .
3 ـ رصيد الدين : و هي مرتبطة بإدانة المال بفوائد و إمتداداتها من حيث القيمة الاقتصادية من خلال أرصدة الإيداع المقروضة .
من هنا، يسهل رؤية فعالية الطاقة و أهميتها في الاقتصاد كما أهمية الذهب أو طباعة الأوراق النقدية من قبل الحكومة أو حتى إصدارات القروض من قبل البنوك .
في الولايات المتحدة ، و معظم دول العالم ، هناك احتكارات مالية money monopoly قائمة بحد ذاتها . و عندما نقول احتكارات مالية ، هذا يعني إمبراطورات مالية ، أي أباطرة و عائلات مالكة ذات قوة و نفوذ هائل و مخيف .
فالمواطن العادي لديه حرية كسب القدر الذي يريده من المال ، لكن أحداً لن يدفع له على شكل صكّ احتياطي فدرالي . لا يوجد هناك ما يستطيع فعله كي يدفع له الأجر على شكل سبائك ذهبية أو شكل آخر من أشكال المال الحقيقي . إن هذا الاحتكار المالي وحده في يد قلة قليلة من أصحاب الأسهم المصرفية الخاصة و هذه المصارف ملك لأغنى العائلات في العالم و خطتهم تهدف في النهاية إلى السيطرة التامة على جميع رؤوس الأموال في العالم . و بالتالي السيطرة على حياة كل شخص على وجه الأرض ! ذلك من خلال رغبتنا في شراء المواد الاستهلاكية أو الخدمات التي تعرضها الشركات على الشعوب .
هناك مصدراً مستقلاً من الطاقة ، يختلف عن الطاقة المألوفة ( البترول الذي هو إحدى عوامل الثراء عند طبقة الصفوة ) ، هذا المصدر هو في متناول جميع الناس حول العالم . و يمكن لاستخدام هذه المصادر بشكل واسع و سريع أن تدمّر خطتهم المبيّتة للهيمنة على العالم .. تدمرها تماماً و بشكل نهائي !.
لماذا نعتبر هذه حقيقة ؟.. لأنه من السهل رؤية ذلك ..! فحاليا ً، إن اقتصاد أي دولة يمكن أن يتم تسريعه أو تبطيئه بواسطة رفع أو تخفيض معدلات الفائدة . لكن بوجود مصدر مستقل لرأس المال ( الطاقة الحرّة ) ، يتم بالتالي إلغاء قطاع الطاقة التقليدية التي تستخدم حالياً في الاقتصاد حيث يمثّل أحد الأعمدة الرئيسية فيه ، يمكن بالتالي زيادة رأس المال دون الحاجة لأخذ قروض مصرفية و بذلك لن يكون لهذه القروض المصرفية العالية الفوائد تأثير كبير !.
فبالتالي نستنتج من ما سبق أننا أمام معادلة مؤلفة من حقيقتين ثابتتين :
الحقيقة الأولى هي أن تقنية الطاقة الحرة يمكنها أن تغيّر قيمة المال بشكل جذري !. أما الحقيقة الثانية ، فهي أن العائلات الثرية والمتعاملون بالقروض المصرفية لا يريدون أي منافسة ، و بالتالي لا يريدون أي سبب يمكن أن يؤثر سلباً على مجرى أعمالهم المالية القذرة !... إن الأمر بهذه البساطة .
إنهم يريدون المحافظة على احتكارهم الحالي للإمدادات المالية . فإن تقنية الطاقة الحرة بالنسبة لهم هي ليست شيئا وجب طمسه فقط بل محرم بشكل أبدي .
لذلك فإن العائلات الثرية ومؤسسات البنوك المركزية هم القوة الأولى التي تعترض حق العامة في الحصول على تقنية الطاقة الحرة . و الدوافع التي تحثهم على القيام بهذا العمل هي : ادعائهم الغير مبرر بالحق المقدس للقيادة ، الجشع ، توقهم الغريزي للتحكم والسيطرة على كل شيء عدا أنفسهم .
أما الأسلحة و الوسائل التي استعانوا بها من اجل ترسيخ هذا التأجيل و استمراره ، فكانت تتراوح بين الإكراه بالتهديد ، الاستعانة بمتخصصين و رجال أكاديميين ( محترمين ) من أجل إيجاد ثغرات وزيف في هذه التقنيات المقموعة و دحضها علمياً ، شراء تقنيات مبتكرة و تصاميم و من ثم حفظها بعيدا عن العالم ، قتل ومحاولة قتل مخترعين ، اغتيال شخصيات ، إحراق المباني عمدا ومجموعة واسعة و متنوعة من الحوافز المالية تارة و بالإكراه تارة أخرى للتلاعب و التآمر على الأشخاص الذين يدعمون نظرية الطاقة الحرة و المؤسسات الممولة لهذا التوجّه ، كما أنهم صرفوا المليارات من الدولارات للترويج لنظرية علمية زائفة تقول بأن الطاقة الحرة مستحيلة من حيث قوانين الطاقة الديناموحراري ( Laws of Thermpdynamics) .
العقبة الثانية :
القوة الثانية التي تعمل على تأجيل حصول العامة على تكنولوجيا الطاقة الحرة هي الحكومات المحلية ، المشكلة هنا ليست بالمنافسة على طباعة العملة المتداولة ، بل من أجل الحفاظ على الأمن القومي . الحقيقة هي أن العالم يشبه الغابة ونستطيع أن نعتبر الإنسان بأنه الكائن الأكثر قسوة وتحايلا و الأقل أمانة . و وظيفته الحكومة أن تضمن الأمن العام . لهذا السبب فإن قوى الشرطة هي عبارة عن ذراع تابع للسلطة التنفيذية في الحكومة لدعم سلطة القانون .
معظمنا يقبل سلطة القانون لأننا تعتقد أنه هذا هو الصواب و فيه مصلحتنا ، بينما هناك بعض من الناس يعتقدون بأن مصالحهم الخاصة لا يمكن تحقيقها إلا من خلال القيام بأفعال لا يقبلها المجتمع . هذه القلة اختارت أن تعمل خارج القانون ولذا يعتبرون : خارجين عن القانون ، مجرمين ، خائنين ، مخربين ، ثائرين أو إرهابيين .
لقد اكتشفت أغلب الحكومات ، عبر التجربة الطويلة ، أن السياسة الخارجية الوحيدة الناجحة في جميع الأوقات هي " المعاملة بالمثل" أي أن تعامل الحكومات بعضها كما تعامل ، هناك سباق دائم على المركز والنفوذ في الشؤون العالمية ، والفريق الأقوى هو الذي يفوز ! أما في مجال الاقتصاد ، فالقاعدة الذهبية تقول : "من لديه الذهب يضع الشروط" . وكذلك الأمر في السياسة أيضا ، مع أن الصورة تبدو أقرب إلى الداروينية ( نسبة إلى تشارلز داروين ) إن الأمر ببساطة هو "البقاء للأنسب" ، والمناسبين في السياسة هم الأقوياء المستعدون للحرب ! حتى باقذر الوسائل و أنجسها !. كل شيء مباح !.. يمكن استعمال أي وسيلة متاحة للبقاء متفوقا على الأعداء ، والأعداء هم الآخرون سواء أكانوا أصدقاء أم خصوم ... هم المعارضون للتوجه المتبع مهما كان خاطئ أو ملتوي أو شاذ !. وهذه الوسائل تتضمن الوضعيات النفسية الشائنة ، الكذب ، التجسس ، السرقة ، اغتيال رؤساء وقادة ، حروب بالوكالة ، التحالف .. حتى مع الشيطان ، تبديل الأحلاف حسب المصلحة ، مفاوضات ، معونة أجنبية ( السلاح العصري الفتاك ) ، وتواجد قوات عسكرية في أي مكان ... وغيرها من وسائل و غايات . إن أعجبك هذا أم لا ... فهذا هو الميدان السيكولوجي والواقعي الذي تعمل فيه الحكومات في جميع أنحاء العالم .
لن تقوم أية حكومة بإعطاء خصما لها أية فائدة بدون مقابل !.. أبدا !! فإن ذلك يعتبر انتحارا ! إن أي نشاط حتى لو فردي داخل أو خارج البلد يمكن له أن يعطي فائدة أو مصلحة للخصم سوف يتم إدانته و اعتباره تهديدا للأمن القومي !... معظم الاختراعات المقموعة من قبل الحكومات يتم تبريرها على أنها تمس الأمن القومي ! و هي مختومة بختم الجنة الفاحصة التي تمثل الجيش و القوات المسلحة .
إن تقنية الطاقة الحرة تعتبر أسوأ كابوس للحكومات المحلية !. من المعروف أن تقنية الطاقة الحرة سوف تطلق سباقا في التسليح بين كل الحكومات وذلك كمحاولة أخيرة لكسب مصالح جديدة وسيطرة أكثر .. فكروا بهذا ... هل تعتقدون أن اليابان لن تشعر بالتهديد إذا حصلت الصين على الطاقة الحرة ؟ هل تعتقدون أن إسرائيل ستبقى ساكنة بينما يحصل العرب على الطاقة الحرة ؟ هل تعتقدون أن الهند ستسمح أن تقوم باكستان بتطوير الطاقة الحرة ؟ هل تعتقدون أن الولايات المتحدة لن تمنع دول العالم من الحصول عليها ؟ إن طاقة لا محدودة كهذه ، إذا توفرت حالياً بشكل فجائي في عالمنا المليء بالمشاكل و الصراعات السياسية ، سوف تؤدي إلى تغيير جذري لميزان القوى . و قد يؤدي كل هذا إلى حرب شاملة لمنع "الآخر" من الحصول على الفائدة والطاقة والثروة اللامحدودة .
سوف يريدها الجميع وفي نفس الوقت سيحاول الجميع كل على حده منع الآخرين من الحصول عليها .
حكومات الدول الغربية هي القوة الثانية العاملة على تأجيل أو تأخير حصول العامة على تكنولوجيا الطاقة الحرة وأسبابها هي:" البقاء" وهذا الصراع على البقاء يعتمد على ثلاثة مسلمات :
أولاً ـ عدم إعطاء الخصم أية فائدة دون أن تكون ضرورية أو لها مردود مجدي .
ثانيا – منع الأفعال الفردية التي قد تؤدي إلى ما يشكّل تحدي لسلطة الشرطة داخل البلد ( الطاقة الحرة تسبب فوضى عارمة ).
ثالثا – الحفاظ على الدخل من خلال الضرائب . أكبر نسبة من الضرائب تأتي من استهلاك الطاقة .
أما إحدى الوسائل الناجعة في المحافظة على الاستقرار ، فهو منع المخترعين من الحصول على براءات اختراعات ، والأسباب مبنية على الحفاظ على الأمن القومي . و أصبح من المألوف مضايقة العلماء والمخترعين باتهامهم بتهم إجرامية . أو فرض ضرائب عالية عليهم أو تهديدهم أو اعتقالهم أو إحراق منازلهم و مختبراتهم أو التجسس عليهم و التدخل في خصوصياتهم أو سرقة مخططاتهم أو إتلافها .. و غيرها من وسائل مألوفة من قبل الحكومات مما يجعل بناء أو صناعة أو تسويق آلة مولدة للطاقة الحرة مستحيلاً .
العقبة الثالثة :
العقبة الثالثة التي تعمل على منع الحصول على تقنية الطاقة الحرة هي بعض المخترعين الواهمين والمخادعين . ففي رحاب هذا المجال العلمي الرائع ( تقنية الطاقة الحرة ) المليء بالاكتشافات العلمية و التقنيات الثورية ، يختبئ عالم مظلم من شذوذ لا تفسير له واختراعات هامشية ومتعهدون و مروجون لا ضمير لهم .
لقد استعملت القوة الثانية والثالثة الإعلام لتسويق أسوأ الأمثلة ولتصرف نظر العامة ولتشوه هذا الاكتشاف بربطه بالاحتيال و النفاق .
فخلال المئة سنة الماضية ، ظهرت عشرات القصص عن اختراعات غريبة ، بعضا من هذه الاختراعات أو الأفكار قد سيطرت على خيال العامة حيث تحولت بعضها إلى أساطير حتى هذا اليوم . فأسماء مثل : كيلي Kelley، هوبارد Hubbard ، كولر Coler ، هندرسكوت Henderschott ، تأتي إلى الذهن فورا . قد تكون هناك تقنيات حقيقية وراء هذه الأسماء ولكن ليس هناك معلومات كافية لإثبات ذلك ، و لازالت صفة الاحتيال غالبة عليها .
تبقى هذه الأسماء مرتبطة بأسطورة الطاقة الحرة ، ويستعملها المتشككون و المكذبون من أجل الدحض بهذه التقنية و ربط كل اختراع جديد بصفة الاحتيال . إن فكرة الطاقة الحرة موجودة في أعماق اللاوعي البشري ، و قد بالغ بعض المخترعين المهمشين في تقدير اختراعاتهم وبالغوا أيضا في تقدير أنفسهم على ما اخترعوه . فظهر مزيج من ما سمي "حمى الذهب Gold fever" و" جنون العظمة ". يقضون على أية مساهمة مستقبلية فعالة يمكن لهم القيام بها . يمكن للأبحاث التي يجرونها أن تحمل بعض من الأمل في التوصل إلى تنيجة مجدية ، لكنهم سرعان ما يتغلب حماسهم على الحقائق العلمية ، فيشطحون بخيالهم ، و من هذه النقطة و صاعداً ، يتراجع المنطق العلمي و تسود حالة خداع النفس و من ثم خداع الآخرين .
يبدو أنه هناك قوة خفية في نفس هؤلاء ، فكرة مغرية تدغدغهم ، حيث يظن هؤلاء الأشخاص أن العالم كله ملقى على أكتافهم وأنهم سيكونون المخلصين .
هناك نوع آخر ، النوع الذي يقترب من التوصل لابتكار ثوري جديد ، أشياء غريبة تحدث لهؤلاء الأشخاص ، فيظنون أنهم على وشك الحصول على ثروة كبيرة . من الضروري جدا امتلاك ضابطا نفسيا وروحيا عاليا للبقاء واقعيا ومتواضعا أمام اختراع مهم كالطاقة الحرة ، الكثير من المخترعين يصبحون غير متزنين لمجرد تفكيرهم بأنهم حصلوا على هذا الاختراع .
و بزوال القيمة العلمية في هذه الحالات ، يظهر عند بعض المخترعين حالة نفسية تسمى "رهاب المطاردة" مما يجعلهم في موقع الدفاع دائما ، غير آمنين ، معرضين للخداع في أي لحظة أو حتى القتل ! وهذا يبعدهم عن هدفهم وهو تطوير آلة الطاقة الحرة .
وقد ظهر خلال الخمسة عشر سنة الماضية العديد من المخادعين ومنهم مخادع في الولايات المتحدة والذي حول مشروع الطاقة الحرة إلى فن في الاحتيال و جمع حوالي 100,000,000 دولار ! لكنه منع بعدها من العمل في واشنطن ثم زج في السجن ، حيث مازال هناك حتى الآن .
كان هذا الرجل يتحدث دائما عن نظام الطاقة الحرة ، وقد باع الناس على أساس أنه سيوفر لكل منهم آلة توفر الطاقة الحرة . وفي الحقيقة لم يعطيهم معلومات حقيقية عن هذه الآلة وقد استطاع خداع جمعيات دينية مسيحية بالصلاة معهم وكذلك جمعيات وطنية في الولايات المتحدة .
إذا استطعتم أن تروا معي أسباب العقبات الأولى والثانية التي شرحتها ، سترون أن ما سببه هذا الشخص الواحد من أذى لمشروع الطاقة الحرة كبير جدا حيث أنه دمر ثقة الناس بهذه التكنولوجيا .
إذا ، فالعقبة الثالثة أمام حصول العامة على الطاقة الحرة هي : فقدان الثقة ، خيبة الأمل ، وعدم الاستقامة. والأسباب هي : الطمع ، الرغبة في السيطرة ، والإحساس الخاطئ بالأهمية الشخصية . والأسلحة المستعملة : الكذب ، الخداع ، الأوهام ، العجرفة .
العقبة الرابعة:
العقبة الرابعة أمام توفر الطاقة الحرة هي نحن .! من السهل أن نرى كم هي حقيرة ووضيعة أسباب العقبات السابقة ، ولكن في الحقيقة هذه الأسباب موجودة فينا أيضا . فمثل العائلات الثرية ، ألا نملك في السر أحلاما تظهرنا متفوقين على غيرنا ؟! أما رغبتنا في السيطرة على الآخرين ، آلا نحلم بذلك أيضا ؟! ألن تبيع إذا كان الثمن مرتفعا .... لنقل مليون دولار نقدا ؟!
ومثل الحكومات ..... آلا يرغب كل منا بضمان بقاءه ؟ إذا احتجزت يوما في المسرح وهو يحترق ألن تركض خائفا دافعا الناس من حولك بجنون ، و تدوس على رؤوسهم لتصل إلى الباب ؟! أو مثل ذلك المخترع الموهوم ألن نبادل واقعا صعبا بحلم مريح ؟ آلا نعتقد أننا أفضل بكثير مما يراه الآخرون ؟ أليس صحيحاً أننا لازلنا نخاف من المجهول ، حتى لو كان يعد بالكثير ؟.
كما نرى ، فإن هذه العقبات الأربعة هي عبارة عن وجوه مختلفة لعملة واحدة ، لكنها تعمل بمستويات و مظاهر مختلفة . في الحقيقة هناك عقبة واحدة في المجتمع تمنع العامة من الحصول على تقنية الطاقة الحرة ، وهذه العقبة هي : سلوك الإنسان الحيواني الذي يفتقر إلى الروحانية و نبل الأخلاق .
إن تقنية الطاقة الحرة هي إحدى التجسيدات الروحانية للفيض الإلهي ، أنه المحرك الاقتصادي لمجتمعات متنورة ، حيث يتصرف الناس بملء إرادتهم بطريقة مهذبة مع بعضهم ، حيث كل فرد من المجتمع لديه كل ما يحتاجه ، ولا يشتهي ما لدى جاره ، في هذا المجتمع لا وجود للحرب ولا للعنف أو مشاكل الأفراد واختلافاتهم ، إن ظهور تقنية الطاقة الحرة في متناول المجتمعات هو فجر جديد للحضارات ، إنه مطلع جديد لتاريخ الإنسان .
لا أحد يستطيع أن ينسبه لنفسه ، لا أحد يصبح بفضله غني ، لا أحد يحكم العلم بواسطته ، إنه ببساطة : هدية من الله ، إنه يجعلنا نتحمل مسؤولية أفعالنا ونضبط أنفسنا ، وعالمنا كما هو الآن لا يمكن له أن يحصل على الطاقة الحرة إلا بعد إعادة ضبطه وتحويله إلى شيء آخر تماما .
إن هذه الحضارة قد وصلت إلى قمة تطورها ، لأنها تقطف ثمار البذور التي زرعتها ، إن هذا الإنسان الحيوان الفاقد للروحانية لا يؤتمن على الطاقة الحرة ، فهو سوف يفعل بها ما كان فعله دائما ، فسيحصل على ما يريد على حساب الآخرين ، وقد يقتل غيره أو نفسه في طريقه ....
أما العائلات الثرية ، فقد فهمت هذا منذ عقود ، وقد كان المخطط أن يعيشوا في عالم الطاقة الحرة ، ولكن بعد تجميد باقي الناس خارج هذا العالم . فهذا ليس جديدا . فالعائلات المالكة طالما اعتبرت باقي الرعايا "نحن" تابعون لها .. ملك لها .. فما هو الجديد ؟ الجديد هو أننا نستطيع ، أنا وأنت ، أن نتواصل بشكل أفضل من أي وقت مضى ، الإنترنت يعطين ا"القوة الرابعة" .. الفرصة لنتغلب على العقبات الأخرى التي تمنع تقنية الطاقة الحرة من الانتشار.
الفرصة:
ما يحصل الآن هو أن المخترعين ينشرون أعمالهم بدلا من التوجه للحصول على براءة اختراع حيث اللجنة العسكرية في إتظارهم مع ختم بعنوان " يمس بالأمن القومي " ، فيذهب اختراعهم إلى عالم الأسرار و من ثم إلى غياهب النسيان . وأصبح الناس يعطون أكثر وأكثر من المعلومات المتنوعة عن التقنيات السرية المقموعة سابقاً . فنراها في الكتب ، و الفيديو، والمواقع المختلفة على الإنترنت . و هناك الكثير من المعلومات حول الطاقة الحرة على الإنترنت ، فالحصول على المعلومات الجديدة يزداد بسرعة .
من الضروري أن تبدأ بجمع المعلومات التي تستطيع الحصول عليها حول الطاقة الحرة ، وسبب ذلك بسيط جدا ، هو أن القوة أو العقبة الأولى والثانية ستمنع أي مخترع أو شركة من بناء وبيع آلة الطاقة الحرة لك ، فالطريقة الوحيدة لتحصل عليها هي أن تقوم أنت أو صديق لك ببناء واحدة بنفسك ، وهذا ما يفعله الآلاف الآن بهدوء ، قد تشعر أنك غير ملائم لهذه المهمة ، ولكن أبدأ بجمع المعلومات الآن . قد تكون أنت حلقة في سلسلة من الأحداث التي ستساعد الكثيرين ، ركز فيما تستطيع فعله ، وليس فيما بقي لتفعله ، هناك مجموعات صغيرة وسرية تبحث الآن ، بينما أنت تقرأ هذا المقال ، وتعمل على جمع تفاصيل هذه التكنولوجيا المقموعة ، والعديد منهم سينشرون النتائج على الإنترنت قريباً ، و الكثير من المعلومات القيمة قد نشرت من قبل .
جميعنا نشكل القوة أو العقبة الرابعة . وإذا وقفنا جميعا ورفضنا البقاء في الجهل والكسل و الخمول ، نستطيع تغيير مسار التاريخ ، إن جمع جهودنا المشتركة سوف يصنع الفرق ، فقط الأعمال الجماعية التي تمثل الكل تستطيع أن تخلق العالم الذي تريده الجماهير وتتوق له .
القوى الثلاث الأخرى : لن تساعدنا على وضع مولد طاقة حرّة قي أقبيتنا ، لن تساعدنا في التحرر من سيطرتها . لكن في النهاية ، فإن تقنية الطاقة الحرة موجودة ، إنها حقيقية ، و تفرض نفسها بقوة كل يوم ، وسوف تغير كل شيء ، الطاقة الحرة ستغير الطريقة التي نعيش بها ، ستغيّر طريقة عملنا ، وكيف نتعامل مع بعضنا ، في الأسطر السابقة رأينا أن تقنية الطاقة الحرة تنفي الطمع والخوف و الصراع على البقاء . ولكن كجميع تمارين الإيمان الروحي يجب أن نظهر الكرم والإيمان بأنفسنا وبحياتنا أولا.
إن مصدر الطاقة الحرة يكمن في داخلنا :
إنه متعة التعبير عن أنفسنا بحرية ، إنه حدسنا الروحي لنطلق ما بداخلنا بدون خوف أو تلاعب . إنها قلوبنا المفتوحة ، إن تقنية الطاقة الحرة تؤسس مجتمعا عادلا حيث يحصل الجميع على ما يكفيه من طعام ولباس وملجأ ، وقيمة ذاتية ، والوقت اللازم ليتأمل في المعاني الروحية الهامة في الحياة . آلا ندين بهذا لبعضنا ، لنواجه مخاوفنا ونبدأ ببناء المستقبل لأولاد أولادنا ؟. ربما لست الوحيد الذي انتظر لأعمل للحصول على الحقيقة الكبرى .
تقنية الطاقة الحرة موجودة هنا . إنها هنا منذ عقود . إن تقنيات الاتصالات والإنترنت قد قضت على سرية هذه الحقيقة الرائعة . لقد بدأ الناس حول العالم ببناء آلات مختلفة خاصة بهم ، تولد الطاقة الحرة ..
لا تريد الحكومات والبنوك لهذا أن يحصل . ولكنهم لا يستطيعون منعه . ستقوم الكثير من الحروب وستحصل أزمات مادية كثيرة لتصرف نظر الناس عن المشاركة في هذه الحركة العالمية للطاقة الحرة . لن يكون هناك أي تغطية إعلامية لما يحصل ، فقط المزيد من الأخبار عن الحروب ، والحروب الأهلية ، وأخبار الأمم المتحدة راعية السلام في المزيد من البلدان .
المجتمعات الغربية تدور بشكل لولبي نحو الدمار الذاتي ، وذلك بسبب تراكم تأثيرات الطمع والفساد . إن الحصول على تقنية الطاقة الحرة لن يوقف هذا الاتجاه بل سيقويه ، وإذا أنت امتلكت آلة الطاقة الحرة ، ستكون بوضع أفضل للنجاة من المرحلة الانتقالية السياسية والاجتماعية والاقتصادية التي ستحصل . لن تنجو أي من الحكومات الحالية من هذا التحول ، السؤال هو: من سيمسك زمام الأمور في العالم الجديد الذي سيظهر : القوة الأولى أم القوة الرابعة ؟؟
الحرب الأخيرة أصبحت قريبة ، لقد زرعت البذور ، وبعد ستأتي الحضارة الحقيقية البعض منا سينجو ليشهد بزوغ فجر عالم الطاقة الحرة .
بقلم البروفيسور "بيتر لينديمان" Peter Lindemann D.Sc
الباحث في الطاقة الحرة و العلوم الأثيرية
مؤلف العديد من الكتب حول هذا المجال المحرّم علمياً و اقتصادياً
بالإضافة إلى إلقائه محاضرات كثيرة أشهرها :
" أسرار الطاقة الحرة الصادرة من الكهرباء الباردة "
The Free Energy Secrets of Cold Electricity
: اسرار الطاقة الحرة المجانية
http://2.bp.blogspot.com/_XdQUl6mgP8...9%85%D8%A7.JPG
http://www.bluegrassfuel.net/attachm...age/TF1000.jpg
http://www.bluegrassfuel.net/attachm...reen_cedes.jpg
شباب الطاقة الحرة و موقع التقنية المحترمين تحية وبعد :
يقول الله تبارك وتعالى في كتابه العزيز...{وَهُوَ الَّذِي خَلَقَ اللَّيْلَ وَالنَّهَارَ وَالشَّمْسَ وَالْقَمَرَ كُلٌّ فِي فَلَكٍ يَسْبَحُونَ }الأنبياء33 ويقول ايضاَ ...{لَا الشَّمْسُ يَنبَغِي لَهَا أَن تُدْرِكَ الْقَمَرَ وَلَا اللَّيْلُ سَابِقُ النَّهَارِ وَكُلٌّ فِي فَلَكٍ يَسْبَحُونَ }يس40
المتمعن في هذه الايات يجد ان كل شئ في هذا الكون يسبح في شئ سماه المولى تبارك وتعالى ( الفلك ) كما تفسر هذه الايات لكن هل هذا الشى هو الفراغ ؟؟!! هل يسبح الشىء في الفراغ .؟؟؟؟
العلماء اهل العلم المنهجى رفضو الى وقت قريب وجود نوع من المادة بين الكواكب والمجرات ولكن حالياً اعترفو بها وسموها ( مادة الظلام الكوني ) او (المادة السوداء ) وعدة تسميات اخرى ..
هذا دليل آخر ان ليس كل ما يقوله العلم المنهجي صحيح او كل ما يعجز عن تفسيره يعتبره خزعبلات او هرطقة علمية او حتى يعتبرها مسائل لا تستحق البحث ويسخر بعض المطبلين والمزمرين اصحاب الشهادات العلمية دون فكر علمي حقيقي للسخرية والتفسيرات التى تتوافق مع ما يدعونه العلم الحديث ..
خلية جو ...إثبات عظيم لا يقبل الشك على الطاقة الكونية (الارغون )
خلية جو خلية بسيطة تتآلف اربع او ثلاث اسطوانات من الستانلس ستيل متداخلة قطرها بالتوالى (2 + 3 + 4+5 انش ) او (3+4+5 انش ) وارتفاعها 25 سم
المختر هو شاب استرالي سمى نفسه جو إكس ولا تلومه لانه تعرض لتهديد بالقتل بسبب اختراعه
كنت املك كتاب عن الخلية بالغة الانكليزية ولكن الله وفق من قام بترجمة هذا الكتاب الى العربية وهو
( الكاتب علاء الحلبي )
صاحب سلسة الطاقة الحرة ... يشرح هذا الكتاب الطرق التفصيلية لبناء خلية جو
ويعطى فكرة عن نوع الطاقة المستمده و يشرح عن طريقة استخلاص هذه الطاقة وبعض الاراء عنها
والمعجز عنها انه يمكن تشغيل كل انواع محركات الاحتراق الداخلي على هذه الخلية و المعجز اكثر انه بعد التشغيل بفتره تفصل عن خرطوم تزويد الوقود وربطها بأحد براغي تثبيت المحرك ..؟!!!
خلية جو ... وسيلة لاستخراج طاقة كونية عظيمة
الرابط
X..خلية جـو - Download - 4shared
http://www.almohandes.org/vb/uploade...1348867017.jpg
http://www14.0zz0.com/2011/07/12/08/914029511.jpg
:049:
منقول بغرض العلاج والصحة !!! مذهل ورائع !!بروتوكول بوب بيك العلاجي
تعرفت على هذا البروتوكول قبل تقريبا ٤ سنوات حين عانيت من اورام ظهرت في ظهري واصابني حاله كسل وخمول شديدين. خسرت وزني ودخلت المستشفى وتبين ان لدي نوع من انواع السرطان.
وقتها بحثت كثيرا في الانترنت عن حالتي وارسلت تقاريري لكل مكان واجابني احد اصدقائي في المانيا واخبرني عن البروتوكول، حينها لم اسمع عنه من قبل. فارسل لي كل البحوث العلميه والمعترف بها من جامعات مرموقه ومؤسسات علميه ومستشفيات ومجلات علميه تشهد بهذا البروتوكول وتشهد بشخص اسمه روبرت بيكر أو بوب بيك حيث انه طور بحث واسلوب علاجي مؤكد معمليا انه يعالج علاج كامل مرض الايدز!!! وهذا الاسلوب اسسه دكاتره اثنان في جامعه البرت آينشتاين في ولايه نيويورك منذ سنه ١٩٩١ في الولايات المتحده اسمهما دكتوروليام ليمان ودكتور كالي وسجلا هذه الطريقه لعلاج كل اعراض مرض الايدز تحت براده اختراع رقم US Patent #5,188,738 وكان هذا في مارس ١٩٩٣...هنا فكرت في نفسي: علاج للايدز من سنه ١٩٩٣ ولم نسمع به؟! والادهى من ذلك انه يعالج كل امراض الالتهابات الفيروسيه والبكتيريه المرافقه لمظله امراض الايدز!!!! صدمت!!! اذكر يومها اني اطلت الجلوس امام شاشه كمبيوتري لأكثر من ١٣ ساعه متواصله ابحث في هذا الموضوع....
هنا قررت البحث اكثر لاشهر من المراسلات والكتب والدوريات العلميه والاتصالات وكلمت ناس شخصيا استفادو من هذا البروتوكول وانقذ حياتهم من امراض مختلفه مثل: الايدز - التهاب الكبد الوبائي النمط سي - انواع مختلفه من السرطان - الاعياء الدائم CFS وغيرها من الامراض التي " ثبت علميا " ان شفائها مستحيل....ولن اطيل وابحر بما اكتشفته من سياسات في عالم شركات الادويه المرتبطه بالربح ونشاطاتها الخاصه بالاجندات الخاصه بها. ساتكلم فقط هنا عن هذا البروتوكول العلاجي وفوائده لي شخصيا ولغيري وكيفيه تطبيقه وكيفيه الحصول عليه بارخص الطرق واكثرها فعاليه.
تكلمت ايضا عن هذا البروتوكول بالتفصيل في قناتي الخاصه في اليوتيوب على:
www.youtube.com/saudlimitless
twitter: @Saudlimitless
facebook: www.facebook.com/saudlimitless
أولا: بحث الدكتور روبرت بيكر:
كان عالم الفيزياء روبرت بوب بيك يحصد ثمار عمله الناجح كفيزيائي كهربائي وهو من اخترك فلاش الكاميرا الحديث وطور لمبته، وايضا طور افكار عديده في مجال الفيزياد الكهربائيه كتصغير مكثفات الكهرباء ونقل الجهد الكهربائي وكذلك تصغير اللوح الكهربائي وحصد شهادات وجوائز عديده في مجاله. حمل د. بوب ( تصغير كلمه روبرت ) في فكره اهتماماً بالعلاجات البديله الصحية كاهتمام جانبي، لكن عندما سمع أنه تم تثبيط الفيروسات والبكتريا والطفيليات وغيرها من العوامل الممرضة في بحث طبي في جامعه البرت آينشتاين من خلال تطبيق تيار كهربائي ضئيل على الدم، أثار هذا الخبر فضوله لأن الكهرباء هي تخصصه!
اقترح البحث الطبي للدكتورين ليمان وكالي تطبيق التيارات الضئيلة ( ٥٠ ميكرو امبير بغض النظر عن الفولت ) على الدم بداخل جسم الانسان عن طديق وضع البطاريه لتهرب دم الانسان من الداخل من خلال عمليه جراحيه باورده الانسان الاساسه المتصله بالقلب عن طريق الساعدين والرجلين، وتم تجربه ذلك على دماء مصابه بالايدز في صحون اخبارات وقوارير ايضا. قام بوب بيك بتطوير هذا النظام المكلف والمعقد بعبقريته الفيزيائيه الكهربيه بعمل نظام بسيط يسمح بتطبيق هذه التيارات على الدم دون الحاجه للجراحه ابدا وذلك بوضع سلكين على شرايين الرسغ مباشره فوق الجلد ووضع ماء على السلكين لتوصيل الكهرباء على الرسغ ومن خلال هذا التوصيل تصل الكهرباء للوريد من فوق الجلد. وبعد تجارب كافية على نفسه وأصدقائه ومعارفه وبعض المرضى حاملين للإيدز حصل الجميع على تحسن ملحوظ خلال اسابيع وتشافي كامل خلال ٣ اشهر من ممارسه ما اسماه: تنظيف الدم بالكهرباء.
لاحظ بوب أنه بينما يمكن تنظيف الدم من الاجسام الغريبه التي تسبب الامراض من فيروسات وبكتيريا وطفيليات باستخدام الكهرباء بجهد ٥٠ ميكرو امبير الى ١٠٠٠ ميكرو امبير، لكن هذه الاجسام الغريبه قد تكون مخبأه " باحواض " الجسم مؤقتاً في الاحواض المفاويه او الغدد المفاويه، كان بعض مرضى الايدز يتشافون تماما من الايدز ولكن يرجعون يصابون به بعد بضع سنين..كيف؟ بكل بساطه هذه الغدد تحتضن بعض القيروسات او الميكروبات من خلال تنقلها بالدم وتظل مختبأه هناك سنين...وبعد ذلك ممكن نشاط بسيط عالقفز او الركض او مجرد تنشيط الدوره الدمويه يلقيها ويرجعها لمجرى الدم. فتنتشر مره اخره هذا طبعا ان لم تلهب الغده المفاويه بحد ذاتها. هنا لاحظ التالي: كهربه الدم تكهرب الدم وتنظفه...ماذا عن باقي الاعضاد في الجسم؟ كالغدد اللمفاويه والكبد والامعاء والعظام؟ اثار الامر حيرته. كهربه الدم تنظف الدم وترفع مناعه الانسان. الهدف منها تنظيف الدم من الشوائب حتى يتمكن جهاز الانسان المناعي من التكفل بالباقي....لكن مرضي الايدز قد تكون لديهم ملاين الفيروسات المختفيه بهذه الاعضاء واللتي قد ترجع لمجرى الدم وتصيب الدم مره واحده وتمرضه....الحل؟
لابد واضافه جزء ثاني من العلاج: النبضات المغناطيسيه.
من خلال تطويره للفلاش في كاميرات التصوير واضائه ال LED صنع بوب مكثف مغناطيسي قوي يشحن القطب السالب " الشافي لجسد الانسان " لكنه مدمر لكل ما هو دخيل ويطلق النبضه هذه من خلال القطب نحو الغدد اللمفاويه او الاعضاء المريضه. ما يفعله هو يحرك السواذل المختزنه في هذه الاعضاء ويرجها لتسقط في مجرى الدم...بعد ذلك يكهرب المريض الدم. اكتشف ايضا من خلال ابحاثه ان الموجه المستخدمه الصحيحه والوحيده المتوافقه والقدره الشفائيه هي التالي:
٦٥٠٠ جاوس او ٠.٦٥ تسلر
تردد النبضه هو ٠.٢ هرتز
سرعه تغير الشحن ١ مل ثانيه
وزن لفه النحاس المكهرب: ٤٠٠ جرام
كما جرب هذه النبضات على على الميكروبات والفيروسات والبكتيريا الجويه في قوارير ولاحظ ان بعضها " تدمر " وبعضها مع الوقت تدمر وتنهك و " تنكسر "
وعند وضعها على الاعضاء المصابه بجسد الانسان تحرك السوائل داخلها على المستوى الدقيق Nano level لترمي بالسوائل على مجرى الدم وفي بعض الحالات والاصابات تقتل المسببات للمرض. الامر اشبه بالطائره الحربيه حينما تخترق حاجز الصوت بين المباني: الزجاج في المبنى يتكسر والمبنى لا يحدث له شيء. الفيروسات والميكروبات هي الزجاج وجسد الانسان هو المبنى.
اعتقد بوب بعد ذلك انه اكمل دراسته وبدأ بالقاء محاضراته المجانيه للعامه لكن تم محاربته من الجهات المسئوله ومن كل شركات الادويه. لكن بعض المسئولين وقفو بصفه وبعض الجهات الكبيره ( مثل الاف بي آي FBI و ال سي آي إيه CIA ووزاره الدفاع الاميريكيه البنتاجون ) بدأو باستاشرته بصفه سريه لاستعمال تكنولجيا الخاصه به لعلاج بعض عملائهم الذين يصعب الاستغناء عنهم والذين راحو ضحيه امراض مستعصيه خصوصا الايدز. فبعض عملاء الاف بي آي كانو بمهمات سريه وكانو ضحيه جنس عشوائي ومخدرات حتى لا ينكشف غطائهم. واخرنا بوب في الفيدوات الخاصه به المتوفره بالانترنت كيف استدعوه وصنعوا اجهزته بسريه كامله وعالج المرضى بمستشفيات سريه خاصه بهذه الاجهزه.
اخبروه انهم احتاجو بعض المضادات الحيويه لبعض المرضى ليستعملوه مع هذا البروتوكول الا ان بعضهم عانى منها لان المضاد الحيوي يجري مع الدم ليعالج الالتهابات وينظف ما في طريقه.
هنا فكر بالموضوع بوب بيك لأيام....وفي احد الليالي استيقظ في الساعه الرابعه صباحا بفكره: الفضه!
تاريخيا كانت الفضه تستعمل كمنظف قبل اكتشاف المضادات الحيويه لكن كان بها عيوب كثيره: ليست كماده لكن كاسلوب تصنيع. كان في الماضي اسلوب تصنيعها مكلف ومليء بالشوائب التي تسبب مرض Argrya وهو ازرقاق الجلد والعينين والاظافر وهي حاله دائمه. لكن بوب بيك بخبرته كفيزيائي كهرباء وميوليه العلاجيه اكتشف طريقه فعاله لتصنيع الفضه كمضاد حيوي خلال نومه.
من خلال تفتيت الفضه بالكهرباء ولانتاج ماده كولويد الفضه colloidal silver ووضعهما بماء مقطر خال من الاملاح ومن ثم شربها فالماء سيحتوي على جزيئات فضه تسبح بالماء المقطر ومشحونه " مأينه " وهي وسيله آمنه انا اشرب يوميا ٤ اكواب من هذا الماء منذ ٤ سنسن ولم ازرق!
شرح بوب هذه الطريقه للجهات وبحثو فيها وطبقوها وهو طبقها ايضا على البشر والحيوانات والنتيجه: الفضه عملت عمل الجهاز المناعي...وكأن الفضه جهاز مناعي ثاني داخل الجسم يدمر ويخنق كل ماهو دخيل عالجسد.
من خلال ابحاثه لاحظ بيك ان الكثير يعاني من الاعراض النسحابيه للمرض واللتي تسمى: اعراض رده فعل هيركزايمر Herxheimer Reaction وهي باختصار ان الجسم يتخلص من فضلاته من فيروسات وعناصر مؤذيه بسرعه اكثر مما يتحملها الانسان فيتعب ويصاب باعراض الحراره العاليه والقيء والاسهال والحمول والصداع الخ واحيانا يموت الانسان - سنتحدث بالتفصيل لاحقا عند استعراض كل جزء من البروتوكول كيف نتلافى هذا الامر!! هنا اضاف بيك الجزء النهائي لبروتوكوله لتلافي هذا الامر: الاوزون
عن طريق شرب الماء المشبع بالاوزون استطاع كل من يستعمل البروتوكول ان لا يقع ضحيه هذه الاعراض...لماذا؟ لان الاوزون هو منعش للدم ومؤكسد لكل ما هو دخيل لانه اوكسجين + اوزون. سأشرح بالتفصيل ذلك لاحقا. المضحك بالموضوع: نيكولا تيسلر اخترع هذا الجهاز وبراءه الاختراع مسجله باسمه منذ سنه ١٩٠٠!! فبما ان تيسلر هو ابو الكهرباء فكان بوب بيك عليم باختراعاته....فكل ما فعله انه صغر الجهاز باستعمال قطع جهاز تنشيف الشعر " السيشوار " وصنعه! كما انه قريب جدا من استعمال اجهزه تنقيه احواض السمك بالاوزون.
هنا باختصار ما هو بروتوكول بوب بيك. الان سنتكلم باذن الله بالتفاصل والصور لكل جزء من البروتوكول.
تكمله قصتي: طبقت البروتوكول...وخلال ٣ اشهر اختفت جميع الاورام واسترجعت صحتي افضل من السابق ولم امرض بعدها سوى لفحات برد موسميه لا تطول معي لاكثر من يومين :)
ثانيا: تفاصيل كل جزء من البروتوكول
أولا: كهربه الدم Blood electrification/Blood Zapping
العلاج بالتيار الكهربائي الضئيل Micro currents therapy أو كهربة الدم هو استخدام تيار لطيف جداً من الكهرباء لتنقية الدم يتراوح بقدره ٥٠ الى ١٠٠٠ ميكرو امبير بوضعه مباشره على الدم.
أن الكهرباء كانت تستخدم على نطاق واسع كوسيلة علاجية مثبتة منذ العصر الروماني. فقد ذكر في كتب الرومانيه القديمه انه اذا المعالجين لم يعرفو ما الخطب مع المريض فقد كانو يجربون ٣ اشياء: الثوم - ازاله التوتر - الكهرباء. كيف الكهرباء؟ كان بعض المعالجين يضعون المرضى بحوض فيه ماء ويضعون معه اماك الايل المكهربه Eil Fish ويضايقون السمكه بعصي الخشب فتكهرب السمكه الماء مع المريض بذات الحوض بضع مرات فيخرجون المريض ويلاحظونه...غالبا تتحسن حالته من اول مرتين....اذا ضل يعاني جربو مره ثانيه الى ان تزول الاعراض كليا فيتم الشفاء.
في هذه الايام تستخدم طريقه التكهرب في الصناعات الغذائية للقضاء على الجراثيم والكائنات الممرِضة في الغذاء والذبح ( كهربه الابقار والماشيه ) إلا أنها لا تزال طريقة علاج غير رئيسية في الطب الدارج.
لقد أثار بحث طبي لجامعة ألبرت أينشتاين الطبية في نيويورك عام 1991 فضول بوب بيك واهتمامه بالعلاج عبر التيار الكهربائي وكان هذا البحث يتضمن تطبيقات عملية لل لعلاج الدم مخبريا من فيروس الإيدز HIV وباقي الفيروسات والميكروبات. تم الإعلان عن هذا البحث لأول مرة ضمن المؤتمر العالمي الأول لدمج طرق العلاج الطبية، في ١٤ مارس عام 1991 وقد نُشر البحث أيضاً في ٣٠ مارس عام ١٩٩١ مع المزيد من الأخبار العلمية ( انظر اللينك المدمج بعد الموضوع للحصول على كل الاخبار الرسميه وصور عنها وابحاثها الاصليه ) وجد دكتور ليمان William D. Lymanوزملاؤه في جامعة البرت آينشتين نيويورك أن التعرض لتيار بين ٥٠ إلى ١٠٠ ميكروأمبير من الكهرباء (تعادل تلك التيارات المتولدة من جهاز ناظم دقات القلب) تقلل من فعالية فيروس الإيدز (HIV) من٥٠٪ وحتى ٩٥٪ وقد أظهرت تجاربهم التي قدمت في ١٤ مارس في واشنطن في أول مؤتمر عالمي عن دمج العلاجات، أن الفيروسات التي تم صعقها بالتيار الكهربائي فقدت قدرتها على صنع إنزيم أساسي لتكاثرها والتصاقها باي كريه دم او اي ماده ولم تعد تستطيع جعل الكريات البيضاء تلتصق ببعضها وتلك علامتين أساسيتين للعدوى الفيروسية. بذلك يتخلص الجسد تلقائيا من الفيروسات عن طريف الكلتين والكبد.
لقد اقترح الباحثون فوراً تطوير جهاز مولد لهذا التيار الضئيل، يستخدم على الأنسجة أو يطبق على الدم الجاري خارج الجسم او كربه الدم عن طريق وضع بطاريه بداخل الاورده الرئيسيه تكهرب الدم من الداخل وتستبدل جراحيا كلما نبضت. وقد أجريت مقابلة مع دكتور ليمان وزميله ستيفن كالي اصحاب براءه الاختراع في برنامج إذاعي كندي اسمه Quirks and Quarks في مارس ١٩٩١ حول بحثهم وبالرغم من أنهم أثبتوا قدرتهم على القيام بتنقية الدم بطريقة غير مكلفة ماديا بشكل كبير، لكن بحثهم تم إهماله وعزلو عن المجتمع وتم نقل ستيفن كالي لجامعه اخرى بعد انتشار الخبر. توجد قصه شهيره عن امرأه اتصلت على ليمان وسألته عن اختراعه لتنظيف الدم حيث ان زوجها يعاني من اعراض حرب عاصه الصحراء وانها تريد ان تخضعه لذا العلاج وانها بحثت في براءات الاختراع بعد مقابله الراديو ووجدت براءه الاختراع باسمه هو وزميله. فرد عليها قائلا: انه لا يعرف تتحدث عنه! ولا يوجد شي من هذا القبيل سوى في قصص الخيال العلمي!! براءه الاختراع رقم ٥١٨٨٧٣٨ رقم في عام ١٩٩٣الذي يسجل براءة اختراعهم هذا في أميركا المصدر الوحيد لإثبات أبحاثهم. هذا يثبت سياسه القمع الميتخدمه لشركات الادويه.
المهم، بوب بيك وجد طريقة بسيطة لتطبيق ذات العلاج على الدم دون جراحه الاورده ويمكن تطبيقها من المنزل! بالواقع ان طريقه بيك فعاله اكثر لانها لا تسد الريان فيتدفق الدم بسهوله اكثر بدون وجود البطاريه بداخله. اخترع بوب نظاما جديد: وضع الأقطاب الكهربائية التي تكهرب الدم "على" الشريانين الرئيسين في اليد او القدم فوقهم مباشرة من على الجلد. ومن الممكن للمستخدم أن يحمل الجهاز الذي صممه بيك وطوره بعده كثيرون ليصغروه اكثر بدون انقاص فائدته وهو صغير الحجم ( انظر الصوره ) يربط عالساعد ليبدو كساعه صغيره أو يوضع في الجيب بينما يكون التيار الكهربائي يعمل ويعالج وينظف الدم، حيث ينتقل التيار من القطبين إلى الجلد فالدم من خلال وضعه على مسرى الشرايين الرئيسين. بسيطه وفعاله! وغير مكلف وتشتغل على بطاريه! الن يثير هذا حقد شركات الادويه الجباره؟ لهذا قمع الا ان بوب بيك اصر على نشره من خلال محاضرات مجانيه غير معلنه تم تسجيلها وتسجيل نتائجها.
هذه الكهرباء لا تقتل الاجسام الضاره الحيه في مجرى الدم لكنها تدمر الغلاف البروتيني الذي يحيط بها فيمنعها من الاتصاق باي شي لتتكاثر...فيتعامل معها جسم الانسان تعامله مع اي شي زائد كذره الغبار مثلا فيخرجه من الجسم عن طريق: الكلى والكبد بخمس طرق: البول، البراز، التعرق، القيء ( نادرا جدا ) او المخاط.
نقاط اخري: بينما يعالج جهاز كهربه الدم الدم فقط، يمكن استعماله في اماكن اخرى كاستعمال محلي مثل: تنظيف الجيوب من التهاباتها في حال الزكام من خلال وضع الجهاز مباشره على مجرى الجيوب. ويمكن ايضا استعماله على الاورام بانواعها والتهابات المفاصل مباشره من خلال وضع قطبي الكهرباء مباشره على المفصل او الورم مع مراعاه زياده نسبه الميكرو امبير في الجهاز لحد لا يضايق المريض.
نقطه مهمه: لا يجب البدأ بتنظيف الدم بالكهرباء الا بالتدريج. فمثلا اول يومين عشرين دقيقه ثم زيادتها بالتدريج للحد الاقصى الذي هو ساعتين في اليوم لتلافي اعراض التخلص من السموم والفضلات المزعجه.
ثالثا: ملاحظات اخرى:
- اخذ الحذر في حاله استعمال البروتوكول مع منظمات القلب. استشر طبيبك.
- يمكن استعمال جهاز كهربه الدم باي وقت مع اي نشاط اذا لاحظت زوال اعراض هيركزامر التي ذكرناها سابقا. انا استعمله طوال اليوم وخلال قيادتي للسياره وفي العمل وحين اتمرن في النادي الصحي. خلال التمرن في النادي صحي من اركض والاوزان افضل وقت لان الدوره الدمويه تنشط فيكهرب الجهاز الدم بشمل اسرع.
- من استعمال كهربه الدم يمكن ان نقول ان كل قطره في دمك قد تكهربت خلا عشر دقائق.
- قال بوب بيك يجب على مستخدمي الجهاز تجنب تناول: أي شيء يحتوي أعشاب طبية من أي نوع سواء محلية أم مستوردة، الثوم البصل والكراث، والمنبهات (شاي، قهوة، متة)، الإضافات الغذائية الصناعية مثل الملح الميوّد والملونات، وكذلك أي دواء كيميائي له آثار سمية محتملة، التدخين بكل أشكاله والنيكوتين، الكحول، أدوية التجميل وكذلك ملينات الأمعاء والمنشطات وبعض الفيتامينات إلخ... وذلك لمدة أسبوع على الأقل قبل بدء العلاج وخلاله، لأن علاج الدم بالكهرباء يمكن أن يسبب "تفتح كهربائي للثقوب الخلوية" مما يجعل جدران الخلايا نفوذة لكميات قليلة من المواد المنحلة في البلاسما، وهي عادة ما تكون غير ضارة لكن هنا قد يحدث تأثير مماثل لأخذ جرعة زائدة من المواد ذاتها وهذا قد يكون مميت (Herxheimer's syndrome) وكأنك ضاعفت تركيز المواد عشرين ضعفاً. طريقة العلاج بالكهرباء والنبضات المغناطيسية كلاهما يسبب تفتح هذه الثقوب. من باب الامانه العلميه علي ان انقل هذا الامر لكن تجاربي اثبتت عكس هذا تماما!!! لم يحصل هذا الامر وانا شخصيا جربته بدون اي رد فعل. وانا امارس البروتوكول منذ اكثر من ٤ سنوات بشكل شبه يومي.
- عدم وضع الاقطاب الكهربائيه علي اي جلد مصاب.
- بعض الناس من استعمال جهاز كهربه الدم اثارت الكهرباء جلدهم ولهبته التهاب بسيط جدا في هذه الحاله استبدل اليد لليد الاخرى وضع كريب مرطب على الاولى. الافضل طبعا وضع كريم مرطب مباشره بعد عمليه كهرباء الدم.
- شرب الماء بكثره!! خلال وقبل وبعد البروتوكول في الكامل والافضل ماء الاوزون.
- في حال حدوث اي اعياء او اعراض هركزايمر اوقف البروتوكول واشرب ماء اوزون بكثره حتى زوال الاعراض وكمل البروتوكول بعد ان تتاكد من زوال الاعراض بالكامل.
- في كهربه الدم يجب اخذ كامل الحذر مع مرضى الكلى أو وظائف الكبد والبدأ يكون بتدرج في البداية لتكن 20 دقيقة في اليوم مثلاً لتقليل عوارض هركزامر.
- يمكن صنع اجهزه البروتوكول بنفسك من خلال الرابط لتنزيل ملف المخططات
والابحاث كامله وهو:
http://www.sharinghealth.com/pdfs/buildyourown.pdf
- لينك الابحاث كامله مع الصفحات والمراجع والتواريخ:
http://www.sharinghealth.com/pdfs beckprotocolhandbook.pdf
- رابط عن استعمالات العلاجات الكهربائيه على مر التاريخ من ايام الرومان:
http://www.sharinghealth.com/pdfs/el...lthbooklet.pdf
- رابط عن كيفيه استعمال البروتوكول لبوب بيك بالعربي:
- رابط عن كيفيه استعمال بروتوكول بوب بيك بالانجليزي ( جزئين ):
http://vimeo.com/22710508?ab
http://vimeo.com/22712761
روابط بيع بروتوكول بيك كاملا:
Amazon.com: Online Shopping for Electronics, Apparel, Computers, Books, DVDs & more search: bob beck protocol
SOTA Instruments and SOTA Products by SOTA Canada
NU LIFE. The Wellness Company. Germany
[url=http://www.alaalsayid.com]
ممكن كده وضوح فكرة الاهرامات الثلاثة المصرية اتبنت ليه!!؟؟؟
اقتباس:
المشاركة الأصلية كتبت بواسطة ياسر ابراهيم
مش عارف ارد علي ايه ولا ايه احنا خرجنا من الهيدروجين للطاقة الحرة
مخرجناش ولا اى شىء حضرتك محتاج تراجع مشاركاتى تانى
الابحاث الحره للطاقه البديله
البطارية الأثيرية Aetheric Battery
هيدروجين وماء برضه
جهاز ثوري لتوليد الكهرباء مجاناً
بالإعتماد على المجسّم الهرمي والطاقة الكهروحيوية للماء
لا يوجد أي قطعة متحركة... تغذيتها الكهربائية مستمرة إلى الأبد!
https://www.youtube.com/watch?v=57QUZ2-J5xc
إن ما سيرد من معلومات هي بتصرّف من كتاب البطارية الأثيرية للأستاذ "علاء الحلبي" مخترع هذا الجهاز الثوري
https://www.youtube.com/watch?v=W2tPsy0PIe4
تم تصميم هذا الجهاز بطريقة تجعله سهل البناء والتشغيل.. وخالٍ من أي تعقيد تكنولوجي.. إنه يعتمد على فكرة بسيطة جداً بحيث لا يتطلّب الأمر أي خبرة في الكهرباء لبنائه.
على ماذا اعتمدت فكرة هذا الابتكار؟
https://www.youtube.com/watch?v=-cmRvgzDvWc
هذه الفكرة لم تأتي من فراغ، بل استندت على عدة أفكار استنبطتها من عدد كبير من الأبحاث والدراسات المختلفة التي بعضها لا يمت للموضوع بأي صلة. فمثلاً، الأشكال الهندسية وكذلك معالجة الماء تخص مجال البيولوجيا (خاصة موضوع الصحة والزراعة) وليس لها أي علاقة بمجال الكهرباء وتوليد الطاقة. هذا ما كنت أظنه في البداية. وهذا ما لازال يظنه الجميع.
https://www.youtube.com/watch?v=N7VttmajtUk
فيما يلي الأفكار والدراسات التي استندت عليها لاستنباط الفكرة الأساسية من ابتكاري. حاولت جاهداً تنظيمها وترتيبها بطريقة تجعله من السهل الاطلاع عليها بالتسلسل وبأقل درجة من التعقيد:
وصف الجهاز:
هو عبارة عن منظومة مولّدة للطاقة الكهربائية يعتمد مبدأ عملها على عاملين أساسيين هما: الماء المُعالج بطريقة معيّنة والشكل الهندسي. أي أن الماء عولج بطريقة بسيطة وسهلة بحيث يتفاعل مع الطاقة التي يجسّدها الشكل الهرمي بحساسية كبيرة. تتألف هذه المنظومة من مجسّمين هرميين متناظرين، وقد تم ترتيب التوصيلات بينهما بطريقة تجعلهما يجسّدان ثنائي قطب. أي أنه عندما يحصل التفاعل بين الماء والطاقة المتجسّدة في كل من الهرمين، أحدهما يأخذ القطب الموجب من التفاعل بينما الآخر يأخذ القطب السالب.
إن طريقة عمل هذه المنظومة مشابهة تماماً لطريقة عمل البطارية العادية لكن المبدأ الآلية يختلفان. ففي حالة البطارية العادية، نحن بحاجة إلى قطبين معدنيين مختلفين للحصول على تيار كهربائي، بينما في هذه المنظومة يوجد قطبين من نفس المعدن وهو الستانلس ستيل. أي أن الشحنة الكهربائية التي نحصل عليها هنا تختلف آليتها تماماً عن آلية البطارية العادية.
صفائح الأقطاب مؤلفة من نفس المعدن، وهو الستانلس ستيل
مجرّد أن استوعبنا الآلية الحقيقية لمبدأ عمل البطارية العادية سوف نكتشف أمور كثيرة لم تكن في الحسبان أبداً. إن السبب الرئيسي وراء تجسيد شحنة كهربائية في البطارية العادية (الخلية الكهربائية) لا يعود فقط إلى فرق الكمون بين القطبين (كومة فولطا)، بل في تفاوت بمستوى الضغط المتجسّد في الخليتين. وذلك نتيجة تفاوت الجهد المتجسّد بين كل من القطبين والمحلول الكهروليتي الذي يغمره. أي أن تفاعل القطب المعدني مع المحلول الكهروليتي في إحدى الخلايا يختلف تماماً، من ناحية الشدة أو الوتيرة، عن التفاعل الحاصل بين القطب الآخر و محلول الخلية الأخرى مما يشكّل فرق في الضغط. ومجرّد أن حصل تفاوت في الكثافة أو الضغط، لا بد من أن تتجسّد شحنة كهربائية.
لازال العلم المنهجي يستند على فكرة أن التفاعل الكيماوي هو المسؤول الرئيسي عن توليد الشحنة في البطارية. لكن الحقيقة هي أن الشحنة تجري عبر النواقل كنتيجة مباشرة لتفاوت الضغط الأثيري الحاصل في الخليتين. هذا الخلل في توازن الضغط الأثيري يجعل جزيئات الماء (التي هي ثنائية قطب) تصطفّ نحو جهة واحدة مما يزيد من شدة التيار. دعونا نشرح العملية بشكل بسيط، ووفق المنظور العلمي للتركيبة الجزيئية للماء.
جميعنا نعلم أن الماء مؤلّف من ذرّتي هيدروجين وذرّة واحدة أكسيجين، ونعلم أيضاً أن الهيدروجين يشكّل القطبية الموجبة عند اندماجه مع الأكسيجين ذات القطبية السالبة،
في الحالة الطبيعية، تكون هذه الجزيئات المائية عشوائية وغير منظّمة، بعد مرور قوة محرّكة كهربائية، أو مجال مغناطيسي أو أي تأثير موجّه عبر الجسم المائي، تصطفّ جزيئات الماء بشكل يتوافق مع جهة التيار الذي يمرّ عبرها، وبالتالي تتحوّل هي أيضاً لبطارية مولّدة لتيار أيثري خاص بها
إن هذا الاصطفاف الجزيئي، والذي يتخذ شكل بطارية فولطا هو الذي يزيد من شدة التيار الكهربائي للبطارية، وليس التفاعل الكيماوي. وإن بطارية السيارة تعمل بنفس المبدأ، حيث صفائح الأقطاب يفصل بينها حاجز مسامي، فبالتالي تُقسم إلى خلايا تفاعل منفصلة مما يجسّد تفاوت في الضغط، وبالتالي يحصل اصطفاف لجزيئات الماء. وأيضاً البطاريات العادية المألوفة لدينا تعمل كذلك وفق نفس المبدأ.
هناك الكثير من المواضيع التي يمكنكم الاطلاع عليها لكي تجزموا بعدها بحقيقة أن المفعول الكهروكيماوي ليس المسؤول الرئيسي عن توليد الشحنة في البطارية. فمن أجل انطلاق التفاعل الكيماوي يتطلّب الأمر طاقة أوّلية في المنظومة بحيث تعمل كمحفّز لهذا التفاعل. فهناك إذاً عوامل كثيرة أخرى تدخل في منظومة البطارية بحيث تساهم في تجسيد الشحنة الكهربائية. والتفاعل الكيماوي لا يمثّل سوى أحد جوانب العملية وليس كلها أو جوهرها.
دور الماء في زيادة شدة التيار:
في أيام التجارب الأولى على بطارية فولطا، ظهر بوضوح أن السائل يلعب دوراً أساسياً في زيادة شدة التيار، حيث تبيّن أن البطارية الجافة التي تتألّف من أزواج من المعادن والتي تتخللها طبقات عازلة جافّة تماماً تنتج كهرباء ذات جهد عالي لكن دون أمبير، بينما البطارية الرطبة التي تتألف من أزواج معادن تتخللها طبقات مبلله بالماء تنتج جهد منخفض لكن مع أمبير عالي (أي تزداد شدة التيار).
بعد أن علمنا بأن اصطفاف جزيئات الماء هي التي تنشّط تجسيد الشحنة بين الأقطاب، إذاً، فلا بد من طريقة لجعل جزيئات الماء تقوم بهذا العمل دون حاجة لتفاعل كيماوي أو أي عملية معقّدة أخرى.
كنت أستطيع تحقيق هذه العملية (اصطفاف جزيئات الماء) من خلال تعريض الماء لذبذبات صوتية أو مجالات مغناطيسية (متحركة أو ثابتة)، أو حتى مجالات كهرومغناطيسية محددة. لكن حرصت على أن أجعل الجهاز يعمل بأكبر قدر من البساطة الممكنة. بالإضافة إلى تجريده من أي قطعة متحركة أو دارة إلكترونية أو أي تجهيزات أو أدوات تتطلّب طاقة دخل خارجية لتشغيله. باختصار أقول: وجب أن يكون جهاز بسيط خالي من الأعطال ولا يتطلّب صيانة أو غيرها من التزامات تقنية. الأمر الأهم هو أنني لست خبيراً في مجال الكهرباء أو الإلكترونيات. ولم أكن أفقه شيئاً عن المصطلحات والمفاهيم الكهربائية سوى بعد أن بدأت أترجم البحوث المتعلقة بالطاقة. لذلك اتبعت الوسائل والطرق البسيطة في معالجة الموضوع ولم ألجأ إلى أي من المنظومات الإلكترونية المعقدة التي يتبعها مخترعي أجهزة توليد الطاقة الحرة، والذين غالباً ما يكونوا مهندسين كهربائيين من الأساس.
بعد معالجة هذه المسألة ذهنياً لفترة طويلة من الزمن خرجت أخيراً بالحل المناسب. هذا الحل يمثّل أبسط الطرق وأقلها تعقيداً. صحيح أنها بدت مغامرة غير واقعية، لكن بعد تردد طويل، قررت في النهاية المباشرة في تطبيقها. الطريقة التي اتبعتها لتجسيد الاصطفاف الجزيئي للماء تعتمد على فكرتين رئيسيتين:
1ـ استخدام الشكل الهندسي بطريقة تمكنني من استثمار الفراغ الديناميكي المحيط (وفق النظرية الأيثرية). وهذا سيساعدني على الاستغناء عن استخدام أي قطعة متحركة في الجهاز (طالما أن الفراغ الديناميكي هو الذي يتحرّك).
2ـ معالجة الماء بطريقة تجعلها تتفاعل كهربائياً مع التأثير الناتج من تفاعل الشكل الهندسي مع هذا الفراغ الديناميكي المحيط. أي سوف أعالج الماء بطريقة تجعله أكثر حساسية للتأثيرات التي ستتجسّد نتيجة تفاعل العاملين المذكورين.
سوف أضع ما يكفي من معلومات مقتبسة من الكتاب بما يخدم القارئ للتعرف على الجهاز وفهم آلية عمله، أما طريقة جمع العاملين السابقين في آلية واحدة تشكّل منظومة ثنائي قطب، ومولّد لشحنة كهربائية، فسوف أشرحها بالتفصيل، لكن يمكن استنباط فكرة وجيزة عن هذه العملية من خلال النظر إلى طريقة عمل آلة "كلفن" التأثيرية The Kelvin Water Dropper التي تولّد شحنة كهربائية من تقطير الماء
الرابط
http://alpha-sci.org/showthread.php?...wfull=1#post74
http://www.alpha-sci.org/uploads/ima...7989285617.jpg
http://www.alpha-sci.org/uploads/ima...6691182777.jpg
http://www.alpha-sci.org/uploads/ima...3869817852.jpg
http://www.alpha-sci.org/uploads/ima...4175424343.jpg
بكده يبقى اهرامات مصر الثلاثة والطاقة الحرة المجانية الكونية المتولدة عبر الاثير والهيدروجين والماء جميعهم تربطهم صلة وثيقة مع بعض
