اقتباس:
المشاركة الأصلية كتبت بواسطة Mohamed_SlvrLan99
I have no problem checking my pressures weekly
Also If I had to top up/reduce pressure with nitrogen, I would have to go to some place that sells it, far more inconvenient to me
As I said earlier if it's free there's really no reason to not do it. Otherwise there's no real benefit
I JUST WANT TO MAKE A LITTLE NOTICE
THESE 20 POUNDS IS PAID FOR ONE TIME WHEN YOU FILL A NEW FULL FOUR TIRES ONLY ONCE AND FOR ALL
I THINK THIS PRICE IS NOT TOO MUCH FOR THE BENIFITS SHOWN HERE ... I KNOW IT'S TOO MUCH COMPARING THE COST THAT PAID BY THE DEALER HIM SELF BUT IT STILL COUNTS
SO LET'S COUNT IT
TWINTY POUNDS FOR THE FIRST TIME ONLY ..,
THEN ONE POUND EVERY ONE MONTH WHEN YOU CHECK THE TIRES
SO ...,
IT'S FOR SIX MONTHS = 26 POUNDS
BUT WITH THE TIRES FILLED WITH AIR YOU WOULD CHECK THE TIRES EVERY WEEK EACH TIME WITH ONE POUND
THAT MEANS IT'S COST FOR SIX MONTHS = 24 POUNDS
WHICH MEANS IN THE END THAT IT WOULD COST YOU ONLY TOW POUNDS OVER THE PRIOD (SIX MONTHS) AND MORE LESS COST ALL THE PEIOD AFTER THAT ALONG THE WAY UNTILL YOU REPLACE THE TIRES
B.S
I DIDN'T COUNT THE CASES THAT THE TIRE WOULD NEED ANY FIX TO ANY HOLE IN IT DUE TO OUR LOVELY STREETS COUSE IN THIS CASE THE COST WILL BE SIMILAR
