صباح الاختراعات ، دا انا هزهقكوا اختراعات و افتكاسات
رقم العضوية : 20666
الاقامة : اخر الدنيا
السيارة: Honda Civic
السيارة[2]: Honda Accord
اهلا شباب
الاختراع الجامد دا اللى اسمع Smart Glass اتعمل فى عربية فيرارى ، بتتحكم فى درجة غمقان الزجاج ، من 1 - 5 اليكترونياً
الفيديو هنا
شوية معلومات بقى عن الاختراع دة
Imagine a high-tech glass that you could change from transparent to frosted with the flick of a switch… You could use it for home windows (eliminating the need for blinds), for store fronts (at night), and even for bathrooms (requiring users to stretch for a new level of trust in technology). Although Privacy Glass is not in common use yet - the technology has actually been around for quite a few years, and there are many stunning examples of this smart material in use all over the world. French company Saint-Gobain produces an “intelligent” glass called Privalite, which can be switched from an ordinary-looking clear glass to a foggy-looking frosted glass by running an electrical current over a polymer liquid-crystal film sandwiched between two plates of glass.
Apparently the Koolhaus-designed Prada flagship store in SoHo, New York, utilizes privacy glass in the dressing rooms. I’ve been to the store on several occasions, but I’ve never quite made it as far as the dressing rooms (bloggers can’t afford Prada), so I have yet to see this in the flesh. Fortunately New Yorkers don’t need to be well-heeled to see Privacy Glass in action. Inhabitat reader John tells us that there is a more accessible (and fun) implementation of privacy glass, right around the corner from the Prada store, at Bar 89 (89 Mercer Street in NYC) “The bathroom doors do the trick and are tripped by an infrared censor. The bar is ok, but the bathrooms on the mezzanine are worth a stop.” {Thanks John!}
+ SwitchLite
+ Privalite
+ Landmark Glass
Privacy glass works according to the principles of polymer liquid-crystal optics. The laminated glazing comprises two sheets of glass, either clear or tinted, and a liquid crystal film. Both faces of the film are covered with a transparent, electrical conductive coating. When the glass is switched off from its special power supply, the liquid crystals are randomly scattered and diffuse light in all directions. By switching the glass on, the crystals line up and reorient themselves, turning the SGG PRIVA-LITE glass totally transparent. Switching from the non-transparent state to the transparent state is almost instantaneous and can be repeated as often as desired.
For more in-depth information on privacy glass, check out HowStuffWork’s article on Smart Windows >
According to the above article, this smart glass technology could potentially save billions of dollars on heating, cooling and lighting costs by being installed into traditional residential windows. Bring it on!
رقم العضوية : 20666
رقم العضوية : 778
الاقامة : العالم الإسلامي
السيارة: C
السيارة[2]: G
مش هو ده الإختراع الذي كان يستخدم في البداية في بعض النظارات الشمسية ؟؟
مهندس أحمد. facebook.com/AHMED1981
facebook.com/AHMED1981MECHANICAL
رقم العضوية : 20666
معنديش فكرة بس معتقدش ، لان الزجاج فى الاختراع دا لازم يكون موصل بالكهربا علشان تعرف تشوف من خلاله ، غير كدة يبقى معتم ، و معتقدش ان فى نضارة شمس لو البطارية بتاعتها خلصت متشفش خالص ينفع كدة ؟ :)
رقم العضوية : 7541
الاقامة : فيصل
السيارة: صنى
السيارة[2]: نيسان
انا سمعت ان الاخترررررررراع الجامد ده موجود فى مصر (الله اعلم)
بس لو موجود حيبىء غالى اوى بس بصراحه جامد
رقم العضوية : 2660
الاقامة : حدائق الاهرام
السيارة: :(
السيارة[2]: lanos 99
دراجة بخارية: nop
اعتقد بردوا ان الاختراع ده نوه عليه احد الاعضاء عند محل option اللي في 6 اكتوبر وقال انه جايليه بعد العيد الصغير ومن ساعتها معرفناش حاجة
[mshosh2]http://s3.postimage.org/z1xf3bakp/image.jpg[/mshosh2]
Mahmoud Fayed
رقم العضوية : 20666
معتقدش انه فى مصر بس اتمنى يكون موجود ، دا لو المتر ب 2000 جنية بردة حلال فيه
رقم العضوية : 12740
الاقامة : EL Haram
السيارة: Lanos & 308
السيارة[2]: punto
بس مبيخليش الواحد يشوف بردو وده عيب
[marq="3;right;3;scroll"](●̪•) H∂$$αற (•̪●)[/marq]
[img2]http://img687.imageshack.us/img687/6783/carcovercls.jpg[/img2]
رقم العضوية : 19431
الاقامة : TANTA & kuwait
السيارة: TOYOTA COROLLA 08
السيارة[2]: HONDA CIVIC LXI 96
بيتهالى انة بيشغل عن طريق الياف زجاجية متوصلة بالقزاز او عدسات انما القزاز يغمق كدة مع نفسة صعبة ؟؟؟
رقم العضوية : 20666
دا لازم تكون حاجة فى خامة الزجاج نفسة او حاجة ملزوقة عليه من مواد معتمة زى اللى فى الصورة اللى بتشرح طريقة تشغيله ، و لما الكهربا بتمشى فيه المواد المعتمة دى جزيئتها بتكون متوازية و تعدى الضوء فتقدر تشوف من خلاله
