بحث سريع .. الخفض لتجنب مشكله Cold start
E70, E75 https://upload.wikimedia.org/wikiped...es_Fig_4.3.jpg
When the vapor pressure in the ethanol blend drops below 45 kPa, fuel ignition cannot be guaranteed on cold winter days, limiting the maximum ethanol blend percentage during the winter months to E75.
[100]
E70 contains 70% ethanol and 30% gasoline, while E75 contains 75% ethanol. These winter blends are used in the United States and Sweden for E85
flexible-fuel vehicles during the cold weather, but still sold at the pump labeled as
E85.
[101] The seasonal reduction of the ethanol content to an E85 winter blend is mandated to avoid cold starting problems at low temperatures.
[101][102]
In the US, this seasonal reduction of the ethanol content to E70 applies only in cold regions, where temperatures fall below 32
°F (0
°C) during the winter.
[103][104] In
Wyoming for example, E70 is sold as E85 from October to May.
[101][105] In Sweden, all E85 flexible-fuel vehicles use an E75 winter blend.
[102] This blend was introduced since the winter 2006-07 and E75 is used from November until March.
[106]
For temperatures below −15
°C (5
°F), all E85 flex vehicles require an engine block heater to avoid cold starting problems.
[106] The use of this device is also recommended for gasoline vehicles when temperatures drop below −23
°C (−9
°F).
[107] Another option when extreme cold weather is expected is to add more pure gasoline in the tank, thus reducing the ethanol content below the E70 winter blend, or simply not to use E85 during extreme low temperature spells.
[106][107]
