http://www.daihatsu.com/catalogue/cu...ore1024_02.jpg
http://www.daihatsu.com/catalogue/cu...ore1024_06.jpg
http://www.daihatsu.com/catalogue/cu...ore1024_03.jpg
http://www.daihatsu.com/catalogue/cu...ore1024_07.jpg
http://www.daihatsu.com/catalogue/cu...ore1024_08.jpg
http://www.daihatsu.at/images/ansich...en/gross/4.jpg
http://galleries.media24.com/Wheels24/4799/08.jpg
http://www.daihatsu.at/images/ansich...en/gross/6.jpg
http://www.daihatsu.at/images/ansich...en/gross/5.jpg
http://img516.imageshack.us/img516/8...5000919vg5.png
http://img45.imageshack.us/img45/364...5001011rj7.png
http://www.daihatsu.co.jp/showroom/l...mg_pac_006.jpg
http://www.daihatsu.co.jp/showroom/l...mg_pac_007.jpg
http://www.daihatsu.co.jp/showroom/l...mg_pac_008.jpg
http://www.daihatsu.co.jp/showroom/l...mg_pac_010.jpg
http://www.daihatsu.co.jp/showroom/l...mg_pac_012.jpg
http://www.daihatsu.co.jp/showroom/l...mg_sft_003.jpg
http://www.daihatsu.co.jp/showroom/l...mg_sft_004.jpg
http://www.daihatsu.co.jp/showroom/l...mg_sft_005.jpg
http://www.daihatsu.co.jp/showroom/l...mg_sft_006.jpg
http://www.daihatsu.co.jp/showroom/l...mg_sft_007.jpg
http://www.daihatsu.co.jp/showroom/l...mg_sft_008.jpg
المواصفات الفنية للشاريد 2008
ENGINE
Type 1KR-FE
Bore/Stroke(mm) 71X84
Capacity (cm3) 998
Compression Ratio 10.5:1
Power KW @ RPM 51@6000
Power HP@ RPM 68.39@6000
Torque NM @RPM 94@3600
Fuel Supply EFI
Fuel Type Unleaded
TRANSMISSION
Type 5 SPEED MANUAL 4 SPEED AUTO
Ratios- 1st 3417 2.731
2nd 1.947 1.526
3rd 1.250 1.000
4th 0.865 0.696
5th 0.707
Reverse 3.143 2.290
Final drive 3.938 4.513
Drive Wheels Front
WHEELS & TYRES
Rim Type Steel
Tyre Size 145/80R13 4J
BRAKES
Front Disc brake with booster
Rear Drums leading and trailing
STEERING
Type RACK AND PINION POWER ASSIST
Turns-lock-lock 3.75
Turning Raduis(m) 8.4m
SUSPENSION
Front Macpherson struts with coil springs
Rear Semi-independent torsion axle beam with coil spring
DIMENSIONS(mm)
Length 3470
Width 1475
Height 1530
Wheelbase 2490
Track Front 1310
Track Rear 1300
Ground Clearance 160
Licensing mass 765 755 AUTO
