بتفكرنى بايام ما كنت مجند فى الجيش كنا بنترعب منها لانها كانت مخصصة لقادة اللواءات والرتب الكبيرة فى المنطقة الغربية وبالتالى جت لى عقدة حقيقية لما اشوفها ههههههههههه خصوصا لو لونها ابيض
لكن شوفت ليها على اليوتيوب مقارنات جامدة وشبه مستحيلة مع عمالقة الدفع الرباعى واثبتت كفاءة
انا بحترم العربية دى عشان امكانيتها
[youtube]http://www.youtube.com/watch?v=v_bPH1YcAPE[/youtube]
[youtube]http://www.youtube.com/watch?v=Ri05q5daGx0&feature=related[/youtube]
[youtube]http://www.youtube.com/watch?v=MDrYOcBbEtg&feature=related[/youtube]
[youtube]http://www.youtube.com/watch?v=MlpESVpC0KQ&NR=1&feature=fvwp[/youtube]
[youtube]http://www.youtube.com/watch?v=0xt2tZLbpxE&feature=related[/youtube]
Main features, safety and ecconomy
Engine size: 1688 ccm (103.00 cubic inches)
Fuel type: Gasoline
Fuel mixed driving: 5.9 litres/100 km (39.73 miles per gallon)
Seats: 4
Drive: 4WD
Transmission: Manual, 5-speed
Engine and transmission
Engine location: Front, longitudinal
Displacement: 1688 ccm (103.00 cubic inches)
Engine type: Inline, 4 cylinder
Max power: 80.00 PS (59 kW or 79 HP) at 5400 Rev. per min.
Max torque: 133.00 Nm (13.6 kgf-m or 98.1 ft.lbs) at 3200 Rev. per min.
Bore x stroke: 82.0 x 80.0 mm (3.2 x 3.1 inches)
Fuel system: Injection
Valves per cylinder: 2
Fuel control: Overhead cam (OHC)
Gearbox: Manual, 5-speed
Speed and acceleration
Top speed: 137.0 km/h (85.1 mph)
Power/weight ratio: 0.0661 PS/kg
Exterior and interior
Max no. of doors: 3
Passenger space: 3690 litres (975 gallons)
Optional cargo space: 1420 litres (375 gallons)
Steering, brakes and tires
Brake details: Optional antiblocking system (ABS).
Front tire dimensions: 175/70-R13
Rear tire dimensions: 175/70-R13
Dimensions and weight
Weight: 1210 kg (2,667.6 pounds)
Max weight with load: 1610 kg (3,549.4 pounds)
Towing weight: 1490 kg (3,284.9 pounds)
Overall length: 3730 mm (146.9 inches)
Overall width: 1690 mm (66.5 inches)
Overall height: 1650 mm (65.0 inches)
Ground clearance: 230 mm (9.1 inches)
Wheelbase: 2210 mm (87.0 inches)
Fuel capacity: 42.0 litres (11.10 gallons)
Other specifications
Country of origin: Russia
CO2 emissions: 180.0 g/km
ابتديت اشوف موديلات 2009 بتجرى على الطريق مافيش حد فى المنتدى جابها
عشان لما اقولكم اخدت 4 غرز في دماغي تقدروا هههههه....
والله العربيه فوق الممتاز بس هي مش عائليه ولا لاستخدام المدينه...
انا زميل لي جاب موديل 2009 و بيشكر فيها جامد و بيقول انها المفروض انها تكون اغلي من كدا بكتير .....
انا معايا الصراحه موديل 1993 و الحمد لله العربيه بجد يعتمد عليها....
لو حد بيفكر يشتريها توكل علي الله مفيش عربيه جيب في مستواها نهائي بالسعر دا و ترتيبها معروف وسط سيارات الدفع الرباعي و لها سمعه جيده جداً
هى الصراحة عربية توب وياسلام لو معاك فى شرم والحتت الجبلية
من يومين... شفت اعلان عن نيفا 2008 الجديدة... عاملة 8000 كيلو و صاحبها بيطلب فيها حاجة و خمسين ألف... 56-57 مش فاكر....
اتصلت بيه... لقيته بيقوللي عشان أكون أمين معاك... العربية ديه زبالة زبالة زبالة...
طيب ايه عيوبها؟
هنقلكو بالظبط الصورة زي ما سمعتها منه...
أولا كلت بيها مطبين جامدين شوية.... طقم البيض اتكسر و رحت غيرته... (من مطبين جامدين)
تاني حاجة... تكييف مالوش أي لزمة...
و كمان فيه ريحة بنزين بصفة مستمرة في الكابينة... و حتى التوكيل نفسه مقدرش يحلها...
و يا سلام بأة لو قافل الازاز و مشغل التكييف.... ريحة البنزين بتزيد جدا جدا....
دا غير أن خراطيم ووصلات التكييف مبقوش يوصلوا الهوا زي الأول بعد ما العربية دخلت في مطبات و مدقات....
فتيس الغرز متركب بطريقة غير اللي موجودة في الكتالوج اللي جاي مع العربية ...
بيقوللي جيت أجربه بحسب الكتالوج... ماشتغلش مظبوط... فسألت بتوع التوكيل قالولي احنا مركبينه باختلاف عن الكتالوج
غير طبعا المعاملة في التوكيل... أسوأ معاملة... و ناس مش فاهمين أي حاجة...
بس في الآخر... قاللي أن النيفا الروسي أحسن 100 مرة...
Content Relevant URLs by
vBSEO 3.6.0 PL2
