على فكرة انا بتكلم انجليزى كويس جدا لانى اساسا فى متخرج من مدارس انجليزى
وكمان فى هندسة
يعنى بفهم كويس فى الانجليش
بس فى اعضاء هنا مش بيردو لانهم مش فاهمين ولذلك انا مش هرد غير اما تكتب عربى
رقم العضوية : 22207
السيارة: seina
السيارة[2]: 127
i there any lubrictant for car joints
becuase vasline is not good eats rubber i am a chemist do not ever ues vasline on rubber
also wd 40 us flammabele and not good lubrictant aslo i think bad for rubber
so is there somthing like it
for lubrictant in egeypt
and also multi purpose
رقم العضوية : 25539
الاقامة : el-obour
السيارة: bmw e46 330
السيارة[2]: Mercedes c200 kompressor
وكمان فى هندسة
[rmade]http://www7.0zz0.com/2014/09/24/17/941743282.jpg[/rmade]
رقم العضوية : 2401
الاقامة : الكوكب الازرق
السيارة[2]: كيا بيكانتو 2011
على اى اساس الفازلين مضر على المطاط ممكن مصدر المعلومات
رقم العضوية : 22207
السيارة: seina
السيارة[2]: 127
first i can not write in arabic because my keyboard in notebook is english also i write in arabic very slow as all sheets in my work is in english
vasline consists of two matarials one is viscous fluid manily is oil and also a supporter which is heavy and can not move easily
so the viscous fluid is good for your rubber as it will make it a lot softer because if the rubber becomes hard it will be damaged easily and vasilne is good because i you use this viscous fluid directly which is manily vegitable oil it will collect dust and its effect will gone quickely so the supporter will increase the life time of the fliud and willnot collect dust but after the fluid is finished you will see a dark fliud which is the supporter and full of dust this kind of supporter is bad for rubber as it is manily a petrolium product which will crack it easily the grease which is called shhm in arabic is many kind and the best one is the synthetic
you can use silcon based products for rubber as it is a very healthy supporter but take care for your glass window
رقم العضوية : 2316
الاقامة : Nasr City - UAE
السيارة: Accent 2006
السيارة[2]: Megane II 2005/Megane II 2007
what parts exactly do you want to lubricate
grease is the main material used by car makers
some of the service agents also use wd40 for parts like windows machines>
use www.yamli.com/editor to write in franco arab and it will translate it into arabic
يا بلادى يا بلادى.........أنا بحبك يا بلادى
رقم العضوية : 22207
السيارة: seina
السيارة[2]: 127
rubber brushing between springs and suspeintion and all about suspention i own seina 2002
رقم العضوية : 2316
if something that has some sort of container then go with the grease
it's used in places such as inside the upper shock mounts AKA البطاحات
if something that can't contain the grease, wd40 is the only solution I know.
رقم العضوية : 2401
silcon based products like what ineed acommercial name
رقم العضوية : 2316
There's another product called
STP Silicon spray
I only get it from Emirates fuel stations
a small bottle for 20 or 22 le
رقم العضوية : 2401
wow................... thanks for your clarification
