شكلها في الصور وحش و مش متناسق
و برده واخدين مبدأ شبابيك الغواصة زي بتاع الياريس
الله أعلم ممكن في الطبيعة يبقي شكلها أحلي
رقم العضوية : 97
الاقامة : ManSOuRa
السيارة: coRoLLa 06
السيارة[2]: siRiOn 07
دراجة بخارية: ان شاء الله
كورولا2008 1400 سي سي
المواصفات الفنية :
Engine and transmission
Engine type
4ZZ-FE
Displacement (cm3)
1398
Cylinder configuration
4 in-line
Max. power (kW @ r/min)
71 @ 6000
Max. power (HP @ r/min)
95.21@ 6000
Max. torque (Nm @ r/min)
130 @ 4400
Valve mechanism
16 valve DOHC with VVT-i
Valves per cylinder
4
Bore x stroke (mm)
79.0x71.3
Compression ratio
10.5:1
Fuel supply
Electronic fuel injection (EFI)
Unleaded fuel requirement
Only
Emission control
Catalytic converter
Emission control phase
Euro Step 4
Transmission type
C50
Transmission configuration
5-speed manual
Gear ratios: 1st
3.545
Gear ratios: 2nd
1.904
Gear ratios: 3rd
1.310
Gear ratios: 4th
0.969
Gear ratios: 5th
0.815
Gear ratios: Reverse
3.250
Gear ratios: Final drive
4.529
Clutch diameter (mm)
200
Driven wheels
Front
Wheels and tyres
Wheel type
Steel
Wheel size
6JJ x 15
Tyre size
195/65R15
Spare wheel
In boot (full size)
Brakes
Front
15'' Ventilated discs
Rear
15'' Solid Disc
Anti-lock Braking System (ABS)
Standard
Electronic Brake force Distribution (EBD)
Standard
Emergency Brake Assist System (BAS)
Standard
Top speed (km/h)
170
Acceleration: 0-100km/h (s)
13.0
Acceleration: 0-400m (s)
18.6
Dimensions, capacities, weights and clearances
Length (mm)
4540
Width (mm)
1760
Height (mm)
1470
Wheelbase (mm)
2600
Front track (mm)
1535
Rear track (mm)
1535
Ground clearance, unladen (mm)
150
Seats: Adults
5
Luggage compartment (VDA, dm3, rear seats in use)
450
Load area: Length (mm)
1065
Load area: Width (mm)
1570
Load area: Height (mm)
540
Fuel tank (litre)
55
Gross vehicle mass (GVM, kg)
1735
Towing capacity (kg): Unbraked trailer
450
Towing capacity (kg): Trailer with overrun brake
1000
Angle of approach
14
Angle of departure
18
كورولا 2008 1600 سي سي
المواصفات الفنية :
Engine type
1ZR-FE
Special engine features
The popular 4ZZ-FE engine achieves the EURO IV European emmion standards while maintaining high standards of fuel economy and torque characteristics in the low speed range.
Displacement (cm3)
1598
4 in-line
91 @ 6000
122@ 6000
157 @ 5200
Valve mechanism
16 valve DOHC with Dual VVT-i
Valves per cylinder
4
Bore x stroke (mm)
80.5x78.5
Compression ratio
10.2:1
Fuel supply
Only
Emission control
Catalytic converter
Euro Step 4
Transmission type
C50
5-speed manual
Gear ratios: 1st
3.545
Gear ratios: 2nd
1.904
Gear ratios: 3rd
1.310
Gear ratios: 4th
0.969
Gear ratios: 5th
0.815
3.250
4.529
212
Driven wheels
Front
Performance (Data by Toyota Motor Corporation)
Top speed (km/h)
195
10.4
17.2
والباقي مثل الموديل الــ 1400 سي سي
عن أبي هريرة قال :
قال رسول الله صلى الله عليه وسلم :
إذا قال الرجل لأخيه :جزاك الله خيرا ، فقد أبلغ في الثناء
رقم العضوية : 794
السيارة: هيونداي فيرنا أوتوماتيك 2007
السيارة[2]: رينو فلوينس
رقم العضوية : 201
السيارة: RENAULT CLIO 1.2 2003
السيارة[2]: lancer1.6 AT2008
شكرا على الصور والمواصفات
شكلها حلو اوى
بس يا سلام بقى لو الحلو يكمل وتنزل من اليابان بدل جنوب افريقيا :?
رقم العضوية : 1122
الاقامة : egypt
السيارة: Lada , 2 Terios , 3 Cerato
السيارة[2]: COROLLA 2014
شكلها حلو جدا جدا
شبه التويوتا اوريون
رقم العضوية : 97
الاقامة : ManSOuRa
السيارة: coRoLLa 06
حضرتك لو شفت الأفينسيس هتعرف انها مبتفرقشي من جنوب افريقيا الى اليابانبس يا سلام بقى لو الحلو يكمل وتنزل من اليابان بدل جنوب افريقيا
الموضوع ليس يقاس مثل ما يحدث في بلدنا هنا من غبور او ابو الفتوح فده شئ وبناء مصانع تويوتا مثل جنوب افريقيا شئ تاني فالمصنع هو هو اللي في اليابان والادارة واحده وهيا تويوتا
عن أبي هريرة قال :
رقم العضوية : 35
السيارة: Lancer 1.6 M/T
السيارة[2]: Elantra '08 A/T
شكلها من قدام مدلدل اوى، و التابلوه شكله مش فخم، خصوصا الهوايات اللى فى النص، صغيرة و شكلها مش كويس.
رقم العضوية : 97
الاقامة : ManSOuRa
السيارة: coRoLLa 06
الرؤية في الحقيقة لها راي أخر
عن أبي هريرة قال :
رقم العضوية : 201
+1المشاركة الأصلية كتبت بواسطة أبو عبدالله
رقم العضوية : 2389
أنا بالفعل كنت أفكر في تويوتا كروللا وكنت في أنتظار الشكل الجديد ولكن السياره من الخلف شكلها قبيح جدا
ولكن إن كان سعرها معقول فسوف أتغاضى عن هذا القبح
ياريت من فضلكم الأسعار هنا في مصر لأني حاولت أجيب أسعارها المتوقعه التي سوف تنزل بها في مصر ولكن لم أفلح
وياريت صاحب الموضوع مشكورا يوضح البيانات أكثر لاننا نعرف الـ hp الحصان ولا نعرف الـkw يجب مراعاة البيانات عندالنقل
وياريت توضيح هل هذه الأمكانيات المنقوله هي ما سوف تنزل به السياره في مصر ؟ أم أقل أم أكثر ؟ وإن كنت لا اعتقد أنها من الممكن ان تنزل بامكانيات اكثر من الخارج
رقم العضوية : 143
الاقامة : Nasr City
السيارة: Toyota Yaris 2007
السيارة[2]: Nissan Juke 2013
أنا شايف إن شكلها حلو بقت كامرى صغيرة و ياريس كبيرة
ياريت يا أبو عبد الله HP بتاع العربية بالمرة
بالنسبة لسعرها أنا كنت سامع من التوكيل و انا بعمل صيانة الياريس إن مش حتقل عن 130.000 الف جم و هى حتنزل بعد منتصف نوفمبر
