حد جرب الجى ام ده ,,,,,,
انا عاوز اعرف ايه رايكم فيه وده اللينك بتاعه ومواصفاته :
http://mobile.jensen.com/jensen/JensenProductDetail.do?
ACTION_TYPE_ID=ACTION_TYPE_PRODUCT_DETAIL&ACTION_C ATEGORY_ID=STR_CATEGORY_AMPLIFIER&ACTION_PRODUCT_I D=JPA460
Power Output
: 60 watts RMS X 4 channels into 4-ohms @ <
1% THD+N
Frequency Response
: 10Hz to 100Hz (-3dB)
Signal to Noise Ratio
: 100dBA below reference (Reference:
1 watt, 4-ohms)
Additional Power Output
: 90 watts RMS X 4 channels into
2-ohms @ < 1% THD+N; 180 watts RMS X 2 channels
(bridged stereo) into 4-ohms @ < 1% THD+N
Dynamic Power
: 600 watts x 2 (bridged stereo) into 4-ohms
@ < 1%THD+N
Dimensions
: 280mm X 65mm X 365mm
General Specifications
Input Sensitivity
: 300mV to 8V for full power output at
clipping (1% THD+N)
Bass Boost
: 0 to +18dB @ 45Hz, continuously variable
Crossover
: 12dB/octave, Butterworth alignment; 45Hz to
250Hz, continuously variable
Reference Supply Voltage for Rated Power:
14.4VDC (+/-
0.2V)
Power Supply
: 14.4VDC, (11 to 16VDC allowable), negative
ground
