بالوصفة دى يبقى دة عادل وجدى... الراجل دة مركب فرامل فى اللانسر بتاعتة ب 7000 جنية... بس هو فعلا محتاج حاجة زى كدة لان عربيتة فيها موتور MIVEC 1800 و 50HP shot of NOS يعنى عربية 225 حصان
ما شاء الله
ما شاء الله
Little correction Mamdouh
Adel's car is MIVEC 1600 cc not 1800 cc and the last update that the car is almost 280-300 HP theoritcally according to the list of tuning parts on .
Finally the brakes kit cost was 9000 L.E
Thanks
Eng.Sherif Shaker
دة اية التعديلات دي اللي ترفع من قوة الموتور للدرجة دي (باستثناء النوس)؟اقتباس:
اقتباس:
Ultra light weight racing fly wheel
Ultra light weight cranck pully
and i think also Ultra light weight Cam Pully
exeedy racing cluch
stainless steel Exhaust (sport) with catback
grounding kit
cold air induction kit with path from the front bumber
racing wiring and spark plugs
and i think he just add voltage stablizer and ECU(i'm not sure about that)
when i remember the rest i'll tell you I S Allah
Thanks
Eng.Sherif Shaker
ايه ال catback دهاقتباس:
المشاركة الأصلية كتبت بواسطة SAbuhashem
His car is 1.6 and 175hp with 50Nos, so there no way his car is 280-300hp and all the bolt on that he has is like 10hp or even less and btw any Honda with 1.8L will beat him hard :)with out the NOS
Best thing is to try performance pad on the stock rotors as I have done it before and the results are very good.
i still beleive that bigger braking kit is the ultimate upgrade... i got proof on that ;)
+1اقتباس:
المشاركة الأصلية كتبت بواسطة MMamdouh
Bigger rotors + performance racing pads = higher brake perfprmance
the Exhaust & The header gives 10% from the power which around 20HPاقتباس:
المشاركة الأصلية كتبت بواسطة kimoboy
the complete cold air kit gived from 5-7% which around 10 HP
The ECU if tuned well with a good fuel pump and NOS and racing spark plugs will give 25-30 HP (+50 from NOS)
the light performance kit with calculations will give 15-20 hp
did you see the MIVEC lancer racing Honda (stocks) before ??
i did
no i raced hondas and i killed them :)
Thanks
Eng.Sherif Shaker
