did you measure the resistance
nope
i thought of that but the 4 wires got different lengths so i will get different readings anyways
also if a wire or more has a problem (high resistance) i would have felt some power loss or hesitation... the car just performs at the same level it did with the OEM wire set
اللغة.....ياريت لو مع الترجمة اكون مع الشكر
