النتائج 1 إلى 10 من 13
    الصورة الرمزية MMamdouh
    رقم العضوية : 102
    السيارة: Daewoo Lanos I 1999
    دراجة بخارية: N/A
    افتراضي SplitFire spark plug cables for my Lanos - Facebook Twitter whatsapp انشر الموضوع فى :
    i got a gift - again - from Ehab Bob and it was a set of Splitfire twin core 8.0mm spark plug cables
    it was one of them sets that you have to cut to your specific lengthens and install the sockets and all so i got a couple of old OEM wire sets and stripped out the rubber caps and the ....l sockets to use them on the SF cables
    i got the lengths off the OEM set and installed the rubber caps... it was a hell of a job as the SF cables are thicker so i used oil to lubricate the cables and let the caps slide... i had to use a hot ....l rod to enlarge the hole in the spark plug cap... that was the most exhausting part
    after that i installed the ....l sockets... the one at the coil pack was tricky as their is a plastic cylinder were the cable has to go in and the SF is thicker than the OEM... i actually used a flat end screw driver and a hammer to force the damn thing in
    last part of the customization was to adjust the position of the ....l socket at the spark plug size, it was an easy job to compare to one of the OEM cable sets... after that i cleaned all the ....l terminals with carb cleaner to get rid of all the oil residue
    the installation was super easy... and as far as looks... it is as good as a cable set made for the Lanos and this is what i like the most
    now for the test drive... no change whatsoever
    it seems that them cables are just like the BOSCH super 4 spark plugs and all... the real benefit is the durability and lack of maintenance rather than performance, i was not that much disappointed as it is a gift... but paying 340LE (62USD) for this set with expectations of power gains will be frustrating indeed
    الصورة الرمزية kimoboy
    رقم العضوية : 1303
    السيارة: Hyunai i10
    السيارة[2]: BMW 325i E46
    الحالة : kimoboy غير متواجد حالياً
    I thought so that it will not give performance, if you need gain then you need to install MSD
    Horsepower is how fast you hit the wall....torque is how far you take the wall with you
    رقم العضوية : 102
    دراجة بخارية: N/A
    i don't think this will add power either as long as you are running a N/A engine
    the need for high voltage for the spark is due to the air/fuel pressure in the combustion chamber so as long as the pressure is the same then stronger spark will do you no good
    if you got forced induction then you are building up pressure in the combustion chamber and that will require a stronger spark
    i am not 100% sure of that... it is just my logical thinking regarding the subject
    رقم العضوية : 1303
    السيارة: Hyunai i10
    I had MSD in my old Honda, and did find some gain high end, the MSD was in it when I bought the car, as for me I don't think it's worth buying it.
    اقتباس المشاركة الأصلية كتبت بواسطة MMamdouh مشاهدة المشاركة
    الصورة الرمزية Ghamrawy
    رقم العضوية : 4385
    الاقامة : Alexandria
    السيارة: grande punto T-jet
    السيارة[2]: خلاص بخ
    دراجة بخارية: nope
    الحالة : Ghamrawy غير متواجد حالياً
    mabrouk ya pasha
    but how come the master of forced induction engines is riding N/A ride ?
    الصورة الرمزية MohaMed_Refaat
    رقم العضوية : 19431
    الاقامة : TANTA & kuwait
    السيارة: TOYOTA COROLLA 08
    السيارة[2]: HONDA CIVIC LXI 96
    الحالة : MohaMed_Refaat غير متواجد حالياً
    congratulation
    استغفر الله عدد خلقة وزنة عرشة ومداد كلماتة ورضاء نفسة
    رقم العضوية : 102
    دراجة بخارية: N/A
    اقتباس المشاركة الأصلية كتبت بواسطة gemino مشاهدة المشاركة
    mabrouk ya pasha
    1- current ride is my only ride... and i can't afford to park the car for a week or so during the installation
    2- reliability is top priority since i am a family man now.. can't afford any glitches
    رقم العضوية : 4385
    السيارة[2]: خلاص بخ
    دراجة بخارية: nope
    you are right ,parking the car for even a day is not a good thing
    hope one day you get a plus to tune and enjoy
    رقم العضوية : 102
    دراجة بخارية: N/A
    thanks my man
    الصورة الرمزية Hegazio
    رقم العضوية : 39787
    الاقامة : 6 أكتوبر
    السيارة: Eclipse-Fluence -Corolla
    السيارة[2]: Civic.felecia.megan.tigo
    الحالة : Hegazio غير متواجد حالياً
    great job .. while as you said .. it's durability rather than performance, unless your old cables got bad, which a new OEM wolud fix
    To Get The Best In Life
    You Have To Start With Yourself
    And Do Your .. BEST
  1. تركيب NGK Laser Iridium Spark Plug للفلوينس
    بواسطة tarek7elmy في المنتدى ريــــنو
    آخر مشاركة: 04-11-2012, 03:26 PM
  2. تركيب NGK Laser Iridium Spark Plug
    بواسطة tarek7elmy في المنتدى تعـــديل الســـيارات و الإضافات
    آخر مشاركة: 02-11-2012, 12:32 PM
  3. spark plug ???
    بواسطة alfateh87 في المنتدى ورشـــة نــايل مــــوتـــورز
    آخر مشاركة: 22-05-2012, 04:58 PM
  4. 7ad seme3 3an el spark plug(bougie) esmo platinum men sherket bosh
    بواسطة smileee في المنتدى ســـيات
    مشاركات: 7
    آخر مشاركة: 05-08-2008, 05:41 AM
  5. what does a spark plug say about the engine?
    بواسطة MMamdouh في المنتدى ورشـــة نــايل مــــوتـــورز
    آخر مشاركة: 21-01-2008, 08:02 PM
