ربنا يزيدك من علمه يا هندسة
الله يخليك يا أبو حميد
ونورت الموضوع
مفيش علاقه بين طول سن القلاووظ ونوع الشمعه أو البوجيه
السن فقط بدون شك لما بيكون فيه أطوال مختلفه بيعتمد على تصميم السن النتايه اللى حيركب عليها كقلاووظ فى وش السلندر
_ أما نوع الشمعه كأنف طويل (ساخن ) أو أنف قصير ( بارد )
بيكون من ضمن التصميم الداخلى للشمعه ومستخبى للداخل ( زى ما أنت شايف على الرسم )
باين أمامك على الصوره بتاعة الأنواع التلاته
اقتباس:
what is a spark plug? What does it do?
unlike some people think, the spark plug does not "make" a spark. It does offer the gap necessary for the electric current produced by the coil jumps as a spark. This spark starts the ignition of the air/gas mixture compressed at the top of the piston, running the engine.
a spark plug has dimensions and features that should be taken in account when time arrives for a replacement, to prevent damage to the engine.
a. Thread diameter: Diameter of the plug's threaded part, the one which goes into the cylinder;
b. Thread reach: Length of the threaded part;
c. Heat range: The velocity which the plug is able to get rid of excess heat.
let's talk a little about each one of those features:
diameter: The engines used in r/c boating use spark plugs with 14 mm thread. This is the feature that causes no worry, because of the obvious reason that you can not put a 14 mm plug on a 12 mm cylinder or v.v.
thread reach: The spark plug with adequate reach doesn't leave any portion of the thread exposed into the cylinder, and on the other hand doesn't leave any portion of the cylinder thread not covered. A short plug allows carbon deposits on the unprotected thread, demanding a careful cleaning before installing a new plug. A long plug, however, leaves a portion of the thread exposed into the combustion chamber. On the exposed portion carbon deposits are formed, that may make it difficult to take the plug off and even damage the cylinder thread. Besides, a plug that is too long may touch the head of the piston on it's upper stroke, with disastrous consequences to the engine. As another detrimental effect, the plug with wrong length doesn't reach the correct working temperature: Cooled by the incoming new mixture being compressed, heated by the ignition of the mixture, the correct plug maintain the adequate temperature.
heat range: To work correctly, the electrode demands a working temperature between 752º/1652º f. Below 752º non burned carbon/oil deposits will foul the plug, above 1652º the electrode tip becomes white-hot and cause pre-ignition/detonation (ignition before the correct time/uncontrolled and fast burning of the mixture.
according to their heat range, plugs are classified in "cold" or "hot". This classification has not to do with the spark temperature - a "hot" plug doesn't have a spark hotter than the one of a "cold" plug and v.v. . The heat range of a plug indicates it's capacity of getting rid of excess heat. The picture bellow shows how a plug dissipates this heat. As we can see, 58% of this heat is dissipated trough the cylinder, being this the more important way of cooling.
so, a "cold" plug dissipates heat quicker that a "hot" one. Bellow, you can see the difference between a hot and a cold plug. The last one has a shorter porcelain isolator, offering a quicker path to heat transfer to the cylinder.
accepted that the spark plug needs to work between certain limits of temperature, it should be understood that different conditions of demand from the engine have an effect on this temperature - on high rpm the engine gets hotter and the plug needs to dissipate heat more quickly. This is the reasons why hoped up engines may need colder plugs than the stock one.
learn how to read the plug: This will show you if you are using the plug with the correct heat range. The way to do this is run your engine at full throttle for some time - the longer the better - and stopping the engine not to allow it to idle.
dark brown to black isolator: Too cold plug
light brown isolator: Correct plug
white to light gray isolator: Too hot plug - change immediately
remember: When in doubt, choose the colder one. The worst that can happen is a fouled plug and it runs erratic. Nothing that will cause perminate damage.
resistor plug: As a path for the spark, the plug is an excellent interference producer. With a non resistor type plug in your car, the noise will bleed through your radio station. On your boat the problem is more serious. Your receiver doesn't receive music but it receives signals from your transmitter. The non resistor plug creates an interference field that may even suppress the transmitter signal. If you are using a failsafe, prepare to swim. If you are not using a fail safe, pray for your boat runs out of gas before hitting something or somebody.
so, always use a resistor spark plug. It cuts the interference caused by the jumping of the spark and allows the receiver to receive the transmitter signal.
and what does that array of numbers and letters mean?
they inform all the features of the spark, the ones we already talked and others that we didn't, like the type of electrode, it's material, dimensions for the outer body and even the ....l of the body.
an "r" letter on the code identifies a resistor spark plug. The reach is also indicated by a letter. The heat range has a numeric indication - on some manufactures the higher the number, the colder the plug, on others, the opposite is true.
that's the way the manufacturers identify theirs spark plugs:
bosh
ngk
proper tightening of the plug is important to prevent damage to the plug or, worst, to the head, made of much softer material. The manufacturers recommend those numbers:
spark plug: Torque: (ft/lbs)
10 mm 7
12 mm 10
14 mm 14
18 mm 18
عجبنى الشوية الكلام دول من أحد المواضيع
لما فيهم من فائده فعلا .....فأضفتهم لهذا الموضوع
معلش يا سمير باشا برجعك لموضوع قديم شوية بس والله انت اكثر واحد بستفاد منه
سؤال بس هو البوجية بيجي مظبوط على كام ngk
وهل لازم اضبطو على العربية الانوس الف شكر ياباشااااااااااا
غالبا بيبقى 1مم وأنت لسه شاريه
بس للانوس بيتظبط على
من 0.7 الى 0.8 مم
قول 0.75 مم ( علشان نبقى ماسكين العصايه من النصف )
طبعا الصح ضبط الثغره طالما عارفين قيمتها لعدم إجهاد ملف الأشعال ( البوبينا ) كهربيا والحفاظ عليها بقدر الأمكاناقتباس:
ياباشا إسم الشركه المنتجه للبوجيه مش مهماقتباس:
و ياريت تنصحنى بنوع بوجيه كويس وشكله عشان انا احترت يعنى ngk ولا دينزو ولا بوش
ياريت يباشا توضحلى ايهما افضل
المهم تكون مواصفات البوجيه اللى حيركب عندك فى المكنه
بيلبى المواصفات المطلوبه للبوجيه المستخدم والمتوصف من قبل صانع المحرك ومصمم دايرة الأشعال
___________________
لأن ممكن تركب أى ماركه
بس تكون المواصفات المستخدمه للماركه دى
هى هى مواصفات البوجيه بتاعك الأساسى
حنشبه البوجيه بقميص أو عبايه
وطالما مقاسها مظبوط ومحدد
مش مهم بأه مين اللى يلبس العبايه دى
محمد ولا حسبن ولا اسماعيل
العبايه هى البوجيه ...........مقاسات ومواصفات ثابته
محمد وحسين وأسماعيل .....دول ngk & بوش & دنسو وهكذا
جزاكم الله خيرا يا باشمهندس سمير
شرح مميز ومبسط وإحترافي
الله يخليك
أخى الفاضل
