You CAN NOT compare the Tiggo with the Carens or the Matrix
you are totally correct in that only point. The tiggo wether you liked it or not is an SUV, you can say the worst or cheapest SUV in the world but still its an SUV. Speaking of that, pricewise the nearest competitve in the Egyptian market regarding the SUVs is 40000l.E more expensive. Explaining this point in a different way the tiggo entered the egyptian rally 2009, and although it had a late position it completed the rally till the end (sure the matrix or carens can not enter a rally, not because they are worse than the tiggo, but they are not SUVs). So finally the tiggo could be compared with the Terios or the Vitara, although it is a chinese car but much more cheaper.
