Excuse me. I'd like to point you to something important. increasing the width of the wheel will generate extra load to the CV joint (kbalen). this will decrease the joint life. So if you decided to replace the wheels with wider ones, then use 1 or 2 (at most) step larger. I mean that in your case use 185 or 195 (at most). regardless the rim size.
