it is not that easy... you gotta cut your current lancer and use the rear of the evo to fit the rear diff.
i was in herafeen a few months ago and saw an E36 convertable being painted with very sexy red color... turns out it was cut in half and welded
Yes this turns out to be cheap way to make, First you look for E36 that has to be coupe or compact and take the papers and you are lucky if you found one that has been accident so you save a lot of money, and later you weld the other car, which is usually imported from outside and cut to two and later you take the papers of the of the car and put it in the welded car
There soooo many cars like that, even my friend that works in BMW parts he used to know all the coupes, and now he told I really don't know which is real and which welded !!
Now people do the Mini especially S
There are also Evo, Imprezza.
So next time when you see a nice Evo wonder if its real or Malhoma :3mla::F_eyeb1[1]:
شوف الموضوع ده
Ya but those are Right wheel, so it will be complicated
Best this if you have good money is to travel to Dubai buy any Evo that you like and take it to the shop and cut it in half, and usually people who do that they know exactly were to cut not like the ones like in Port Said they cut anywhere to save time, later on you ship the car here and pay taxes and do the other trick :)
هو انت بتلحم النصين على شاسيه العربيه الاصليه بس كده؟؟ انا سمعت ان فى حوارات تانيه ارقام الشاسيه و الموتور و حاجات بتتغير و كده يعنى مش مضمونه 100% ممكن تتكشف الكلام ده صح؟
