صفحة 1 من 4 1 2 3 4 الأخيرةالأخيرة
النتائج 1 إلى 10 من 35
    الصورة الرمزية asd7778
    رقم العضوية : 32576
    السيارة: لا يوجد
    السيارة[2]: Opel insignia 2014
    دراجة بخارية: uiojolji
    الحالة : asd7778 غير متواجد حالياً
    افتراضي اسرار الفيكترا سى - Facebook Twitter whatsapp انشر الموضوع فى :
    فى منتدى خاص بالفيكترا سى وهو موقع انجليزى ووجدت كلام على بعض الاوبشن الخاصة بالفيكترا سى
    1 - Windows go up and down holding buttons on keyfob.
    2 - disconnect speak in boot for alarm to have horn go off instead
    3 - Open drivers door and flash headlights and the lights and reverse lights will stay on for 30secs
    4 -If you have sight and light pack the windows go up themselves if it rains while your out of the car.
    5 -Sit in the car hold the lock button on the key and lock button on the door for about 10seconds/beep occurs for anti-hijack
    6 - rear windscreen wiper sweeps when in reverse when front wipers are on
    7 - If 1 of your brake lights fail the ECU uses another bulb in the cluster(red 1 of course)
    8 - If you have electric memory seats then the car remembers the position of the seat, door mirrors and internal mirror for each key fob and adjusts them all back to that setting when each key unlocks the car.
    9 - Parking lights
    The front parking light and tail light of one side of the vehicle can be activated when parking:
    1. Set light switch to 0 or AUTO .
    2. Ignition off.
    3. Move turn signal stalk all the way up (right parking light) or down (left parkinglight).
    An acoustic signal sounds and control indicator <> illuminates briefly in the instrument cluster to indicate activation.
    Remove the ignition key before leaving the vehicle.
    To switch it off, switch on the ignition or move the turn signal stalk in the opposite direction.
    10 - Press auto switch on ECC after you stopped the engine, it will activate residual aircondition.
    11 - Hold the 'SETTINGS' or 'MAIN' button for 10 seconds/until a beep is heard on the stereo and then press it to cycle through the hidden screens
    12 - If you dont have a TC switch then this may work on your car, it does on mine... With the engine running flick the ignition off and on quickly so it still runs. All the normal warning lights come on and then go off except the TC light this stays on and voila! TC is off!!
    13 - On full CANBUS cars, when the fuel is low and !!RANGE!! appears, hold the round selector wheel down on the steering wheel to acknowledge the message and get your normal info display back.
    (this works with other info, such as low washer fluid level aswell.)
    14 - Radio Ignition On Logic is programmed per key.
    15 - One-press unlock can be programmed similar to 5 above, but use Unlock button on the key fob.
    16 - Wipers can be set to a vertical position after switching off the ignition (hold down the wiper stalk for a few seconds I think release when they are in the right position).
    17 - The manual is a mind of useful information
    18 - If you unlock the car but do not open a door or the boot within about a minute the car will lock it's self again
    22. Remember Duncan posting this. If you have climate control, and you press in the rotating fan button, you get the option to adjust where the air blows.
    23 - If you press the Un-lock button on the keyfob for more than 3 sec, the electric windows will open
    24 - If you press the Lock-button on the keyfob for 3 sec, the windows will close/you can partly close the windows by stop pressing the button before windows fully closed.
    25 - For cars with Bluetooth and climate control-if the fan is set to auto and you recieve or make a call the fan will blow more quietly. Also works with some aftermarket handsfree kits when the headunit is on mute.
    انا جربت معظمهم شغلين فى عربنى توب لاين واشدهم هو التست مود رقم 11 وهو انك تشغل الكاسيت وبعدين تضعط على زر السيتنج لفترة لغايتة ما تسمع صفاره وبعدين تضعط على غلى زر بى سى (كمبيوتر بورد) مر حتظهر الشاشه العادية وبعدين ضعطه كمان تظهر خمس شاشات مع كل ضعطه على البى سى واهم البيانات هى فولت البطاريه وشحنها درجه الحرار بره وجوه العربيه درجه حرارة سائل التبريد وسرعة العربيه وبيانات بالهبل عن العربيه جامده جدا وشكلها شديد جربوها وقلولى رأيكم ولى مش عارف يشغل حاجه يسألنى
    منقول من موقع فيكترا سى فورم
    الصورة الرمزية tananybasha
    رقم العضوية : 23085
    الاقامة : Giza
    السيارة: لايوجد حالياً
    السيارة[2]: Opel Vectra A Sport 2.0L M/T
    دراجة بخارية: هوندا 1000
    الحالة : tananybasha غير متواجد حالياً
    اكيد جامدين و اللى معاه السى هيشكروك عليها كتير
    لو أن ابن آدم هرب من رزقه كما يهرب من الموت لأدركه رزقه كما يدركه الموت
    محمد الطنانى
    الصورة الرمزية bedo13
    رقم العضوية : 45899
    الاقامة : UppeR EgypT
    السيارة: Vectra 2008 M/T
    السيارة[2]: Mazda3 2009 A/T
    الحالة : bedo13 غير متواجد حالياً
    الف شكر يا معلم
    طب انا عربيتي standard line‏ أعمل ايه :'(
    وداعا أيها الغريب..
    لكن كل شيء ينتهي....
    Little Doc.
    Abd El RahmaN
    رقم العضوية : 32576
    السيارة: لا يوجد
    اقتباس المشاركة الأصلية كتبت بواسطة bedo13 مشاهدة المشاركة
    الف شكر يا معلم
    جربها كدا يا باشا افتح الراديوا وبعدين اضعط على زر setting or menu لغاية ما تسمع صونه تكه بعد كدا جرب تضعط على منيو هما كانوا كتبين فى المنتدى فيكترا سى انه بيتشتغل مع الشاشة الصغيره.
    الصورة الرمزية KHALED AYMAN
    رقم العضوية : 21070
    الاقامة : EL MA7ALA EL KOBRA
    السيارة: الله يرحمها
    السيارة[2]: opel
    دراجة بخارية: -
    الحالة : KHALED AYMAN غير متواجد حالياً
    ما شاء الله ..
    معلومات جامده جدا ..
    انا نازل اجربها...
    الصورة الرمزية N.a.j.d
    رقم العضوية : 35093
    الاقامة : JorDan egypt
    السيارة: Corsa 2007 1.4
    السيارة[2]: Astra 2003 2.0
    الحالة : N.a.j.d غير متواجد حالياً
    طب مفيش حاجه للاسترا ولا ايه
    soon 2011
    [img3]http://img103.herosh.com/2010/03/17/929079106.jpg[/img3]
    لا اله الا الله محمد رسول الله
    رقم العضوية : 21070
    السيارة[2]: opel
    دراجة بخارية: -
    انا جربتها ..
    الحمد لله
    جربت التست مود ده !!
    جاااااااااااااااااامد
    بس انا عايز اعرف ليه منصور ما اعلنش عن الامكانيات دى ؟
    ولا دى حاجات بيستخدمها المهندسين فى الصيانه ؟؟
    رقم العضوية : 23085
    الاقامة : Giza
    اقتباس المشاركة الأصلية كتبت بواسطة khaled ayman مشاهدة المشاركة
    انا جربتها ..
    الحمد لله
    يا باشا دى اسرار حربية منصور عمره ما يطلعها
    محمد الطنانى
    رقم العضوية : 21070
    السيارة[2]: opel
    دراجة بخارية: -
    اقتباس المشاركة الأصلية كتبت بواسطة tananybasha مشاهدة المشاركة
    منصور ده نااااااايم على ودانه ..
    تخيل ان الفيكترا التوب لاين (الى معايا) فيها تسخين فى الكراسى ,,
    و الباشا مش بيجيب سيرته فى الكماليات خااااااااااالص
    انا قدرت اعرف
    الانجيكشن بيضخ كام ملى بنزين فى الثانيه !!!
    رقم العضوية : 32576
    السيارة: لا يوجد
    انا جربتها ..
    الحمد لله
    غالبا يا باشا بتستخدم فى الصيانه فى مصر لكن بره كله عارفها والوكيل بيقول عنها واصلا الوصول ليها بيكون اسهل لان فى الكمبيوتر بورد مود بيكون فى مود اسمه تست مود بتشغله منها على طول وبيكون فى معاها كمان السنسور بناع العجل الى منصور باشا ماركبهوش فى العربيه رغم انه اساسى جدا والله وفى دول كتير بتفرض تركيبه اجبارى.
    سؤال بقى يا رجاله انا نفسى جدا اركب باركنك سنسور فى العربيه بس مش عارف اعمل ايه وكمان انا قرات انا الفيكترا سى ال ecu ما بيديش بور الى ايه حاجه بركب فى العربيه برانى وطبعا على ما اعتقد ان منصور فى الطراوه مش حيركب حاجه يعنى فى توكيلات كتير بعد ما الجى بى اس اتفتح جابت اليونت بتاعت الجى بى اس اصلى او برانى زى تيوتا وهوندا بس منصور و لا كأن فى حاجه حصلت عموما انا عاوز نصيحتكم فى موضوع الباركنج سنسور اعمل ايه وهل ممكن العم منصور يفيد فى حاجه فى الموضوع ده.
  1. اسرار أيه الكرسي
    بواسطة rodyA113 في المنتدى المنتــــــدى الاجتمــاعى
    آخر مشاركة: 08-04-2013, 02:15 AM
  2. اسرار الزينون
    بواسطة amz2011 في المنتدى المنتــــــدى العـــــــــــام للسيــارات
    مشاركات: 14
    آخر مشاركة: 10-11-2011, 02:11 PM
  3. اسرار تعبئة الزيوت في مصر
    بواسطة hossampg في المنتدى زيوت المحرك
    مشاركات: 11
    آخر مشاركة: 22-07-2011, 11:20 PM
  4. اسرار آيه الكرسي
    بواسطة أبو كنوز في المنتدى المنتــــــدى الاجتمــاعى
    آخر مشاركة: 07-09-2009, 10:32 AM
  5. اسرار سوق القطط فى مصر
    بواسطة الطنطاوي في المنتدى المنتــــــدى الاجتمــاعى
    مشاركات: 41
    آخر مشاركة: 17-10-2008, 10:29 PM
