المشاركة الأصلية كتبت بواسطة egyptianmafia
if there is no switch then probably the software you have in the car is not the software for Egypt.....
just because it is flashes...doesnt mean it is technically available in the car
the switch needs to be there.....
if the switch is not there...then the Vectra has no ESP....
and probably the Vectra sold outside of Egypt has ESP and the software in the Vectra in Egypt is not the right software for Egypt
even if you buy the 1st grade Vectra C and then go back to Mansour to have him install curise control....they will install the switch (handle) and then install the software for the high line or top line vectra...because those are the ones that include cruise control in their software.....
and you need to check if the catalog states whether the specs may change from one country or another....look carefully because this line could be very small and somewhere in the book! ....
