النتائج 1 إلى 10 من 21
    الصورة الرمزية pointer
    رقم العضوية : 3719
    الاقامة : القاهره مدينة نصر
    السيارة: CLS 2010
    السيارة[2]: Lamborghini Gallardo 2009‏
    الحالة : pointer غير متواجد حالياً
    افتراضي Obd2 لصيانه السياره حد عاوزه - Facebook Twitter whatsapp انشر الموضوع فى :
    جبت obd2 للسياره ولكن للاسف غير متوافق مع سيارتي لو حد محتاجه يقول
    ومواصفاته
    Technical Details
    1.This cable can not work if your car uses a protocol/bussystem like VPW, PWM or CAN-BUS
    2. Terminal K = Bus of communication
    3. Terminal L = Ignition for waking up car computing system (ECU: Engine Control Unit)
    4. Existed 3 different protocols with same OBD2 connector incl. ISO/KWP, VPW, PMW
    5. This K/L Diagnostic interface & cables work on ISO/KWP (Key Word Protocol) launched after 1996 on
    . Supported also ISO9141 protocol 7.The Cables may work with some versions of the Carsoft, but carsoft used a lot of different interfaces during the different versions and also had some custom interfaces. Workable Model This diagnostic cable is usable for ISO9141 and KWP2000 transmission protocol like used for example by: Volkswagen,Audi,Skoda,Seat Free Softwares includs: Scantool,OBD Gauge by Dana Peters,OBD Logger by Jonathan Senkerik,OBD-II ScanMasterby Wladimir Gurskij, obd2crazy,OBD2 Scantool by Ivan,Andrewjeski,RDDTC by Pete Calinski,ScanTest by Ivan Ganev. Softwares Available to Purchase includes:Digimoto,PCMSCAN,ProScan,VAG-COM. Vehicle Coverage: Fit 1990-2004 VAG Car Makers Models CC Fuel Connector Type Fit or not? AUDI 80 ALL ALL 2x2 ? 100 ALL ALL 2x2 ? 200 ALL ALL 2x2 ? A2 ALL ALL 16 PINS ? A3(8P) ALL ALL 16 PINS X A3 ALL ALL 16 PINS ? A4(B7) ALL ALL 16 PINS X A4 ALL ALL 16 PINS ? A4 Cabriolet ALL ALL 16 PINS ? A6 ALL ALL 16 PINS ? A6(C6/4F) ALL ALL 16 PINS X A8/A8L(D3/4E) ALL ALL 16 PINS X A8 ALL ALL 16 PINS ? Q7 ALL ALL 16 PINS ? S2 ALL ALL 16 PINS ? S3 ALL ALL 16 PINS ? TT ALL ALL 16 PINS ? SEAT Alhambra ALL ALL 16 PINS ? Altea ALL ALL 16 PINS ? Altea(5P) ALL ALL 16 PINS X Arosa ALL ALL 16 PINS ? Cordoba ALL ALL 16 PINS ? Ibiza ALL ALL 16 PINS ? Inca ALL ALL 16 PINS ? Leon MK1 ALL ALL 16 PINS ? Leon MK2 ALL ALL 16 PINS ? Leon(1P) ALL ALL 16 PINS X Toledo ALL ALL 16 PINS ? Toledo(5P) ALL ALL 16 PINS X SKODA Fabia ALL ALL 16 PINS ? Felicia ALL ALL 16 PINS ? Octavia Mk1 ALL ALL 16 PINS ? Octavia MK2 ALL ALL 16 PINS ? Octavia(1Z) ALL ALL 16 PINS X Superb ALL ALL 16 PINS ? Volksw Beetle ALL ALL 16 PINS ? Bora ALL ALL 16 PINS ? Caddy ALL ALL 16 PINS ? Caddy(2K) ALL ALL 16 PINS X Corrado ALL ALL 16 PINS ? Golf MK2 ALL ALL 16 PINS ? Golf MK3 ALL ALL 16 PINS ? Golf MK4 ALL ALL 16 PINS ? Golf MK5(1K) ALL ALL 16 PINS X Golf Plus(5M) ALL ALL 16 PIN
    و للي عوزه هو في القاهره وهو علي 250 جنيه باذن الله وهو جديد تماما و ب السي دي بتاعه التواصل علي الخاص
    [marq="5;right;3;scroll"]اللهم عافنى فى بدنى, اللهم عافنى فى سمعى ,اللهم عافنى فى بصرى , لا اله الا انت , اللهم انى اعوذ بك من الكفر والفقر و واعوذ بك من عذاب القبر , لا اله الا انت[/marq]
    الصورة الرمزية tananybasha
    رقم العضوية : 23085
    الاقامة : Giza
    السيارة: لايوجد حالياً
    السيارة[2]: Opel Vectra A Sport 2.0L M/T
    دراجة بخارية: هوندا 1000
    الحالة : tananybasha غير متواجد حالياً
    مينفعش الأوبل يعنى
    لو أن ابن آدم هرب من رزقه كما يهرب من الموت لأدركه رزقه كما يدركه الموت
    محمد الطنانى
    الصورة الرمزية medomezo
    رقم العضوية : 21219
    السيارة: ........*@#@#@........*
    السيارة[2]: نوبيرا 2004
    الحالة : medomezo غير متواجد حالياً
    (obd2) سؤالى هو ده ايه ؟؟؟؟؟؟؟؟
    رقم العضوية : 3719
    السيارة: CLS 2010
    اقتباس المشاركة الأصلية كتبت بواسطة medomezo مشاهدة المشاركة
    (obd2) سؤالى هو ده ايه ؟؟؟؟؟؟؟؟:b4_611::u_thin1[1]:
    ده عباره عن كابل و له سوفت مير بيمسح السياره سينسور سينسور وبيعطي الاعطال اللي فيها او حاله الموتور ومسح شامل من الكونترول يونت بس
    الصورة الرمزية bolbol2005
    رقم العضوية : 21891
    الاقامة : Ismailia
    السيارة: هيونداي النترا
    السيارة[2]: دايو لانوس
    الحالة : bolbol2005 غير متواجد حالياً
    بكام يا اخي
    الصورة الرمزية alexcdx
    رقم العضوية : 43304
    الاقامة : ALEX
    السيارة: JAGUAR
    السيارة[2]: NUBIRA
    الحالة : alexcdx غير متواجد حالياً
    برجاء رفع صوره له + الأسم التجارى + البلد المصنع
    هل هو vag with k,l support terminals
    أو الموقع الى بشرح فيه عمله أصل الكتابه كلها متلخبطه و مليانه علامات أستفهام بس متهيئلى أن ده خاص بالفولكس 2kالقديم ؟
    شكرا
    رقم العضوية : 3719
    السيارة: CLS 2010
    الكابل طرازه 409.1 وصورته زي دي
    [aldl]http://img.diytrade.com/cdimg/814082/7186582/0/1239092881/USB_KKL_VAG-COM_409_1_VAG_COM_Cable.jpg[/aldl]
    والطرازات اللي بيشتغل عليها مكتوبه في الموضوع وهي قديم وحديث ومعاه كابل اضافي بيشغل الموديلات القديمه نسبيا زي ده
    [aldl]http://www.autodiagnosztika.com/vag2x2.JPG[/aldl]
    واي خدمه
    الصورة الرمزية wanderer
    رقم العضوية : 46648
    السيارة: soon
    السيارة[2]: soon
    الحالة : wanderer غير متواجد حالياً
    طيب هو الكابل ده بيوصل بالسيارة ازاى
    وهل ينفع مع العربيات الكورى
    ممكن اعرف برضه جبته منين
    رقم العضوية : 3719
    السيارة: CLS 2010
    لا لخبطه ولا حاجه الموديلات اللي شغاله واللي مش شغاله اهي
    Compatible Vehicles: Volkswagen, Audi, skoda, seat:
    Audi Models:
    - Compatible: A2 / A3 / A4 Cabriolet / A6 / A8 / S2 / S3 / TT
    - Not Compatible: 80 / 100 / 200 / A3(8P) / A4(B7) / A6(C6/4F) / A8 / A8L(D3/4E) / Q7
    SEAT Models:
    - Compatible: Alhambra / Altea / Arosa / Cordoba / Ibiza / Inca / Leon MK 1 / Leon MK 2 / Toledo
    - Not Compatible: Altea (5P) / Leon (1P) / Toledo (5P)
    Skoda:
    - Compatible: Fabia / Felicia / Octavia MK 1 / Octavia MK 2 / Superb
    - Not Compatible: Octavia (1Z)
    VW:
    - Compatible: Beetle / Bora / Caddy / Corrado / Golf MK2 / Golf MK3 / Golf MK4 / Jetta MK3 / Jetta MK4/ Lupo / Passat MK3 / Passat MK4 / Polo MK3 / Polo MK4 / Touran / Touareg / Transporter T3 / Transporter T4 / Transporter T5.
    - Not Compatible: Caddy (2K) / Golf MK5 (1K) / Golf Plus / Jetta MK5 (1K) / Passat MK5 (B6) / Passat MK6 (B6) / Phaeton / Touran (1T)
    Catalog Ref: Car accessories, cable fault code, VAG-COM, OBD2 cable
    Other Features
    Also supports ISO9141 protocol
    No DC or alternate power supply needed, just connect to your car and computer
    Work with most Volkswagen and Audi models sold worldwide from 1994 to current year
    The K/L Diagnostic interface cables works on ISO/KWP (Key Word Protocol) that were launched after 1996
    رقم العضوية : 3719
    السيارة: CLS 2010
    اقتباس المشاركة الأصلية كتبت بواسطة wanderer مشاهدة المشاركة
    لا كل مجموعه من السيارات لها الكابل والطراز بتعها فلازم تسال الاول
    انا جبته من اتجلترا بفيزا وكلام كتير وكبير اوي المهم هو من انجلترا وما تنتظرش يكون في مصر والا كنت جبته من هنا
    علي العموم ممكن اجيب الكابل المتوافق مع عربيتي قريب لو تحب اي خدمه
  1. جدول لصيانه العربيه
    بواسطة a4_han في المنتدى فـــــورد
    آخر مشاركة: 17-07-2011, 05:14 PM
  2. ايه المطلوب لصيانه ال 80.000
    بواسطة Michael_Lanos في المنتدى هيــونــداى
    آخر مشاركة: 25-12-2010, 10:24 PM
  3. لانوس 2000 هل فيها فيشة Obd2؟
    بواسطة boty50 في المنتدى دايــو+شيفرولية لانوس
    مشاركات: 22
    آخر مشاركة: 23-09-2008, 12:04 PM
  4. الحدالاقصى لصيانه 1000كيلو
    بواسطة has1 في المنتدى هيــونــداى
    مشاركات: 12
    آخر مشاركة: 26-10-2007, 10:31 PM
