اوعى تشترى هيونداى
نصيحة من واحد بيفهم فى العربيات أوعى تشترى هيونداى و خصوصا المانيوال
بص يا سيدى الفتيس المانيوال فى أجيال هيونداى نفس التصميم فى Accent, Elantra, Getz, I30 And so on يعنى شوية دقيق و مية و شوية العجينة ممكن تطلع كحك و ممكن بسكويت أو ممكن بديفور.
و هيونداى عندها عيب تصميم فى الدبرياج
http://www.carsurvey.org/reviews/hyu...mments/page-3/
المشاركة دى منقولة من الموقع و شوف الراجل بيعدل تصميم الدربرياج بتاع شركة هيونداى اللى هي المفروض تصنع عربيات لعب للأطفال
2nd Aug 2009, 23:14
I bought a 2008 Elantra with a slipping clutch up front. I repaired it myself. Car had 72,000 miles on it which I thought was low miles for a clutch problem.
I am used to a clutch design having a release fork which is removable from the bellhousing, a return spring, and a push style release bearing pushing the clutch fingers forward for disengagement.
This Elantra, however, has the release bearing moved by an arm integrated into the bellhousing supported by two plastic bearings. The release bearing snap locks into the clutch fingers and always rides the clutch fingers. Since the release bearing is locked to the clutch fingers, it is pulled back to disengage the clutch. Also the clutch mechanism has no return spring, so all of the return power comes from the clutch fingers.
Dust as the clutch wears, got into the plastic bearings and increased the force needed to push the arm holding the release bearing back to its rest (clutch engaged) position.
The clutch fingers have to push both: the release bearing against this increased shaft resistance and the back pressure resistance in the hydraulic fluid in the system. This increase in force bent my clutch fingers inward.
To help stop this in the future, after replacing the clutch following a turned flywheel. I removed the slave cylinder fluid resistance by taking out a hydraulic orifice plate and spring, located right behind the fluid hose nut on the slave cylinder. Second, I determined where the clutch likes to rest when at rest (engaged). Welded an extension to the end of the slave cylinder clutch lever and attached a return spring to give assistance to the return of the clutch.
I then welded a nut to the other end of the slave cylinder clutch lever and put a bolt through it, with a lock nut, to rest against the flat part of the transmission. This keeps the arm from being pulled back too far by the new return spring and the clutch arm always moves back to its rest position.
As the clutch wears, a periodic adjustment will be necessary of this bolt to allow the clutch to fully engage since its zero point is now held by a bolt adjustment.
This design has been done on a few other models of cars I've owned so only time will tell if this Elantra will like it.
Note: This will slightly increase the pedal resistance of the clutch pedal during shifting. Spring pulls back about 5 lbs so it is hardly felt.
صدقتونى
Hyundai has a baaaaaaaaaaaad clutch design
مع صحبى اكسينت من سنة 99 مغيرتش اسطوانة !
وانا معايا من سنتيين و ذى الفل
و خالى عملة 280 الف كيلو و بتأمرك !!
مش اى حاجة مكتوبة بالانجليزى تصدقها يأستاذى :)))))
هى عربيات هيونداى دى نزلت مصر امبارح مثلا دى عربيات موجودة من سنين
بالنسبة للشخص اللى بيعدل دة فمش اى حد نسمع كلامه وخلاص
كلام مش منطقى طبعا انا معايا النترا و عديت ال 100 الف كيلو و ما شاء الله زى الفل و ليا اصحابى معدين بيها ال 200 الف و لا فيها اى كلام من اللى حضرتك بتقوله مش لدرجه عربيات اطفال يعنى
لو كانت كده مكنتش قعدت ده كله في مصر
ولا نجحت كده و لا نتشرت كده
و ليس كل ما يكتب بالانجليزيه حقائق يا باشا
انا اخويا راكب اكسيل وكان عندو مشكلة في الغيار التالت ولما سئل قالو ان فتيس الاكسيل كلو في مشكلة في الغيار التالت بس بصراحة ماشوفتش اي هيونداي في مشكلة في الفتيس
بصراحة الهيونداى اثبتت كفاءة فى مصر
بصراحه انا بحترم هيونداي جدا لان اي عربيه تثبت كفاءه في مصر تبقي عربيه جباره. احنا في بلد مفيهاش شارع تعرف تمشي فيه ده غير الحر الشديد جدا و كميات التراب المهوله اللي تسد اجدعها فلاتر. هيونداي عدت من كل ده يبقي اكيد عربيه محترمه.
و كان رئيس شركة هوندا و نيسان اعدين يقولوا هيونداي مذهلة هيونداي هتسبقنا
فعلا هيونداي بقت الرابع على العالم في المبيعات لانها رخيصة و عملية و اقتصادية
Content Relevant URLs by
vBSEO 3.6.0 PL2
