أكواد زيوت شركة فولكس
  • أكواد زيوت شركة فولكس
    VW Group Lubricants
    VW 009 300 - VW power steering fluid spec.
    VW 500.00 - VW spec for multigrade engine oils for petrol engines with SAE 5W-X/10W-X viscosity.
    VW 500.00 + 505.00 - Oil meets both VW 500.00 and 505.00 spec.
    VW 501.01 - VW spec for petrol engines.
    VW 501.14 - Brake fluid with low viscosity, VW 2006>.
    VW 502.00 - VW spec, oil for petrol engines. Successor of VW 501.01 & 500.00 spec.
    VW 503.00 - Long-life petrol engine oil for VW cars with WIV. Meets ACEA A1, SAE 0W-30 or 5W-30.
    VW 503.01 - Special engine oil for some VW petrol engines. SAE 5W-30.
    VW 504.00 - Long-life petrol engines with WIV.
    VW 505.00 - Passanger car diesel engine oil, minimum performance level CCMC PD-2. Lists viscosities:- SAE 5W-50, 10W-50/60, 15W-40/50, 20W-40/50 requiring 13% max evaporation loss and SAE 5W-30/40, 10W-30/40 requiring 15% max evaporation loss.
    VW 505.01 - Special engine oil for VW turbodiesel with pump-injector-unit and for the V8 commonrail turbodiesel engines. Meets ACEA B4 SAE 5W-40 spec.
    VW 506.00 - Special long-life engine oil for turbodiesel engines with WIV, viscosity is SAE 0W-30.
    VW 506.01 - Special long-life oil for turbodiesel engines with pump-injector-unit with WIV.
    VW 507.00 - Long-life diesel engine oil with WIV.
    VW B 000 700 A - Special VW approved brake fluid.
    VW G 002 000 - Special VW hydraulic fluid for power steering.
    VW G 004 000 - Special VW hydraulic fluid for power steering.
    VW G 009 317 - VW gear oil for manual & automated 6 speed transmissions.
    VW G 052 145 - Special synthetic gear oil, SAE 75W-90.
    VW G 052 162 - VW spec for Esso LT 71141. Special ATF with additional friction modifier for some ZF automatic gearboxes (ZF 4HP20, 5HP19, 5HP24, etc).
    VW G 052 171 - Gearbox oil SAE 70W-75.
    VW G 052 175 - Special fluid for Haldex clutch. Developed by Haldex and Statoil.
    VW G 052 178 - Gearbox oil SAE 75W.
    VW G 052 180 - Special VW fluid for multitronic CVT.
    VW G 052 190 - Special VW fluid for multitronic CVT transmissions and differential, built in one.
    VW G 052 300 A2 - Compressor oil.
    VW G 052 726 - Gear oil SAE 75W.
    VW G 052 798 - Gearbox oil SAE 70W-75.
    VW G 052 911 - Audi spec, for gearboxes of FWD cars with longitudinal engines. Meets API GL-5, SAE 75W-90.
    VW G 052 990 - Special ATF, for VW automatic transmission and differential built in one.
    VW G 055 005 - Special ATF, for VW automatic transmissions and transaxles.
    VW G 055 145 - No info available.
    VW G 055 162 - Special ATF, for VW automatic transmissions and transaxles.
    VW G 055 175 - Special fluid for Haldex-clutch. Developed by Haldex and Statoil.
    VW G 11 TL 774-C - VAG spec engine coolants.
    VW G 12 TL 774-D - VW standard antifreeze for use with VW group vehicles. Red in colour - must NOT be mixed with other antifreezes and particular coolant additives which comply with standard TL VW 774B or C (G11) - Blue-Green in colour (which may have been used in earlier VW group vehicles). This standard should NOT be used to top up TL VW 774F (G12 Plus).
    VW G 12 TL 774-F - VW standard for antifreeze for use in VW group vehicles, Purple-Lilac colour - can be mixed with TL VW 774D - Red in colour (which may have been used in earlier VE group vehicles).
    VW G 50 - Special synthetic gear oil, GL-4+ SAE 75W-90.
    VW G 51 - Special synthetic gear oil, SAE 75W-90.
    [sor2]http://oi41.tinypic.com/eranop.jpg[/sor2]
