Do You Know What This Symbol Means?
  • Do You Know What This Symbol Means?
    Do you recognize the symbol here? It lights up in your instrument panel and looks like a U-shaped pictograph with treads and an exclamation point in the middle.
    Do you understand what it means now?
    If you guessed a low tire-pressure warning, you are right. If you didn’t recognize the symbol, that’s also understandable because one out of three drivers do not, according to Schrader, a company that makes tire pressure monitoring systems.
    The warning for the TPMS lights up when one or more of your vehicle’s tires is 25% below the manufacturer’s recommended pressure. The system is now required on all vehicles starting with the 2008 model year.
    The issue here seems to be that the public hasn’t been properly educated on the warning symbol, which is supposed to be “idiot proof” and understandable across a wide variety of cultures and languages. Yet 46% of drivers couldn’t figure out that the icon represents a tire and 14% thought the symbol represented another problem with the vehicle entirely, according to Schrader.
    As we said earlier in the week, properly inflated tires are vitally important to your safety. Low pressure will affect your braking, acceleration, stability, cornering and fuel economy. The government instituted the TPMS mandate after the Bridgestone/Firestone tire failures on the Ford Explorer in 2000, a controversy that was partly attributed to inadequately inflated tires.
    Source: Yahoo-Auto
    تيل الفرامل الأمامي يا باشا..
    this symbol indicates Warning for BRAKE PAD
    best regards
    [fot1][CENTER][SIZE="3"]أحد أدمنز جروب: [SIZE="5"][FONT="Tahoma"] >< اسبرانزا للجميع >< [/FONT][/SIZE][/SIZE][/CENTER][/fot1] ع الفيس بوك
      the warning for the tpms lights up when one or more of your vehicle’s tires is 25% below the manufacturer’s recommended pressure.
      الأجابه
      ولسه ياما هنشوف فى تكنولوجيا السيارات
        انا مش عارف ناويين يوصلو لفين
        [RIGHT][FONT=Arial Black][COLOR=#000000][/COLOR][/FONT] [/RIGHT]
          دى بتاعة تيل الفرامل وهى معمولة شبة علامة الهاند بريك
          [COLOR=navy][SIZE=6]TAREK AL AKKAD[/SIZE][/COLOR]
            بس دى مش موجوده فى اى عربيه (طبعا انا بتكلم عن عربيات مصر)
            انا عرفتها لما جبت كتالوج عربيتى من على الموقع بتاعهم لاقيتهم شايلين منها حاجات بالهبل هنا فى مصر
            اللهم إني أعوذ بك من علم لا ينفع ومن قلب لا يخشع ومن نفس لا تشبع ومن دعوة لا يستجاب لها
              المشاركة الأصلية كتبت بواسطة kimocyc مشاهدة المشاركة
              best regards
                المشاركة الأصلية كتبت بواسطة tarekmomo مشاهدة المشاركة
                  دي بتاعت إنخفاض الضغط داخل أحد الإطارات
                  رأيتها في جراند شيروكي
                  [sor2]http://img401.imageshack.us/img401/6193/5vgb.jpg[/sor2]
