CRANKSHAFT SENSOR(CPS) TESTING
INDUCTIVE TWO WIRE TYPE(ENGINE SENSOR)
A vehicle's Crankshaft Position Sensor (CPS) can give non start problem Particularly Fiesta/Escort (corrosion in connector) and Clio/Megane's (dirty sensor).
These are normally on the clutch bell housing, but can also be on the crankshaft pulley (next to alternator drive belts). If possible pull connector apart and clean connection with WD40 (these sensors produce their electricity about 0.2-2.0 AC volts when engine turning, so can easily be lost due to corrosion) if still non start next check if sensor is working by using a volt meter.
Set meter to AC volts, you might need to attach some leads to sensor to test, loud speaker leads often are the right size for this, with meter set on Ohm's check the resistance should be around 200-500 Ohm's normally, if really high resistance try to find correct specification but normally would be faulty, if seems ok set meter to AC volts and crank engine being careful of moving parts, you should get a reading of between 0.2 and 2.0 volts with engine turning, if no reading remove sensor and clean, sensor some times are contaminated with particles from the clutch, which can stop them working. Refit and test to see if producing AC electricity. Sometimes it can be very hard to get the senor out, a trick that will sometimes work is, if you can see a hole in the bell housing near the Crankshaft Position Sensor (CPS) sensor try spraying carburettor cleaner onto the flywheel, when cranking the engine, this will sometimes clean the sensor and the vehicle will start.
VEHICLE CAMSHAFT SENSOR TESTING
There are two types of camshaft sensor, two wire inductive pick-up and three wire hall effect type.
TWO WIRE INDUCTIVE TYPE (ENGINE SENSOR)
These are very similar to crankshaft sensors, follow testing
TESTING CAMSHAFT SENSORS
THREE WIRE HALL EFFECT SENSOR TYPE (ENGINE SENSOR
These can be tested with a multi-meter, there should be a 5 volt supply, a negative with ignition on and a switching voltage with the engine turning, the meter will read the average of the switching normally between 0.5-1.5 volts.
USING A MULTI-METER
Insert a paper clip into rear of the connecter see picture, you should read 5 volts between pins 1 and 2 with the ignition on and a switching voltage (0.5-1.5v) between 2 and 3 with the engine turning.
Note check pin numbers may be different and black tape to prevent shorting.
USING A MULTI-METER
