please help about wd 40 replacment
  • please help about wd 40 replacment
    i there any lubrictant for car joints
    becuase vasline is not good eats rubber i am a chemist do not ever ues vasline on rubber
    also wd 40 us flammabele and not good lubrictant aslo i think bad for rubber
    so is there somthing like it
    for lubrictant in egeypt
    and also multi purpose
    على فكرة انا بتكلم انجليزى كويس جدا لانى اساسا فى متخرج من مدارس انجليزى
    وكمان فى هندسة
    يعنى بفهم كويس فى الانجليش
    بس فى اعضاء هنا مش بيردو لانهم مش فاهمين ولذلك انا مش هرد غير اما تكتب عربى
    [rmade]http://www7.0zz0.com/2014/09/24/17/941743282.jpg[/rmade]
      على اى اساس الفازلين مضر على المطاط ممكن مصدر المعلومات
      [SIGPIC]http://imageshack.us/photo/my-images/545/6c6d1551112s.gif/[/SIGPIC]
        first i can not write in arabic because my keyboard in notebook is english also i write in arabic very slow as all sheets in my work is in english
        vasline consists of two matarials one is viscous fluid manily is oil and also a supporter which is heavy and can not move easily
        so the viscous fluid is good for your rubber as it will make it a lot softer because if the rubber becomes hard it will be damaged easily and vasilne is good because i you use this viscous fluid directly which is manily vegitable oil it will collect dust and its effect will gone quickely so the supporter will increase the life time of the fliud and willnot collect dust but after the fluid is finished you will see a dark fliud which is the supporter and full of dust this kind of supporter is bad for rubber as it is manily a petrolium product which will crack it easily the grease which is called shhm in arabic is many kind and the best one is the synthetic
        you can use silcon based products for rubber as it is a very healthy supporter but take care for your glass window
          what parts exactly do you want to lubricate
          grease is the main material used by car makers
          some of the service agents also use wd40 for parts like windows machines>
          use www.yamli.com/editor to write in franco arab and it will translate it into arabic
          [CENTER][COLOR=Blue][B][SIZE=4]يا بلادى يا بلادى.........أنا بحبك يا بلادى[/SIZE][/B][/COLOR]
            rubber brushing between springs and suspeintion and all about suspention i own seina 2002
              if something that has some sort of container then go with the grease
              it's used in places such as inside the upper shock mounts AKA البطاحات
              if something that can't contain the grease, wd40 is the only solution I know.
                silcon based products like what ineed acommercial name
                  There's another product called
                  STP Silicon spray
                  I only get it from Emirates fuel stations
                  a small bottle for 20 or 22 le
                    wow................... thanks for your clarification
                      you are welcome
                        المشاركة الأصلية كتبت بواسطة Fadi Ezzat مشاهدة المشاركة
                        وكمان فى هندسة
                        [CENTER]:auto:[/CENTER]
                          مش فاهم حاجة
                          [CENTER][URL="http://www.facebook.com/pages/Opel-Vectra-B/118286498828"][sor2]http://badge.facebook.com/badge/118286498828.2713.630313105.png[/sor2][/URL]
                          [B][SIZE=4]لما نعيش فى تبات و نبات و نجيب صبيان و بنات إسمى هو الى هيخدوه منى و بس[/SIZE][/B]
