عاوز رسم داخلى لعلبة الشكمان
  • عاوز رسم داخلى لعلبة الشكمان
    انا عاوز رسم بيوضح تكوين وطريقة عمل علبة الشكمان من الداخل
    انا عارف انه طلب صعب لكن الاعضاء هنا قدها وقدود
    [B]بَلْ سَوَّلَتْ لَكُمْ أَنفُسُكُمْ أَمْرًا فَصَبْرٌ جَمِيلٌ وَاللَّهُ الْمُسْتَعَانُ عَلَى مَا تَصِفُونَ[/B]
    اتفضل يا باشا
    [CENTER][shr71=http://dostor.org/sites/default/files/10/Feb/05/gallery/ent.jpg]مـــــــصـــــــــر[/shr71]
    :majd(4):
      و ده الشرح بالانجليزي
      Your car's exhaust system carries away the gases created when the fuel and air are burned in the combustion chamber. These gases are harmful to humans and our environment. Make sure there are no holes in the exhaust system or in the passenger compartment where exhaust fumes could enter. Below is a listing of the parts of the exhaust system and their functions.
      Exhaust manifold:
      The exhaust manifold attaches to the cylinder head and takes each cylinder's exhaust and combines it into one pipe. The manifold can be made of steel, aluminum, stainless steel, or more commonly cast iron.
      Oxygen sensor:
      All modern fuel injected cars utilize an oxygen sensor to measure how much oxygen is present in the exhaust. From this the computer can add or subtract fuel to obtain the correct mixture for maximum fuel economy. The oxygen sensor is mounted in the exhaust manifold or close to it in the exhaust pipe.
      Catalytic converter:
      This part converts harmful carbon monoxide and hydrocarbons to water vapor and carbon dioxide. Some converters also reduce harmful nitrogen oxides. The converter is mounted between the exhaust manifold and the silencer box (muffler).
      Silencer Box (Muffler):
      The silencer box serves to quiet the exhaust down to acceptable levels. Remember that the combustion process is a series of explosions that create a lot of noise. Most silencer boxes use baffles to bounce the exhaust around dissipating the energy and quieting the noise. Some also use fiberglass packing which absorbs the sound energy as the gases flow through.
      Exhaust pipe:
      Between all of the above mention parts is the exhaust pipe which carries the gas through it's journey out your tail pipe. Exhaust tubing is usually made of steel or aluminized steel tubing
      :majd(4):
        thanks
