Lamborghini Reventon - 2008
  • Lamborghini Reventon - 2008
    The technology found in the Murciélago LP640 has not been modified. The engine in the LP640 forwards is the classic twelve-cylinder engine with 6.5 litre displacement. Only for this car, Lamborghini guarantees, an astounding 650 HP (478 kW) at 8,000 revolutions per minute (rpm). The huge torque, equal to maximum 660 Nm, ensures a powerful switch from any number of revolutions: even the slightest pressure on the accelerator is spontaneously transformed into thrust. The robotised e.gear changes gear faster than even the most expert driver. In addition, the permanent Viscous Traction four-wheel drive system ensures that every force is constantly translated into movement.
    As in the original Murciélago LP640, the Reventón accelerates from 0 to 100 km/h in just 3.4 seconds, with a maximum speed over 340 km/h.
    Lamborghini Reventón - Technical data
    Frame
    High strength tubular steel structure with carbon fibre components.
    Bodywork
    In carbon fibre, except roof and door external panels (steel)
    Steering
    Type: Mechanical (rack and pinion) power-assisted
    Right-hand turning circle: 12.55 m (41.17 ft)
    Wheels and tyres
    Front: 245/35 ZR 18
    Rear: 335/30 ZR 18
    Engine
    Type: 12 cylinders at 60°
    Bore and stroke: 88 mm x 89 mm (3.46 in x 3.50 in)
    Displacement: 6496 cc (396.41 in3)
    Compression ratio: (11 ± 0.2):1
    Maximum power: 650 HP (478 kW) at 8000 rpm (guaranteed through the engine selection)
    Maximum torque: 660 Nm (487 lb-ft) at 6000 rpm
    Engine position in vehicle: Longitudinal central-rear
    Cylinder heads and engine block: Aluminium
    Intake system: Variable geometry with 3 operating modes
    Performance data
    Top speed: 340 km/h (211.3 mph)
    Acceleration 0-100 km/h (0-62 mph): 3.4 s (before: 3.8 s)
    Fuel Consumption (according to DIR 1999/100/CE)
    Urban: 32,3 l/100km
    Extra-urban: 15,0 l/100 km
    Combined: 21,3 l/100 km
    CO2 emissions: 495 g/km
    [CENTER]الحمد لله[/CENTER]
    [CENTER] [/CENTER]
    [CENTER][sor2]http://farm3.static.flickr.com/2639/3939929853_4547d6e150.jpg[/sor2][/CENTER]
      no comment
      [SIGPIC][/SIGPIC]Opel : 1 Team , 1 Family , 1 Goal
      حرااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااام
      [URL="http://www.postimage.org/image.php?v=PqJgCQ0"][img]http://www.postimage.org/PqJgCQ0.jpg[/img][/URL]
