جميع موديلات أستون مارتن الحالية
This is a sticky topic.
  • جميع موديلات أستون مارتن الحالية
    1- DB9 :
    Engine
    - All alloy, quad overhead camshaft, 48-valve, 5935cc V12
    - Compression ratio 10.3:1
    - Visteon engine management controlling fuel injection, ignition, diagnostics and misfire detection system.
    - Stainless steel by-pass valve exhaust system
    - Maximum power 335 kW (450 bhp) at 6000 rpm
    - Maximum torque 570 Nm (420 lb ft) at 5000 rpm
    - Acceleration 0-60 mph in 4.9 seconds
    - Maximum speed 186 mph (300 km/h)
    2-V8 Vantage:
    Engine:
    - All alloy quad overhead camshaft 32 valve, 4.3 litre V8
    - Variable inlet camshaft timing
    - Dry sump lubrication system
    - Fully catalysed stainless steel exhaust system with active bypass valves
    - Front-mid mounted engine
    - Rear wheel drive
    Projected Performance figures:
    - Maximum power: 283kW (380 bhp) @ 7300 rpm
    - Maximum torque: 410Nm (302 lb.ft) @ 5000 rpm
    - Maximum speed: 175 mph
    - 0-60 mph in 4.9 seconds
    - 0-100 km/h in 5.0 seconds
    3-Vanquish S:
    Engine
    All alloy, quad overhead camshaft, 48-valve, 5935cc 60° V12. Front engine, rear-wheel drive.
    Twin PTEC engine management system controlling fuel-injection, ignition and diagnostics.
    Fully catalysed stainless steel exhaust system with active by-pass valves.
    Compression ratio: 10.8:1.
    Maximum power: 388 kW (520 bhp) at 7000 rpm
    Maximum torque: 577 Nm (425 lb.ft) at 5800 rpm
    Acceleration: 0-100 km/h (62 mph) in 4.8 seconds
    Maximum speed: Over 200 mph
    تم التثبيت من قبل الإدارة
    مع الاسف مفيش صور حاول ترفعهم تاني او تشوف لينكات تانيه
    [sor2]http://www.fotoobook.com/images/d/dw/original/2012-04/1334998509_1143.jpeg[/sor2]
      مافيش صورررررررررررررررررررررررر
      [mtohg=#ff0000]http://www.mlfati.net/uploads/images/mlfati-62c14c8f53.jpg[/mtohg]
      ا[COLOR=black]للهم لا اله الا انت سبحانك ............انى كنت من الظالمين[/COLOR]
      م/ محمــــــــــــد جمــــال رضـــوان
        الصور تقريبا موقع التحميل حذفها
        [CENTER][B] :penguin4: [/B][B][SIZE=4]
        [/SIZE][/B][/CENTER]
          الصور مش ظاهرة
          [aldl]http://nileup.com/up/uploads/nilemotors_13899410841.jpg[/aldl]
            لا إله إلا الله ولا حول ولا قوة إلا بالله العلي العظيم
