Ferrari 206 GT
Production period
Number built 1968 - 1969
152
Engine
Engine
Bore (mm)
Stroke (mm)
Stroke volume
Compression ratio
Maximum power (HP)
At speed of rotation (rpm)
Gear V-6 65°
86
57
1987
9.3:1
180
8000
5 Speed
Performance
Top speed (kph)
0-100 kph 235
Ferrari 246
GT and GTS "Dino"
Production period
Number built 1969-74 (GT)
1972-74 (GTS)
2487 (GT)
1274 (GTS)
Engine
Engine
Bore (mm)
Stroke (mm)
Stroke volume
Compression ratio
Maximum power (HP)
Gear V-6 65°
92,5
60
2418
195
7600
5 Speed
Performance
Top speed (kph)
0-100 kph 235
Ferrari 308 GT4
Production period
Number built 1974-1980
2826
Engine
Engine
Bore (mm)
Stroke (mm)
Stroke volume
Compression ratio
Maximum power (HP)
Gear V-8
81
71
2926
255
7000
5 Speed
Performance
Top speed (kph)
0-100 kph 236
6.6
Ferrari 308 GTB and GTS
Production period
Number built 1975-77 (GTB Glass-fibre)
1977-80 (GTB Steel)
1977-80 (GTS)
712 (GTB Glass-fibre)
2185 (GTB Steel)
3219 (GTS)
Engine
Engine
Bore (mm)
Stroke (mm)
Stroke volume
Compression ratio
Maximum power (HP)
Gear V-8 90°
81
71
2926
8.8:1
255
7700
5 Speed
Performance
Top speed (kph)
0-100 kph 252
Ferrari Mondial 8 Coupe
Production period
Number built 1980 - 1982
703
Engine
Engine
Bore (mm)
Stroke (mm)
Stroke volume
Compression ratio
Maximum power (HP)
Gear V-8 90°
81
71
2926
8.8:1
214
6600
5 Speed
Performance
Top speed (kph)
0-100 kph 230
Production period
152
Engine
Engine
Bore (mm)
Stroke (mm)
Stroke volume
Compression ratio
Maximum power (HP)
Gear V-6 65°
86
57
1987
9.3:1
180
8000
5 Speed
Performance
Top speed (kph)
0-100 kph 235
Ferrari 246
GT and GTS "Dino"
Production period
1972-74 (GTS)
2487 (GT)
1274 (GTS)
Engine
Engine
Bore (mm)
Stroke (mm)
Stroke volume
Compression ratio
Maximum power (HP)
Gear V-6 65°
92,5
60
2418
195
7600
5 Speed
Performance
Top speed (kph)
0-100 kph 235
Ferrari 308 GT4
Production period
2826
Engine
Engine
Bore (mm)
Stroke (mm)
Stroke volume
Compression ratio
Maximum power (HP)
Gear V-8
81
71
2926
255
7000
5 Speed
Performance
Top speed (kph)
0-100 kph 236
6.6
Production period
1977-80 (GTB Steel)
1977-80 (GTS)
2185 (GTB Steel)
3219 (GTS)
Engine
Engine
Bore (mm)
Stroke (mm)
Stroke volume
Compression ratio
Maximum power (HP)
Gear V-8 90°
81
71
2926
8.8:1
255
7700
5 Speed
Performance
Top speed (kph)
0-100 kph 252
Production period
703
Engine
Engine
Bore (mm)
Stroke (mm)
Stroke volume
Compression ratio
Maximum power (HP)
Gear V-8 90°
81
71
2926
8.8:1
214
6600
5 Speed
Performance
Top speed (kph)
0-100 kph 230
