better than the best
  • better than the best
    شكرا يا باشا
    بس جامد اوى اوى اوى اوى اوى اوى اوى للصبح التورك رينج بتاع ال 335i من 1300 - 5000 شئ فظيييييييييييييييييع دية علطول فى التورك رينج
    [CENTER]الحمد لله[/CENTER]
    [CENTER] [/CENTER]
    [CENTER][sor2]http://farm3.static.flickr.com/2639/3939929853_4547d6e150.jpg[/sor2][/CENTER]
      also the high rev v8 is mind blowing the only problem with the new m3 is weight
        it revs to 8400 woooooow i want to hear it's sound
        [CENTER] [/CENTER]
          بس لية تسارع ال335 مش حراق زي التانيين رغم أن عزمها متوافر عند عدد لفات موتور(rpm) قليل أعتقد فية سببين(كما في الصورة التالية):
          أولا:نسبة التخفيض النهائي(للكورونا)أقل من الام3 وبالتالي أكيد تسارع أقل من السكون.
          ثانيا:مفيهاش كورونا لوك(lsd)وبالتاي يزود احتكاك الاطارات ويقلل التسارع.
            i am sure in reality it can accelerate faster than that i've seen it pull even with an e46 m3
              and i think it can be faster than e46 m3 if only change the differentials with e92 m3 differentials
                يا جدعان .. ال335 دي2 تيربو ... 3000سي سي2 تيربو .. و التيربو مايظهرش تاثيره غير بعد 2800-3000 ار بي ام .. عشان كده الحته بتاعه التورك باند
                  hi xpert really glad that a bmw turbo professional joined our discussion
                  BMW fit this new engine with two small-displacement turbochargers--instead of one larger unit--in an effort to reduce lag. And for the most part, it worked.
                  and this this its dyno chart:
                  and this this the link to those who did the dyno:
                  xpert please tell us what you think.
                    the turbos are fitted so that one works at lower engine speeds to boost low end torque while the other picks up at higher revs so that u get a wide smooth torque band
                      sorry i was wrong the 335i has a parallel turbo setup so both turbos work together
                        what i think .. if only i can get my hands on such an engine , and a 1 series or a E30 3 series ....
                          lol you will have to wait for a long time
                          what i want is a BMW v8 in an e21 if possible
                            possible and done , and isa next 5 years i will do an M5 V8 in the e30 ..., and a V12 in a e30 too ...
                              there is also 135i
                              the same engine of 335i yet turbo
