BMW 4.4L V8 twin-turbo
  • BMW 4.4L V8 twin-turbo
    Undoubtedly, the most unique feature of the 4.4L TT is the packaging of the turbochargers in the valley between the cylinder banks.
    This is made possible by the swapping of the intake and exhaust ports in the cylinder heads, with the exhaust now exiting towards the middle. This allows the turbochargers to be mounted in the valley with minimal plumbing, which means less bulk, lower weight and better efficiency.
    Immediately after exiting the turbochargers, the exhaust gases enter the catalysts. It's important to keep the cats as close as possible, as the exhaust carries heat that is required for the converters' operation.
    Packaging the cats in this location underneath the hood must present some interesting insulation challenges!
    Instead of expensive variable-vane technology, each turbo makes use of fixed geometry and relatively simple wastegates.
    Each compressor is fed via a black oval-shaped duct, as shown above.
    Between the compressor outlet and the intake manifolds lie a pair of air-to-water intercoolers, one for each bank. Such an intercooler reduces packaging volume and tract length compared to a top- or front-mounted air-to-air heat exchanger.
    Immediately downstream of the intercoolers lie a pair of electronically-controlled throttle bodies.
    Below each centrally-located coil-on-plug (COP) assembly resides the direct injector, along with the feed lines and fuel rail. It's presumed that piezoelectric injectors are employed here, which are fast enough to allow several injection events per combustion cycle.
    Each fuel rail gets its own fuel-pressure regulator. The operating system of this system is yet unknown, but we're guessing that it's similar to the 200 bar (3000 PSI) that is used in the engine's direct-injection predecessors.
    Dished pistons are used to lower the compression ratio, with a compact ring package to reduce crevice volume and frictional losses.
    The net effect is a peak of 400 HP, with 450 lb-ft of torque delivered between 1750 and 4500 RPM. In a sport sedan such as the 5 Series, this engine will likely erase fond memories of the musclecar era, and even in portly SUVs such as BMW's X5 and X6, the result should still be rather impressive.
    [CENTER][RIGHT][CENTER][SIGPIC][/SIGPIC]
    [/RIGHT]
    شكرا يا باشا
    [CENTER]الحمد لله[/CENTER]
    [CENTER] [/CENTER]
    [CENTER][sor2]http://farm3.static.flickr.com/2639/3939929853_4547d6e150.jpg[/sor2][/CENTER]
      وهم بجد
      انا بعشق بي ام بجد احسن ناس عملو عربيات في الدنيا
        BMW 4.4L V8
        وكمان
        twin-turbo
        ومطلع 400 بس !!!!
          المشاركة الأصلية كتبت بواسطة FLYINGPEUGEOT مشاهدة المشاركة
          BMW 4.4L V8
          وكمان
          twin-turbo
          ومطلع 400 بس !!!!
          مش عارف برضه ازاي .... بس يمكن تكون متعوضة في العزم ؟؟
          [CENTER][URL=http://imageshack.us][IMG]http://img248.imageshack.us/img248/876/30717208md0.jpg[/IMG][/URL][/CENTER]
          [CENTER][COLOR="Navy"][SIZE="4"]علي ارتفاع [COLOR="Purple"] 2,285[/COLOR] m :cool: [/SIZE][/COLOR][/CENTER]
          [CENTER][B][COLOR=navy]لا اله الا الله محمد رسول الله [/COLOR][/B][/CENTER]
            وده ده ايه ده بينه شيكولاته
            اللهم عيشنا عيش الاخرة
            علشان دمنا ميتحرش من العربيات الى نزلى اليومين دول والمواتير الغريبة ده
            طول عمرى بشوف الماتور عبارة عن كتلة حديد مشحمة
            اول مرة اعرف انه تحفة فنية كدة
            ربنا يباركلك يبنى على الموضوع الجميل ده
              الموتور chocked علشان يفتح المجال لل ام فايف و الام ثري علشان يتباعو يا عم ... بعدين ل 400 دوول الشركه اللي قايلاهم . انما هوه اصلاً اكتر من كده ..
              اول ما نزل ال V8 قالو عليه 286 حصان .. الناس قاسته لقيته +300 ..
              اول ما عملو ال 318 اي اس .. طلع اكتر من 160 حصان .. خنقووه علشان يطلع 135 حصان علشان سوق ال ام ثري مايقفش ...
                المشاركة الأصلية كتبت بواسطة Xpert مشاهدة المشاركة
                جوني باشا .... لو كدة ... فا موتور ال 316 الجديدة كام حصان فعلا .... ال gross
                و ال net كان كمان لو تعرف ..... عشان أنا نفسي أعرف أزاي قليلة كدة ؟؟؟
                    شكرا علي سرعة الرد
                      اي خدمه يا حج .. طبعاُ اللينك الاولاني للعربيه و التاني للمواتير ..
