If you please-if any one have e36manual
  • If you please-if any one have e36manual
    alsalmo alyko
    ya ragalet el bm lo 7ad 3ando elmanual le e36 at 1995 yb2a mashkorrn
    انا عربيتى 95 مانيوال
    تحت امرك
    [CENTER]وبحبك وانتى بتنقى .. أغانى قلبى يسمعها
    وأحبك لما بتعاندى .. فى حاجات الدنيا تمنعها
    :wink05:[/CENTER]
      Bentley_BMW_3-Series_Service_Manual_(e36).pdf
      [CENTER]الحمد لله[/CENTER]
      [CENTER] [/CENTER]
      [CENTER][sor2]http://farm3.static.flickr.com/2639/3939929853_4547d6e150.jpg[/sor2][/CENTER]
        rabna ya7"alik ya basha i have the same car but auto i want to know the fuel consumption inside the city
          alf alf shoker ya basha
            Depends on the road and your driving style and how much traffic you face and whether you have your A/C on or off and what's your engine's condition ( plugs, coils, efficiency,... )
            in my opinion you can't judge a car's fuel consumption in Cairo
            you have to take it to an open road to test it's consumption
            Mine does about 6 L/100 Km on the highway @ 100 km/h
            Around the city here in Alex i get around 10 L/100 Km
            This is combined with some hard driving and sometimes relaxed driving ( cruising @ alkurneish @ 60 km/h in 5th doing about 4 L/100 Km according to the guage below the RPM dial )
            those figures are from my car 1995 E36 316i with the later engine M43b16 and it has a manual box
            if you need any more info just let me know
            [CENTER] [/CENTER]
              Thanks a lot ya basha.
              but i astonished because i discussed this issue with the tech. manager in Bavarian and he told me that this car make from 12L to 16L per 100KM inside the city and 220:240KM in 20L outside the city
                المشاركة الأصلية كتبت بواسطة Ahmedabdelmawgoud مشاهدة المشاركة
                as i told you , you cannot judge a car's consumption in a very crowded traffic like Cairo
                As for the open roads i really don't think that it's only doing that range on 20L !!!!!!!!!!!!!! This is not even the consumption of a 328i
                With a 328i you should be getting 7.5 litre/100km on the highway which is about ~ 270 Kms for every 20 litres !
                And this is for a 6 cylinders 2800cc motor !
                Imagine if the 4 cylinder 1600cc motor is using more ...
                something must be wrong
                You can check the consumption of the 328i here
                328i mpg? - Bimmerforums - The Ultimate BMW Forum
                Here is a calculator to convert from MPG to l/100 km
                L/100 km to MPG or MPG to L/100 km Fuel / Gas Efficiency / Consumption Conversion Chart / Table (Miles per US gallon to liters per 100 kilometers )
                and i told you before that my car gets ~ 6 L/100 Km on the highway which is ~ 320+ Km for every 20 litre !
                But i repeat this is for the manual !!
                I don't know about the automatic !!!
                [CENTER] [/CENTER]
                  عن تجربة حد اعرفه كويس
                  استهلاك ال 320 ال 6 سلندر المانيوال اقل من 316 ال 4 سلندر الاوتوماتيك
                  بس بالبلدى كده
                  ممكن يكون السبب فى استهلاك البنزين ضعف السحب لسبب ما
                  يعنى بالعربى العربيه بتنعر عشان تمشى
                  يعنى سحبها اقل من صوتها
                  وده اسبابه كتير ممكن البوجيهات او الاسطوانه او الديسك مثلا
                  تابع صوت العربيه
                  :wink05:[/CENTER]
                    يا جماعة من كتلوج العربية عندى اكتشفت حاجة صدمتنى !!!!
                    الأستهلاك عند سرعة 90 كم/س الفرق ما بين المحركات لا يذكر تقريبا !!!!
                    ال 316 مانيوال 5,6 و اوتوماتيك 5,9
                    ال 318 مانيوال 5,7 و اوتوماتيك 6
                    ال 320 مانيوال 6,5 و اوتوماتيك 5,9
                    ال 325 مانيوال 6,6 و اوتوماتيك 6
                    و كذلك عند سرعة 120 كم/س
                    ال 316 مانيوال 7.3 و اوتوماتيك 7.5
                    ال 318 مانيوال 7.4 و اوتوماتيك 7.7
                    ال 320 مانيوال 7.9 و اوتوماتيك 7.3
                    ال 325 مانيوال 8 و اوتوماتيك 7.4
                    الكلام دة من الكتالوج عندى !!!!!!!!!!!!
                    دة على كدة ال 316 مش فارقة خالص عن ال 325 او ال 328 لو بتسوق بالراحة و طريقك سفر على طول !!!!!!!!!!!!!!!!!!!!!!!
                    [CENTER] [/CENTER]
