(اهداء) الجزء الرابع- الدليل الشامل لرموز أخطاء جميع فئات bmw ومعانيها
  • (اهداء) الجزء الرابع- الدليل الشامل لرموز أخطاء جميع فئات bmw ومعانيها
    الجزء الرابع :
    17110037 Radiator including module carrier Loose
    17110048 Radiator including module carrier Leaking
    17110072 Radiator including module carrier Poorly bled
    171100XX Radiator including module carrier
    17110114 Radiator cap Occasional malfunction
    17110115 Radiator cap Permanent malfunction
    17110123 Radiator cap Incorrect / not fitted
    17110148 Radiator cap Leaking
    171101XX Radiator cap
    17110237 Radiator compensating tank Loose
    17110248 Radiator compensating tank Leaking
    171102XX Radiator compensating tank
    17110401 Fan surround Cracked / broken / torn off
    17110437 Fan surround Loose
    17110439 Fan surround Unpleasant noises
    171104XX Fan surround
    17110759 Radiator coolant level Too low / deep / slight
    17110760 Radiator coolant level Too high
    171107XX Radiator coolant level
    17111112 Electric fan Permanent failure
    17111137 Electric fan Loose
    17111179 Electric fan incorrect connection /contact
    17111199 Electric fan Fault code stored in diagnosis fault code memory (no warning lamp)
    171111XX Electric fan
    17111214 Thermostat for oil-to-coolant heat exchanger (automatic transmission) Occasional malfunction
    17111215 Thermostat for oil-to-coolant heat exchanger (automatic transmission) Permanent malfunction
    17111279 Thermostat for oil-to-coolant heat exchanger (automatic transmission) incorrect connection /contact
    171112XX Thermostat for oil-to-coolant heat exchanger (automatic transmission)
    1711XXXX Radiator with mount
    17122001 Coolant hose, thin (inside diameter approx. 8 mm) Cracked / broken / torn off
    17122030 Coolant hose, thin (inside diameter approx. 8 mm) Blistering
    17122069 Coolant hose, thin (inside diameter approx. 8 mm) Worn / sheared through
    171220XX Coolant hose, thin (inside diameter approx. 8 mm)
    17122101 Coolant hose, medium (inside diameter approx. 16 mm) Cracked / broken / torn off
    17122130 Coolant hose, medium (inside diameter approx. 16 mm) Blistering
    17122169 Coolant hose, medium (inside diameter approx. 16 mm) Worn / sheared through
    171221XX Coolant hose, medium (inside diameter approx. 16 mm)
    17122201 Coolant hose, thick (inside diameter approx. 32 mm) Cracked / broken / torn off
    17122230 Coolant hose, thick (inside diameter approx. 32 mm) Blistering
    17122269 Coolant hose, thick (inside diameter approx. 32 mm) Worn / sheared through
    171222XX Coolant hose, thick (inside diameter approx. 32 mm)
    17122313 Quick-release coupling, coolant hose, thin (inside diameter approx. 8 mm) Broken
    17122337 Quick-release coupling, coolant hose, thin (inside diameter approx. 8 mm) Loose
    17122341 Quick-release coupling, coolant hose, thin (inside diameter approx. 8 mm) Poorly adapted/fitted
    171223XX Quick-release coupling, coolant hose, thin (inside diameter approx. 8 mm)
    17122413 Quick-release coupling, coolant hose, medium (inside diameter approx. 16 mm) Broken
    17122437 Quick-release coupling, coolant hose, medium (inside diameter approx. 16 mm) Loose
    17122441 Quick-release coupling, coolant hose, medium (inside diameter approx. 16 mm) Poorly adapted/fitted
    171224XX Quick-release coupling, coolant hose, medium (inside diameter approx. 16 mm)
    17122513 Quick-release coupling, coolant hose, thick (inside diameter approx. 32 mm) Broken
    17122537 Quick-release coupling, coolant hose, thick (inside diameter approx. 32 mm) Loose
    17122541 Quick-release coupling, coolant hose, thick (inside diameter approx. 32 mm) Poorly adapted/fitted
    171225XX Quick-release coupling, coolant hose, thick (inside diameter approx. 32 mm)
    17122613 Hose clip, coolant hose, thin (inside diameter approx. 8 mm) Broken
    17122637 Hose clip, coolant hose, thin (inside diameter approx. 8 mm) Loose
    17122641 Hose clip, coolant hose, thin (inside diameter approx. 8 mm) Poorly adapted/fitted
    171226XX Hose clip, coolant hose, thin (inside diameter approx. 8 mm)
    17122713 Hose clip, coolant hose, medium (inside diameter approx. 16 mm) Broken
    17122737 Hose clip, coolant hose, medium (inside diameter approx. 16 mm) Loose
    17122741 Hose clip, coolant hose, medium (inside diameter approx. 16 mm) Poorly adapted/fitted
    171227XX Hose clip, coolant hose, medium (inside diameter approx. 16 mm)
    17122813 Hose clip, coolant hose, thick (inside diameter approx. 32 mm) Broken
    17122837 Hose clip, coolant hose, thick (inside diameter approx. 32 mm) Loose
    17122841 Hose clip, coolant hose, thick (inside diameter approx. 32 mm) Poorly adapted/fitted
    171228XX Hose clip, coolant hose, thick (inside diameter approx. 32 mm)
    1712XXXX Coolant lines/coolant hoses
    17210039 Engine oil cooler Unpleasant noises
    17210048 Engine oil cooler Leaking
    172100XX Engine oil cooler
    17210148 Heat exchanger, automatic transmission fluid - coolant Leaking
    172101XX Heat exchanger, automatic transmission fluid - coolant
    17210539 Oil cooler for automatic transmission Unpleasant noises
    17210548 Oil cooler for automatic transmission Leaking
    172105XX Oil cooler for automatic transmission
    1721XXXX Oil cooler
    17220037 Engine oil cooler lines/connections, engine end Loose
    17220039 Engine oil cooler lines/connections, engine end Unpleasant noises
    17220048 Engine oil cooler lines/connections, engine end Leaking
    172200XX Engine oil cooler lines/connections, engine end
    17220137 Engine oil cooler lines/connections, oil cooler end Loose
    17220139 Engine oil cooler lines/connections, oil cooler end Unpleasant noises
    17220148 Engine oil cooler lines/connections, oil cooler end Leaking
    172201XX Engine oil cooler lines/connections, oil cooler end
    17221139 Oil cooler lines/hoses for transmission fluid, transmission side Unpleasant noises
    17221148 Oil cooler lines/hoses for transmission fluid, transmission side Leaking
    172211XX Oil cooler lines/hoses for transmission fluid, transmission side
    17221239 Oil cooler lines/hoses for transmission fluid on radiator side Unpleasant noises
    17221248 Oil cooler lines/hoses for transmission fluid on radiator side Leaking
    172212XX Oil cooler lines/hoses for transmission fluid on radiator side
    17229023 E53 M54 Retrofit autom. gearbox oil cooler lines with chafe guard (with independ. heating retrofit)
    1722XXXX Oil cooler lines
    17310112 Radiator shutter Permanent failure
    17310113 Radiator shutter Broken
    17310115 Radiator shutter Permanent malfunction
    173101XX Radiator shutter
    1731XXXX Radiator shutter
    17320112 Changeover valve, radiator shutter Permanent failure
    17320129 Changeover valve, radiator shutter Sticking/jammed
    17320179 Changeover valve, radiator shutter incorrect connection /contact
    17320184 Changeover valve, radiator shutter incorrect electrical resistance
    173201XX Changeover valve, radiator shutter
    17320248 Vacuum hose, radiator shutter Leaking
    17320276 Vacuum hose, radiator shutter dirty / blocked
    173202XX Vacuum hose, radiator shutter
    1732XXXX Radiator shutter actuation
    17510137 Charge air intercooler Loose
    17510148 Charge air intercooler Leaking
    17510176 Charge air intercooler dirty / blocked
    175101XX Charge air intercooler
    17510232 Charge air pipes/hoses Deformed / distorted / bent
    17510237 Charge air pipes/hoses Loose
    17510248 Charge air pipes/hoses Leaking
    17510276 Charge air pipes/hoses dirty / blocked
    175102XX Charge air pipes/hoses
    1751XXXX Charge air intercooler with mount
    17XXXXXX Cooling
    18110032 Exhaust system, general Deformed / distorted / bent
    18110039 Exhaust system, general Unpleasant noises
    181100XX Exhaust system, general
    18110101 Front exhaust pipe (jacket pipe) Cracked / broken / torn off
    18110137 Front exhaust pipe (jacket pipe) Loose
    18110148 Front exhaust pipe (jacket pipe) Leaking
    181101XX Front exhaust pipe (jacket pipe)
    18110248 Exhaust pipe flange gasket Leaking
    181102XX Exhaust pipe flange gasket
    18110501 Vibration absorber, exhaust pipe Cracked / broken / torn off
    18110537 Vibration absorber, exhaust pipe Loose
    181105XX Vibration absorber, exhaust pipe
    18110601 Intermediate pipe (between manifold and catalytic converter) Cracked / broken / torn off
    18110604 Intermediate pipe (between manifold and catalytic converter) Screw connection torn
    18110637 Intermediate pipe (between manifold and catalytic converter) Loose
    18110639 Intermediate pipe (between manifold and catalytic converter) Unpleasant noises
    18110648 Intermediate pipe (between manifold and catalytic converter) Leaking
    181106XX Intermediate pipe (between manifold and catalytic converter)
    1811XXXX Exhaust line
    18120001 Front silencer Cracked / broken / torn off
    18120039 Front silencer Unpleasant noises
    18120048 Front silencer Leaking
    18120075 Front silencer corroded
    181200XX Front silencer
    18120101 End silencer (with tailpipes) Cracked / broken / torn off
    18120139 End silencer (with tailpipes) Unpleasant noises
    18120148 End silencer (with tailpipes) Leaking
    18120175 End silencer (with tailpipes) corroded
    181201XX End silencer (with tailpipes)
    18120201 Intermediate silencer Cracked / broken / torn off
    18120239 Intermediate silencer Unpleasant noises
    18120248 Intermediate silencer Leaking
    18120275 Intermediate silencer corroded
    181202XX Intermediate silencer
    18120339 Rear silencer, exhaust flap Unpleasant noises
    18120383 Rear silencer, exhaust flap incorrect or no switching action
    181203XX Rear silencer, exhaust flap
    1812XXXX Silencer
    18210001 Front exhaust mount (bracket) Cracked / broken / torn off
    18210037 Front exhaust mount (bracket) Loose
    182100XX Front exhaust mount (bracket)
    18210101 Rear exhaust mount (bracket) Cracked / broken / torn off
    18210137 Rear exhaust mount (bracket) Loose
    182101XX Rear exhaust mount (bracket)
    18210401 Centre exhaust mount (bracket) Cracked / broken / torn off
    18210437 Centre exhaust mount (bracket) Loose
    182104XX Centre exhaust mount (bracket)
    18210501 Front exhaust mount, rubber element Cracked / broken / torn off
    18210537 Front exhaust mount, rubber element Loose
    182105XX Front exhaust mount, rubber element
    18210601 Centre exhaust mount, rubber element Cracked / broken / torn off
    18210637 Centre exhaust mount, rubber element Loose
    182106XX Centre exhaust mount, rubber element
    18210701 Rear exhaust mount, rubber element Cracked / broken / torn off
    18210737 Rear exhaust mount, rubber element Loose
    182107XX Rear exhaust mount, rubber element
    1821XXXX Exhaust mounting components
    18320101 (Main) catalytic converter Cracked / broken / torn off
    18320114 (Main) catalytic converter Occasional malfunction
    18320115 (Main) catalytic converter Permanent malfunction
    18320139 (Main) catalytic converter Unpleasant noises
    18320148 (Main) catalytic converter Leaking
    18320196 (Main) catalytic converter Fault code in diagnosis memory (warn. lamp on)
    18320199 (Main) catalytic converter Fault code stored in diagnosis fault code memory (no warning lamp)
    183201XX (Main) catalytic converter
    18320201 Primary catalytic converter Cracked / broken / torn off
    18320214 Primary catalytic converter Occasional malfunction
    18320215 Primary catalytic converter Permanent malfunction
    18320239 Primary catalytic converter Unpleasant noises
    18320248 Primary catalytic converter Leaking
    18320296 Primary catalytic converter Fault code in diagnosis memory (warn. lamp on)
    18320299 Primary catalytic converter Fault code stored in diagnosis fault code memory (no warning lamp)
    183202XX Primary catalytic converter
    1832XXXX Catalytic converter with mount
    18XXXXXX Exhaust system
    21210052 Complete clutch Not opening
    21210055 Complete clutch Stick-slip
    21210058 Complete clutch Slipping
    212100XX Complete clutch
    21210113 Complete clutch disc Broken
    21210121 Complete clutch disc Worn
    212101XX Complete clutch disc
    21210339 Dual mass flywheel (ZMS) Unpleasant noises
    21210348 Dual mass flywheel (ZMS) Leaking
    212103XX Dual mass flywheel (ZMS)
    21210413 Clutch pressure plate Broken
    212104XX Clutch pressure plate
    21219039 E36/7 E39 E46 E52 E53 Cracking sound during clutch operation
    2121XXXX Clutch with drive plate
    21510013 Clutch release Broken
    21510025 Clutch release Rough running
    21510039 Clutch release Unpleasant noises
    215100XX Clutch release
    21510134 Clutch release lever Stiff to move
    215101XX Clutch release lever
    2151XXXX Clutch release mechanism with lever
    21520115 Clutch master cylinder Permanent malfunction
    21520139 Clutch master cylinder Unpleasant noises
    21520148 Clutch master cylinder Leaking
    215201XX Clutch master cylinder
    21520215 Clutch slave cylinder Permanent malfunction
    21520239 Clutch slave cylinder Unpleasant noises
    21520248 Clutch slave cylinder Leaking
    215202XX Clutch slave cylinder
    21520348 Clutch pipes and hoses Leaking
    215203XX Clutch pipes and hoses
    2152XXXX Clutch actuation (hydraulics)
    21549053 E46 S54 Vehicle - no clutch engagement
    21XXXXXX Clutch
    22110001 Engine mounting bracket Cracked / broken / torn off
    22110037 Engine mounting bracket Loose
    221100XX Engine mounting bracket
    22110101 Rubber mounts, hydraulic bearings, damping-controlled hydraulic bearing (DSHL) Cracked / broken / to
    22110137 Rubber mounts, hydraulic bearings, damping-controlled hydraulic bearing (DSHL) Loose
    22110139 Rubber mounts, hydraulic bearings, damping-controlled hydraulic bearing (DSHL) Unpleasant noises
    22110148 Rubber mounts, hydraulic bearings, damping-controlled hydraulic bearing (DSHL) Leaking
    221101XX Rubber mounts, hydraulic bearings, damping-controlled hydraulic bearing (DSHL)
    22110283 DSHL bearing incorrect or no switching action
    221102XX DSHL bearing
    22110401 DSHL vacuum hoses / lines / hose connection Cracked / broken / torn off
    22110437 DSHL vacuum hoses / lines / hose connection Loose
    22110448 DSHL vacuum hoses / lines / hose connection Leaking
    22110476 DSHL vacuum hoses / lines / hose connection dirty / blocked
    221104XX DSHL vacuum hoses / lines / hose connection
    22110583 DSHL electric changeover valve incorrect or no switching action
    22110584 DSHL electric changeover valve incorrect electrical resistance
    221105XX DSHL electric changeover valve
    22110601 Heat baffle plate for engine mount Cracked / broken / torn off
    22110637 Heat baffle plate for engine mount Loose
    22110639 Heat baffle plate for engine mount Unpleasant noises
    221106XX Heat baffle plate for engine mount
    22110701 Stop pad, engine Cracked / broken / torn off
    22110737 Stop pad, engine Loose
    22110739 Stop pad, engine Unpleasant noises
    221107XX Stop pad, engine
    22110801 Heat shield for engine mounting bracket Cracked / broken / torn off
    22110837 Heat shield for engine mounting bracket Loose
    22110839 Heat shield for engine mounting bracket Unpleasant noises
    221108XX Heat shield for engine mounting bracket
    22110901 Engine mounting bracket Cracked / broken / torn off
    22110937 Engine mounting bracket Loose
    221109XX Engine mounting bracket
    22111001 Engine - stabilizer link, top (engine mounting bracket / stabilizer link mount) Cracked / broken / t
    22111037 Engine - stabilizer link, top (engine mounting bracket / stabilizer link mount) Loose
    22111039 Engine - stabilizer link, top (engine mounting bracket / stabilizer link mount) Unpleasant noises
    221110XX Engine - stabilizer link, top (engine mounting bracket / stabilizer link mount)
    22111101 Engine - stabilizer link, bottom (front axle carrier / stabilizer link bracket) Cracked / broken / t
    22111137 Engine - stabilizer link, bottom (front axle carrier / stabilizer link bracket) Loose
    22111139 Engine - stabilizer link, bottom (front axle carrier / stabilizer link bracket) Unpleasant noises
    221111XX Engine - stabilizer link, bottom (front axle carrier / stabilizer link bracket)
    22111201 Bracket for engine - stabilizer link, bottom (engine / stabilizer link, bottom) Cracked / broken / t
    22111237 Bracket for engine - stabilizer link, bottom (engine / stabilizer link, bottom) Loose
    221112XX Bracket for engine - stabilizer link, bottom (engine / stabilizer link, bottom)
    22111301 Mount for engine - stabilizer link, top (body / stabilizer link, top) Cracked / broken / torn off
    22111337 Mount for engine - stabilizer link, top (body / stabilizer link, top) Loose
    22111339 Mount for engine - stabilizer link, top (body / stabilizer link, top) Unpleasant noises
    221113XX Mount for engine - stabilizer link, top (body / stabilizer link, top)
    2211XXXX Engine mount
    22310001 Manual transmission mount, cross member Cracked / broken / torn off
    22310037 Manual transmission mount, cross member Loose
    223100XX Manual transmission mount, cross member
    22310101 Manual transmission mount, rubber/hydraulic mount Cracked / broken / torn off
    22310137 Manual transmission mount, rubber/hydraulic mount Loose
    22310139 Manual transmission mount, rubber/hydraulic mount Unpleasant noises
    22310148 Manual transmission mount, rubber/hydraulic mount Leaking
    223101XX Manual transmission mount, rubber/hydraulic mount
    22310201 Vibration absorber (manual transmission) Cracked / broken / torn off
    22310237 Vibration absorber (manual transmission) Loose
    22310239 Vibration absorber (manual transmission) Unpleasant noises
    223102XX Vibration absorber (manual transmission)
    22310301 Manual gearbox mounting, gearbox mounting bracket Cracked / broken / torn off
    22310337 Manual gearbox mounting, gearbox mounting bracket Loose
    223103XX Manual gearbox mounting, gearbox mounting bracket
    22310401 Stop pad, manual gearbox Cracked / broken / torn off
    22310437 Stop pad, manual gearbox Loose
    22310439 Stop pad, manual gearbox Unpleasant noises
    223104XX Stop pad, manual gearbox
    2231XXXX Transmission mount, manual transmission
    22320001 Automatic transmission mount, cross member Cracked / broken / torn off
    22320037 Automatic transmission mount, cross member Loose
    223200XX Automatic transmission mount, cross member
    22320101 Automatic transmission mount, rubber/hydraulic mount Cracked / broken / torn off
    22320137 Automatic transmission mount, rubber/hydraulic mount Loose
    22320139 Automatic transmission mount, rubber/hydraulic mount Unpleasant noises
    22320148 Automatic transmission mount, rubber/hydraulic mount Leaking
    223201XX Automatic transmission mount, rubber/hydraulic mount
    22320201 Vibration absorber (automatic transmission) Cracked / broken / torn off
    22320237 Vibration absorber (automatic transmission) Loose
    223202XX Vibration absorber (automatic transmission)
    22320301 Heat shield for transmission cross member Cracked / broken / torn off
    22320337 Heat shield for transmission cross member Loose
    22320339 Heat shield for transmission cross member Unpleasant noises
    223203XX Heat shield for transmission cross member
    22320401 Stop pad, automatic gearbox Cracked / broken / torn off
    22320439 Stop pad, automatic gearbox Unpleasant noises
    223204XX Stop pad, automatic gearbox
    22320501 Automatic gearbox mounting, gearbox mounting bracket Cracked / broken / torn off
    22320537 Automatic gearbox mounting, gearbox mounting bracket Loose
    223205XX Automatic gearbox mounting, gearbox mounting bracket
    22329039 E38/730iA Transmission cross member
    2232XXXX Transmission mount, automatic transmission
    22XXXXXX Engine and transmission mounts
    23000039 Manual transmission in neutral position Unpleasant noises
    230000XX Manual transmission in neutral position
    23000108 Manual transmission in 1st gear Jumps out
    23000134 Manual transmission in 1st gear Stiff to move
    23000139 Manual transmission in 1st gear Unpleasant noises
    23000188 Manual transmission in 1st gear failing to synchronize
    230001XX Manual transmission in 1st gear
    23000208 Manual transmission in 2nd gear Jumps out
    23000234 Manual transmission in 2nd gear Stiff to move
    23000239 Manual transmission in 2nd gear Unpleasant noises
    23000288 Manual transmission in 2nd gear failing to synchronize
    230002XX Manual transmission in 2nd gear
    23000308 Manual transmission in 3rd gear Jumps out
    23000334 Manual transmission in 3rd gear Stiff to move
    23000339 Manual transmission in 3rd gear Unpleasant noises
    23000388 Manual transmission in 3rd gear failing to synchronize
    230003XX Manual transmission in 3rd gear
    23000408 Manual transmission in 4th gear Jumps out
    23000434 Manual transmission in 4th gear Stiff to move
    23000439 Manual transmission in 4th gear Unpleasant noises
    23000488 Manual transmission in 4th gear failing to synchronize
    230004XX Manual transmission in 4th gear
    23000508 Manual transmission in 5th gear Jumps out
    23000534 Manual transmission in 5th gear Stiff to move
    23000539 Manual transmission in 5th gear Unpleasant noises
    23000588 Manual transmission in 5th gear failing to synchronize
    230005XX Manual transmission in 5th gear
    23000608 Manual transmission in reverse Jumps out
    23000634 Manual transmission in reverse Stiff to move
    23000639 Manual transmission in reverse Unpleasant noises
    23000688 Manual transmission in reverse failing to synchronize
    230006XX Manual transmission in reverse
    23000808 Manual transmission in 6th gear Jumps out
    23000834 Manual transmission in 6th gear Stiff to move
    23000839 Manual transmission in 6th gear Unpleasant noises
    23000888 Manual transmission in 6th gear failing to synchronize
    230008XX Manual transmission in 6th gear
    23005039 Sequential M-transmission (SMG) upshift characteristics Unpleasant noises
    23005061 Sequential M-transmission (SMG) upshift characteristics Too rough
    23005083 Sequential M-transmission (SMG) upshift characteristics incorrect or no switching action
    230050XX Sequential M-transmission (SMG) upshift characteristics
    23005139 SMG downshift characteristics Unpleasant noises
    23005161 SMG downshift characteristics Too rough
    23005183 SMG downshift characteristics incorrect or no switching action
    230051XX SMG downshift characteristics
    23005227 SMG gear engagement (from 0) Locked/jammed
    23005239 SMG gear engagement (from 0) Unpleasant noises
    23005261 SMG gear engagement (from 0) Too rough
    230052XX SMG gear engagement (from 0)
    23005360 SMG cut-in delay (from 0) Too high
    230053XX SMG cut-in delay (from 0)
    23005583 SMG emergency mode program incorrect or no switching action
    230055XX SMG emergency mode program
    23005666 SMG forward power transmission No effect
    230056XX SMG forward power transmission
    23005766 SMG reverse power transmission No effect
    230057XX SMG reverse power transmission
    23005814 SMG shifting in neutral position Occasional malfunction
    230058XX SMG shifting in neutral position
    23005952 SMG clutch Not opening
    230059XX SMG clutch
    23009134 E39 M62 S62 D-transmission 3rd gear difficult to disengage
    23009334 E39 E46 M47/TU M57 Gearbox (F-gearbox) - difficulty in shifting
    23009434 E36/7 E38 E39 E46 E53 C-gearbox - difficulty in shifting
    2300XXXX Manual gearbox (symptom defect codes)
    23110048 Manual transmission assy Leaking
    231100XX Manual transmission assy
    23110148 Gearbox cover (MINI) Leaking
    231101XX Gearbox cover (MINI)
    23110354 Guide sleeve with flange Scratches, score marks
    231103XX Guide sleeve with flange
    23110648 Manual transmission drain plug Leaking
    231106XX Manual transmission drain plug
    23110848 Breather manual transmission casing Leaking
    231108XX Breather manual transmission casing
    23110948 Manual transmission casing parting joint Leaking
    231109XX Manual transmission casing parting joint
    23111048 Manual transmission rotary shaft seal, clutch end Leaking
    231110XX Manual transmission rotary shaft seal, clutch end
    23111148 Manual transmission rotary shaft seal, output flange Leaking
    231111XX Manual transmission rotary shaft seal, output flange
    23111248 Manual transmission rotary shaft seal, selector shaft Leaking
    231112XX Manual transmission rotary shaft seal, selector shaft
    2311XXXX Housing with cover
    23140014 Reversing light switch Occasional malfunction
    23140015 Reversing light switch Permanent malfunction
    23140048 Reversing light switch Leaking
    231400XX Reversing light switch
    2314XXXX Electrical attachments
    23211337 Output flange Loose
    232113XX Output flange
    2321XXXX Transmission shafts
    23XXXXXX Manual transmission
    24000048 Automatic transmission, complete Leaking
    240000XX Automatic transmission, complete
    24000139 Automatic transmission, forward gears, vehicle in motion Unpleasant noises
    240001XX Automatic transmission, forward gears, vehicle in motion
    24000639 Automatic transmission, reverse gear, vehicle in motion Unpleasant noises
    240006XX Automatic transmission, reverse gear, vehicle in motion
    24000739 Automatic transmission, forward gears, vehicle stationary Unpleasant noises
    240007XX Automatic transmission, forward gears, vehicle stationary
    24000839 Automatic transmission, reverse gear, vehicle stationary Unpleasant noises
    240008XX Automatic transmission, reverse gear, vehicle stationary
    24001739 Automatic transmission shift characteristics, upshifts Unpleasant noises
    24001758 Automatic transmission shift characteristics, upshifts Slipping
    24001761 Automatic transmission shift characteristics, upshifts Too rough
    240017XX Automatic transmission shift characteristics, upshifts
    24001839 Automatic transmission shift characteristics, downshifts Unpleasant noises
    24001858 Automatic transmission shift characteristics, downshifts Slipping
    24001861 Automatic transmission shift characteristics, downshifts Too rough
    240018XX Automatic transmission shift characteristics, downshifts
    24001939 Automatic transmission, selecting gear (from N or P) Unpleasant noises
    24001961 Automatic transmission, selecting gear (from N or P) Too rough
    240019XX Automatic transmission, selecting gear (from N or P)
    24002060 Automatic transmission engagement delay (from N or P) Too high
    240020XX Automatic transmission engagement delay (from N or P)
    24002159 Automatic transmission shift frequency Too low / deep / slight
    24002160 Automatic transmission shift frequency Too high
    240021XX Automatic transmission shift frequency
    24002239 Automatic transmission in normal/park setting (N/P) Unpleasant noises
    240022XX Automatic transmission in normal/park setting (N/P)
    24002383 Automatic transmission in emergency shift program incorrect or no switching action
    240023XX Automatic transmission in emergency shift program
    24002466 Automatic transmission, power transmission forward No effect
    240024XX Automatic transmission, power transmission forward
    24002566 Automatic transmission, power transmission back No effect
    240025XX Automatic transmission, power transmission back
    24002738 Start-off gearshift, automatic transmission Shaking
    24002761 Start-off gearshift, automatic transmission Too rough
    240027XX Start-off gearshift, automatic transmission
    24009058 E36 E39 M44 M52 Fault code 111 (check engine lights or clutch slips)
    24009061 E36 M52 B20 (Jatco transmission) harsh 1st-2nd gearshift during warm-up phase
    24009111 E36 E39 E46 E53 M52 M54 (GM5) Position switch, fault code 60
    24009161 E38 E39 M62 M57 Poor gearshift comfort (3rd - 2nd gearshift)
    24009261 E36/7 E39 E46 E53 M54 M57 (GM5) Gearshift comfort
    24009279 E38 E39 E53 M62 Automatic transmission fault code 34
    24009396 E39 E46 M52 (GM5) Solenoid valve, converter lock-up clutch (fault code 48)
    24009414 E38 E39 M57 M62 (5HP24) Harsh 3rd-4th/4th-3rd gearshift - emergency program
    24009548 E38 E39 E53 M62 Leak at threaded connection of converter housing
    24009839 E36/7 (with A4S 310R) Gearing/whistling noise
    2400XXXX Automatic gearbox / ECVT (symptom defect codes)
    24100014 Gearbox position switch Occasional malfunction
    24100015 Gearbox position switch Permanent malfunction
    241000XX Gearbox position switch
    2410XXXX Gearbox casing with add-on parts
    24309012 E36/7 E39 E46 E53 (GM5) No or harsh gearshift (control unit fault)
    24339048 E36 E39 Sealing cap working piston leaking
    24400261 Automatic transmission, converter clutch engagement (closing/opening) Too rough
    244002XX Automatic transmission, converter clutch engagement (closing/opening)
    24409057 E39 E46 M57 A Vibrations in speed range of 100 to 130 km/h
    2440XXXX Torque converter
    24530165 Automatic transmission parking lock Does not lock into position
    245301XX Automatic transmission parking lock
    24530252 Automatic gearbox parking lock - emergency release Not opening
    24530253 Automatic gearbox parking lock - emergency release Not closing
    245302XX Automatic gearbox parking lock - emergency release
    2453XXXX Parking lock
    24609161 E53 M54 (GM5) Poor gearshift quality (2nd - 3rd)
    24619083 E39 E46 E53 M54 US GM5 - No 1st - 2nd upshift after uphill driving
    :F_eyeb1[1]: Yassooooo
