الجزء السابع :
51110036 Front bumper assy Dented/wavy
51110037 Front bumper assy Loose
51110041 Front bumper assy Poorly adapted/fitted
511100XX Front bumper assy
51110601 Front bumper guards Cracked / broken / torn off
51110637 Front bumper guards Loose
51110641 Front bumper guards Poorly adapted/fitted
511106XX Front bumper guards
51110841 Front bumper seal Poorly adapted/fitted
511108XX Front bumper seal
51111566 Front bumper impact absorber No effect
511115XX Front bumper impact absorber
51111637 Front bumper covers Loose
51111668 Front bumper covers Peels off / detaches itself
511116XX Front bumper covers
51111737 Licence plate support pad Loose
51111741 Licence plate support pad Poorly adapted/fitted
511117XX Licence plate support pad
5111XXXX Front bumper
51120036 Rear bumper assy Dented/wavy
51120037 Rear bumper assy Loose
51120039 Rear bumper assy Unpleasant noises
51120041 Rear bumper assy Poorly adapted/fitted
511200XX Rear bumper assy
51120601 Rear bumper guards Cracked / broken / torn off
51120637 Rear bumper guards Loose
51120641 Rear bumper guards Poorly adapted/fitted
511206XX Rear bumper guards
51120841 Rear bumper seal Poorly adapted/fitted
511208XX Rear bumper seal
51120939 Rear bumper, absorber weight Unpleasant noises
511209XX Rear bumper, absorber weight
51121037 Rear bumper diffuser Loose
511210XX Rear bumper diffuser
51121137 Tail light cover Loose
51121140 Tail light cover Poorly adjusted / outside tolerance
511211XX Tail light cover
51121566 Rear bumper impact absorber No effect
511215XX Rear bumper impact absorber
51121637 Rear bumper covers Loose
51121668 Rear bumper covers Peels off / detaches itself
511216XX Rear bumper covers
51121701 Rear apron Cracked / broken / torn off
51121732 Rear apron Deformed / distorted / bent
51121737 Rear apron Loose
51121741 Rear apron Poorly adapted/fitted
511217XX Rear apron
51121841 Rear bumper licence plate holder Poorly adapted/fitted
511218XX Rear bumper licence plate holder
5112XXXX Rear bumper
51130001 Front or****ntal grille, centre Cracked / broken / torn off
51130037 Front or****ntal grille, centre Loose
51130078 Front or****ntal grille, centre poor surface finish
511300XX Front or****ntal grille, centre
51130301 Air entry and heater grille Cracked / broken / torn off
51130337 Air entry and heater grille Loose
511303XX Air entry and heater grille
51130737 Air outlet grill, roof pillars/air outlet cover trim Loose
51130741 Air outlet grill, roof pillars/air outlet cover trim Poorly adapted/fitted
511307XX Air outlet grill, roof pillars/air outlet cover trim
51131037 Rain channel / roof trim strip Loose
51131041 Rain channel / roof trim strip Poorly adapted/fitted
51131075 Rain channel / roof trim strip corroded
511310XX Rain channel / roof trim strip
51131137 Door sill cover trim Loose
51131168 Door sill cover trim Peels off / detaches itself
511311XX Door sill cover trim
51131230 Door pillar cover/film (outer B-pillar) Blistering
51131237 Door pillar cover/film (outer B-pillar) Loose
51131268 Door pillar cover/film (outer B-pillar) Peels off / detaches itself
511312XX Door pillar cover/film (outer B-pillar)
51131936 Trim strip with roof rack mounting Dented/wavy
51131937 Trim strip with roof rack mounting Loose
511319XX Trim strip with roof rack mounting
51132132 Body mouldings, side panel/door Deformed / distorted / bent
51132141 Body mouldings, side panel/door Poorly adapted/fitted
51132175 Body mouldings, side panel/door corroded
511321XX Body mouldings, side panel/door
51132401 Cap, left/right (convertible) Cracked / broken / torn off
51132432 Cap, left/right (convertible) Deformed / distorted / bent
51132437 Cap, left/right (convertible) Loose
511324XX Cap, left/right (convertible)
51132532 Soft-top cover flap trim strip (convertible) Deformed / distorted / bent
51132537 Soft-top cover flap trim strip (convertible) Loose
511325XX Soft-top cover flap trim strip (convertible)
51132632 Roof railing Deformed / distorted / bent
51132637 Roof railing Loose
51132641 Roof railing Poorly adapted/fitted
51132654 Roof railing Scratches, score marks
51132668 Roof railing Peels off / detaches itself
51132675 Roof railing corroded
511326XX Roof railing
51132737 C-pillar outer finisher (Z3 Coupe / MINI) Loose
51132740 C-pillar outer finisher (Z3 Coupe / MINI) Poorly adjusted / outside tolerance
511327XX C-pillar outer finisher (Z3 Coupe / MINI)
51132837 Outer finisher, A-pillar (MINI) Loose
51132840 Outer finisher, A-pillar (MINI) Poorly adjusted / outside tolerance
511328XX Outer finisher, A-pillar (MINI)
51132901 Bonnet trim strip Cracked / broken / torn off
51132937 Bonnet trim strip Loose
51132941 Bonnet trim strip Poorly adapted/fitted
51132975 Bonnet trim strip corroded
511329XX Bonnet trim strip
51133337 Cover on headlight housing Loose
51133341 Cover on headlight housing Poorly adapted/fitted
511333XX Cover on headlight housing
51133437 Grille/air inlet, side panel Loose
51133478 Grille/air inlet, side panel poor surface finish
511334XX Grille/air inlet, side panel
51133511 Spirit of Ecstasy incl. drive unit Occasional failure
51133512 Spirit of Ecstasy incl. drive unit Permanent failure
51133537 Spirit of Ecstasy incl. drive unit Loose
51133539 Spirit of Ecstasy incl. drive unit Unpleasant noises
51133578 Spirit of Ecstasy incl. drive unit poor surface finish
511335XX Spirit of Ecstasy incl. drive unit
5113XXXX External finishers
51140037 Badges (BMW / MINI) Loose
51140068 Badges (BMW / MINI) Peels off / detaches itself
511400XX Badges (BMW / MINI)
51140137 **** plate (BMW / MINI) Loose
51140178 **** plate (BMW / MINI) poor surface finish
511401XX **** plate (BMW / MINI)
51140323 Sticker, paintwork Incorrect / not fitted
511403XX Sticker, paintwork
51140422 Sticker, tyre pressures Manufacturing fault
51140423 Sticker, tyre pressures Incorrect / not fitted
511404XX Sticker, tyre pressures
51140523 Sticker, other information Incorrect / not fitted
511405XX Sticker, other information
5114XXXX Labels, emblems, instruction plates, adhesive film
51160013 Rear view mirror housing, outside Broken
51160037 Rear view mirror housing, outside Loose
51160039 Rear view mirror housing, outside Unpleasant noises
51160041 Rear view mirror housing, outside Poorly adapted/fitted
511600XX Rear view mirror housing, outside
51160213 Inside mirror Broken
51160215 Inside mirror Permanent malfunction
51160233 Inside mirror Optical distortion
51160237 Inside mirror Loose
511602XX Inside mirror
51160303 Sun visors (incl. mirror cover) Ripped
51160334 Sun visors (incl. mirror cover) Stiff to move
51160336 Sun visors (incl. mirror cover) Dented/wavy
51160337 Sun visors (incl. mirror cover) Loose
51160339 Sun visors (incl. mirror cover) Unpleasant noises
51160367 Sun visors (incl. mirror cover) Discoloured
511603XX Sun visors (incl. mirror cover)
51160513 Front ashtray Broken
51160529 Front ashtray Sticking/jammed
51160541 Front ashtray Poorly adapted/fitted
511605XX Front ashtray
51160613 Rear ashtray Broken
51160641 Rear ashtray Poorly adapted/fitted
511606XX Rear ashtray
51160701 Oddments tray on transmission tunnel Cracked / broken / torn off
51160730 Oddments tray on transmission tunnel Blistering
51160737 Oddments tray on transmission tunnel Loose
51160741 Oddments tray on transmission tunnel Poorly adapted/fitted
511607XX Oddments tray on transmission tunnel
51160841 Finisher, shift lever cover Poorly adapted/fitted
51160878 Finisher, shift lever cover poor surface finish
511608XX Finisher, shift lever cover
51160929 Glovebox, front passenger's side Sticking/jammed
51160937 Glovebox, front passenger's side Loose
51160941 Glovebox, front passenger's side Poorly adapted/fitted
51160965 Glovebox, front passenger's side Does not lock into position
511609XX Glovebox, front passenger's side
51161029 Glovebox, driver's side Sticking/jammed
51161037 Glovebox, driver's side Loose
51161041 Glovebox, driver's side Poorly adapted/fitted
51161065 Glovebox, driver's side Does not lock into position
511610XX Glovebox, driver's side
51161101 Grab handles Cracked / broken / torn off
51161137 Grab handles Loose
51161178 Grab handles poor surface finish
511611XX Grab handles
51161410 Oddments tray, back door Fallen out
51161429 Oddments tray, back door Sticking/jammed
51161465 Oddments tray, back door Does not lock into position
511614XX Oddments tray, back door
51161710 Outside mirror glass Fallen out
51161733 Outside mirror glass Optical distortion
51161757 Outside mirror glass Vibration / oscillation
51161767 Outside mirror glass Discoloured
511617XX Outside mirror glass
51161866 Outside mirror heating No effect
511618XX Outside mirror heating
51162012 Mirror auto-dip photocell Permanent failure
511620XX Mirror auto-dip photocell
51162107 Vanity mirror in sun visor Cracked
51162133 Vanity mirror in sun visor Optical distortion
511621XX Vanity mirror in sun visor
51162301 Glovebox retaining strap, passenger's side, lower Cracked / broken / torn off
511623XX Glovebox retaining strap, passenger's side, lower
51162539 Gas pressurized spring for glovebox, passenger's side, lower Unpleasant noises
51162566 Gas pressurized spring for glovebox, passenger's side, lower No effect
511625XX Gas pressurized spring for glovebox, passenger's side, lower
51162929 Coin box Sticking/jammed
51162934 Coin box Stiff to move
51162937 Coin box Loose
511629XX Coin box
51163010 Oddments tray, front door Fallen out
51163029 Oddments tray, front door Sticking/jammed
51163065 Oddments tray, front door Does not lock into position
511630XX Oddments tray, front door
51163122 Hinged tray, front centre armrest Manufacturing fault
51163129 Hinged tray, front centre armrest Sticking/jammed
51163134 Hinged tray, front centre armrest Stiff to move
51163137 Hinged tray, front centre armrest Loose
51163141 Hinged tray, front centre armrest Poorly adapted/fitted
51163186 Hinged tray, front centre armrest does not light up
511631XX Hinged tray, front centre armrest
51163239 Oddments box, rear (roadster) Unpleasant noises
51163252 Oddments box, rear (roadster) Not opening
51163253 Oddments box, rear (roadster) Not closing
51163265 Oddments box, rear (roadster) Does not lock into position
511632XX Oddments box, rear (roadster)
51163313 Drink holder, front Broken
51163337 Drink holder, front Loose
51163365 Drink holder, front Does not lock into position
511633XX Drink holder, front
51163413 Drink holder, rear Broken
51163437 Drink holder, rear Loose
51163465 Drink holder, rear Does not lock into position
511634XX Drink holder, rear
51163513 Coat hook in headlining Broken
51163565 Coat hook in headlining Does not lock into position
511635XX Coat hook in headlining
51163613 Oddments compartment in centre console Broken
51163652 Oddments compartment in centre console Not opening
51163653 Oddments compartment in centre console Not closing
511636XX Oddments compartment in centre console
51163737 Adhesive joint, inside rear view mirror **** Loose
511637XX Adhesive joint, inside rear view mirror ****
51163837 Easy entry module - light in outside mirror Loose
51163886 Easy entry module - light in outside mirror does not light up
511638XX Easy entry module - light in outside mirror
51163907 Vanity mirror in headlining (rear compartment) Cracked
51163933 Vanity mirror in headlining (rear compartment) Optical distortion
51163952 Vanity mirror in headlining (rear compartment) Not opening
51163965 Vanity mirror in headlining (rear compartment) Does not lock into position
511639XX Vanity mirror in headlining (rear compartment)
51164052 Lock (lockable) centre armrest hinged box, front Not opening
51164053 Lock (lockable) centre armrest hinged box, front Not closing
511640XX Lock (lockable) centre armrest hinged box, front
51164113 Hook for roller sun blind, rear door window Broken
511641XX Hook for roller sun blind, rear door window
51164237 Interior strip / centre armrest finisher, front Loose
51164254 Interior strip / centre armrest finisher, front Scratches, score marks
51164291 Interior strip / centre armrest finisher, front colour differences
511642XX Interior strip / centre armrest finisher, front
51164313 Stowage compartment, headliner (incl. glasses compartment) Broken
51164352 Stowage compartment, headliner (incl. glasses compartment) Not opening
51164353 Stowage compartment, headliner (incl. glasses compartment) Not closing
511643XX Stowage compartment, headliner (incl. glasses compartment)
51169423 E46 S54 US Retrofit interior rear-view mirror with DWA LED (DWA retrofit)
5116XXXX Mirrors, finishers, ashtrays, oddments trays
51170137 Headlight cover flap Loose
51170175 Headlight cover flap corroded
511701XX Headlight cover flap
51179061 E46/C Convertible top positioned on convertible top compartment lid (rubber buffer)
5117XXXX Flaps / lids
51180037 Licence plate carrier Loose
511800XX Licence plate carrier
5118XXXX Various mounting components
51210029 Rotary latch lock, front Sticking/jammed
51210034 Rotary latch lock, front Stiff to move
51210037 Rotary latch lock, front Loose
51210039 Rotary latch lock, front Unpleasant noises
51210065 Rotary latch lock, front Does not lock into position
512100XX Rotary latch lock, front
51210137 Front door lock striker Loose
51210139 Front door lock striker Unpleasant noises
51210141 Front door lock striker Poorly adapted/fitted
512101XX Front door lock striker
51210210 Door lock barrel Fallen out
51210229 Door lock barrel Sticking/jammed
51210234 Door lock barrel Stiff to move
51210237 Door lock barrel Loose
512102XX Door lock barrel
51210313 Inner door opener with operating assembly, front Broken
51210334 Inner door opener with operating assembly, front Stiff to move
51210337 Inner door opener with operating assembly, front Loose
51210339 Inner door opener with operating assembly, front Unpleasant noises
51210341 Inner door opener with operating assembly, front Poorly adapted/fitted
51210368 Inner door opener with operating assembly, front Peels off / detaches itself
512103XX Inner door opener with operating assembly, front
51210413 Locking button with linkage/bowden cable front Broken
51210434 Locking button with linkage/bowden cable front Stiff to move
51210437 Locking button with linkage/bowden cable front Loose
512104XX Locking button with linkage/bowden cable front
51210513 Outer door handles, front Broken
51210534 Outer door handles, front Stiff to move
51210537 Outer door handles, front Loose
51210539 Outer door handles, front Unpleasant noises
51210575 Outer door handles, front corroded
51210578 Outer door handles, front poor surface finish
512105XX Outer door handles, front
51210701 Door stop, front Cracked / broken / torn off
51210734 Door stop, front Stiff to move
51210737 Door stop, front Loose
51210739 Door stop, front Unpleasant noises
51210765 Door stop, front Does not lock into position
512107XX Door stop, front
51210801 Inner weather strips, front Cracked / broken / torn off
51210832 Inner weather strips, front Deformed / distorted / bent
51210837 Inner weather strips, front Loose
512108XX Inner weather strips, front
51210937 Interior strip, instrument panel Loose
51210978 Interior strip, instrument panel poor surface finish
51210991 Interior strip, instrument panel colour differences
512109XX Interior strip, instrument panel
51211001 Outer weather strips, front Cracked / broken / torn off
51211032 Outer weather strips, front Deformed / distorted / bent
51211037 Outer weather strips, front Loose
51211075 Outer weather strips, front corroded
512110XX Outer weather strips, front
51211101 Window weatherstrip, outside front Cracked / broken / torn off
51211132 Window weatherstrip, outside front Deformed / distorted / bent
51211137 Window weatherstrip, outside front Loose
512111XX Window weatherstrip, outside front
51211301 Actuating lever trim (convertible) Cracked / broken / torn off
51211332 Actuating lever trim (convertible) Deformed / distorted / bent
51211337 Actuating lever trim (convertible) Loose
512113XX Actuating lever trim (convertible)
51211439 Closing aid front doors (automatic soft close) Unpleasant noises
51211440 Closing aid front doors (automatic soft close) Poorly adjusted / outside tolerance
512114XX Closing aid front doors (automatic soft close)
51211513 Dust cap, door lock barrel Broken
51211566 Dust cap, door lock barrel No effect
512115XX Dust cap, door lock barrel
51211766 Child safety lock (rear doors) No effect
512117XX Child safety lock (rear doors)
51211812 Door lock heating Permanent failure
512118XX Door lock heating
51212069 Ignition key track Worn / sheared through
512120XX Ignition key track
51219252 E53 Outside door handle frozen-up
5121XXXX Door locks, handles, linings at front
51220137 Lock striker, rear Loose
51220139 Lock striker, rear Unpleasant noises
51220141 Lock striker, rear Poorly adapted/fitted
512201XX Lock striker, rear
51220229 Rotary latch lock, rear Sticking/jammed
51220234 Rotary latch lock, rear Stiff to move
51220237 Rotary latch lock, rear Loose
51220239 Rotary latch lock, rear Unpleasant noises
51220265 Rotary latch lock, rear Does not lock into position
512202XX Rotary latch lock, rear
51220513 Outer door handles / grip strip, rear door Broken
51220534 Outer door handles / grip strip, rear door Stiff to move
51220537 Outer door handles / grip strip, rear door Loose
51220539 Outer door handles / grip strip, rear door Unpleasant noises
51220575 Outer door handles / grip strip, rear door corroded
51220578 Outer door handles / grip strip, rear door poor surface finish
512205XX Outer door handles / grip strip, rear door
51220701 Door stop, rear Cracked / broken / torn off
51220734 Door stop, rear Stiff to move
51220737 Door stop, rear Loose
51220739 Door stop, rear Unpleasant noises
51220765 Door stop, rear Does not lock into position
512207XX Door stop, rear
51220801 Inner weather strips, rear Cracked / broken / torn off
51220832 Inner weather strips, rear Deformed / distorted / bent
51220837 Inner weather strips, rear Loose
512208XX Inner weather strips, rear
51220937 Interior strip, rear Loose
51220978 Interior strip, rear poor surface finish
51220991 Interior strip, rear colour differences
512209XX Interior strip, rear
51221001 Outer weather strips, rear Cracked / broken / torn off
51221032 Outer weather strips, rear Deformed / distorted / bent
51221037 Outer weather strips, rear Loose
51221075 Outer weather strips, rear corroded
512210XX Outer weather strips, rear
51221101 Window weatherstrip, outside rear Cracked / broken / torn off
51221132 Window weatherstrip, outside rear Deformed / distorted / bent
51221137 Window weatherstrip, outside rear Loose
512211XX Window weatherstrip, outside rear
51221239 Closing aid rear doors (automatic soft close) Unpleasant noises
51221240 Closing aid rear doors (automatic soft close) Poorly adjusted / outside tolerance
512212XX Closing aid rear doors (automatic soft close)
51221329 Umbrella ejector system (incl. umbrella), rear door Sticking/jammed
51221339 Umbrella ejector system (incl. umbrella), rear door Unpleasant noises
51221352 Umbrella ejector system (incl. umbrella), rear door Not opening
51221353 Umbrella ejector system (incl. umbrella), rear door Not closing
512213XX Umbrella ejector system (incl. umbrella), rear door
51221513 Outer door handles/grip strip, rear lid Broken
51221537 Outer door handles/grip strip, rear lid Loose
51221541 Outer door handles/grip strip, rear lid Poorly adapted/fitted
51221578 Outer door handles/grip strip, rear lid poor surface finish
512215XX Outer door handles/grip strip, rear lid
51221613 Inner door opener with operating assembly, rear Broken
51221634 Inner door opener with operating assembly, rear Stiff to move
51221637 Inner door opener with operating assembly, rear Loose
51221639 Inner door opener with operating assembly, rear Unpleasant noises
51221641 Inner door opener with operating assembly, rear Poorly adapted/fitted
51221668 Inner door opener with operating assembly, rear Peels off / detaches itself
512216XX Inner door opener with operating assembly, rear
51221713 Locking button with linkage/bowden cable rear Broken
51221734 Locking button with linkage/bowden cable rear Stiff to move
51221737 Locking button with linkage/bowden cable rear Loose
512217XX Locking button with linkage/bowden cable rear
5122XXXX Door locks, handles, rear fitting
51230037 Engine hood catch Loose
51230040 Engine hood catch Poorly adjusted / outside tolerance
512300XX Engine hood catch
51230301 Engine hood lock cable Cracked / broken / torn off
51230329 Engine hood lock cable Sticking/jammed
51230337 Engine hood lock cable Loose
512303XX Engine hood lock cable
51231066 Engine hood gas pressurized prop No effect
512310XX Engine hood gas pressurized prop
5123XXXX Engine hood catch, locks
51240029 Rear lid lock Sticking/jammed
51240037 Rear lid lock Loose
51240041 Rear lid lock Poorly adapted/fitted
512400XX Rear lid lock
51240132 Rear lid locking bracket Deformed / distorted / bent
51240137 Rear lid locking bracket Loose
51240140 Rear lid locking bracket Poorly adjusted / outside tolerance
512401XX Rear lid locking bracket
51240234 Rear lid locking cylinder Stiff to move
51240237 Rear lid locking cylinder Loose
51240248 Rear lid locking cylinder Leaking
512402XX Rear lid locking cylinder
51240434 Rear lid Gas pressurized spring Stiff to move
51240437 Rear lid Gas pressurized spring Loose
51240439 Rear lid Gas pressurized spring Unpleasant noises
51240466 Rear lid Gas pressurized spring No effect
51240475 Rear lid Gas pressurized spring corroded
512404XX Rear lid Gas pressurized spring
51240813 Rear lid locking cylinder - dust cover Broken
512408XX Rear lid locking cylinder - dust cover
51240934 Rear lid panel lock Stiff to move
51240937 Rear lid panel lock Loose
51240940 Rear lid panel lock Poorly adjusted / outside tolerance
512409XX Rear lid panel lock
51241041 Rear lid rubber buffer Poorly adapted/fitted
512410XX Rear lid rubber buffer
51241139 Automatic boot lid (mechanical parts) Unpleasant noises
51241152 Automatic boot lid (mechanical parts) Not opening
51241153 Automatic boot lid (mechanical parts) Not closing
512411XX Automatic boot lid (mechanical parts)
51241214 Hydraulic unit, automatic rear lid Occasional malfunction
51241239 Hydraulic unit, automatic rear lid Unpleasant noises
51241248 Hydraulic unit, automatic rear lid Leaking
512412XX Hydraulic unit, automatic rear lid
51241366 Tail gate (coil) support spring (automatic opening) No effect
512413XX Tail gate (coil) support spring (automatic opening)
51241401 Boot lid emergency release Cracked / broken / torn off
51241434 Boot lid emergency release Stiff to move
51241440 Boot lid emergency release Poorly adjusted / outside tolerance
512414XX Boot lid emergency release
51249452 E46/5 (SE 493) Convenience opening, boot lid does not open
51249514 E65 E66 (with SA 316) Malfunction in automatic boot lid
5124XXXX Rear lid catch, locks
51250037 Soft-top cover flap lock Loose
512500XX Soft-top cover flap lock
51250137 Soft-top cover flap arrester hook Loose
51250141 Soft-top cover flap arrester hook Poorly adapted/fitted
512501XX Soft-top cover flap arrester hook
51250240 Soft-top cover flap locking bracket Poorly adjusted / outside tolerance
512502XX Soft-top cover flap locking bracket
51250366 Soft-top cover flap Gas pressurized spring No effect
512503XX Soft-top cover flap Gas pressurized spring
51250401 Soft-top cover flap Bowden cable Cracked / broken / torn off
51250429 Soft-top cover flap Bowden cable Sticking/jammed
51250440 Soft-top cover flap Bowden cable Poorly adjusted / outside tolerance
512504XX Soft-top cover flap Bowden cable
51250501 Soft-top cover flap cable for forced connection with rear lid Cracked / broken / torn off
512505XX Soft-top cover flap cable for forced connection with rear lid
5125XXXX Other locking items
51310007 Windscreen Cracked
51310030 Windscreen Blistering
51310033 Windscreen Optical distortion
51310041 Windscreen Poorly adapted/fitted
51310050 Windscreen Water ingress / condensate
51310054 Windscreen Scratches, score marks
513100XX Windscreen
51310348 Windscreen cementing Leaking
513103XX Windscreen cementing
51310401 Windscreen gutter strip Cracked / broken / torn off
51310437 Windscreen gutter strip Loose
51310441 Windscreen gutter strip Poorly adapted/fitted
513104XX Windscreen gutter strip
51310666 Windscreen heating wire No effect
513106XX Windscreen heating wire
51310737 Windscreen cover Loose
513107XX Windscreen cover
51311107 Rear window Cracked
51311130 Rear window Blistering
51311133 Rear window Optical distortion
51311154 Rear window Scratches, score marks
513111XX Rear window
51311341 Rear window decorative frame / filler strip Poorly adapted/fitted
51311378 Rear window decorative frame / filler strip poor surface finish
513113XX Rear window decorative frame / filler strip
51311403 Rear window cementing Ripped
51311448 Rear window cementing Leaking
513114XX Rear window cementing
51311503 Rear window trim strips Ripped
51311541 Rear window trim strips Poorly adapted/fitted
51311554 Rear window trim strips Scratches, score marks
51311578 Rear window trim strips poor surface finish
513115XX Rear window trim strips
51311666 Rear window heating wire No effect
513116XX Rear window heating wire
51311768 Rain sensor prism (incl. light sensor) Peels off / detaches itself
513117XX Rain sensor prism (incl. light sensor)
51319540 R50 Windscreen rubber frame
5131XXXX Windscreen and rear window
51320013 Window crank, front Broken
51320037 Window crank, front Loose
513200XX Window crank, front
51320113 Front manual window regulator Broken
51320121 Front manual window regulator Worn
51320129 Front manual window regulator Sticking/jammed
51320137 Front manual window regulator Loose
51320140 Front manual window regulator Poorly adjusted / outside tolerance
513201XX Front manual window regulator
51320229 Holder with window regulator rail Sticking/jammed
51320237 Holder with window regulator rail Loose
513202XX Holder with window regulator rail
51320307 Front door window Cracked
51320329 Front door window Sticking/jammed
51320330 Front door window Blistering
51320333 Front door window Optical distortion
51320334 Front door window Stiff to move
51320337 Front door window Loose
51320339 Front door window Unpleasant noises
51320341 Front door window Poorly adapted/fitted
51320354 Front door window Scratches, score marks
513203XX Front door window
51320432 Front window guide rail Deformed / distorted / bent
51320437 Front window guide rail Loose
51320441 Front window guide rail Poorly adapted/fitted
513204XX Front window guide rail
51320532 Front window guide rubber Deformed / distorted / bent
51320537 Front window guide rubber Loose
51320541 Front window guide rubber Poorly adapted/fitted
513205XX Front window guide rubber
51321241 Corner trim (mirror **** trim) Poorly adapted/fitted
513212XX Corner trim (mirror **** trim)
51321637 Front door window frame trim panel Loose
51321641 Front door window frame trim panel Poorly adapted/fitted
51321678 Front door window frame trim panel poor surface finish
513216XX Front door window frame trim panel
51321737 Cover, inner corner trim Loose
513217XX Cover, inner corner trim
51322037 Door joint seal, entrance Loose
51322041 Door joint seal, entrance Poorly adapted/fitted
513220XX Door joint seal, entrance
51329339 E46/C Crackling noise from side windows when closed
5132XXXX Windows with manual operation at front
51330932 Front window guide rail Deformed / distorted / bent
51330937 Front window guide rail Loose
51330940 Front window guide rail Poorly adjusted / outside tolerance
513309XX Front window guide rail
51331213 Window regulator, front Broken
51331229 Window regulator, front Sticking/jammed
51331237 Window regulator, front Loose
51331239 Window regulator, front Unpleasant noises
513312XX Window regulator, front
51331601 Front window regulator operating cable Cracked / broken / torn off
51331608 Front window regulator operating cable Jumps out
51331639 Front window regulator operating cable Unpleasant noises
513316XX Front window regulator operating cable
51331766 Heating element, side window, front No effect
513317XX Heating element, side window, front
51339339 R50 R53 Door window rattles when opening door
5133XXXX Windows with power actuation at front
51340013 Window crank handle, rear Broken
51340037 Window crank handle, rear Loose
513400XX Window crank handle, rear
51340113 Rear manual window regulator Broken
51340129 Rear manual window regulator Sticking/jammed
51340137 Rear manual window regulator Loose
51340140 Rear manual window regulator Poorly adjusted / outside tolerance
513401XX Rear manual window regulator
51340307 Rear door window Cracked
51340329 Rear door window Sticking/jammed
51340330 Rear door window Blistering
51340333 Rear door window Optical distortion
51340337 Rear door window Loose
51340339 Rear door window Unpleasant noises
51340341 Rear door window Poorly adapted/fitted
51340354 Rear door window Scratches, score marks
513403XX Rear door window
51340432 Rear window guide rail Deformed / distorted / bent
51340437 Rear window guide rail Loose
51340441 Rear window guide rail Poorly adapted/fitted
513404XX Rear window guide rail
51340532 Rear window guide rubber Deformed / distorted / bent
51340537 Rear window guide rubber Loose
51340541 Rear window guide rubber Poorly adapted/fitted
513405XX Rear window guide rubber
51340737 Rear door window frame trim panel Loose
51340778 Rear door window frame trim panel poor surface finish
513407XX Rear door window frame trim panel
51341107 Corner window, rear door Cracked
51341133 Corner window, rear door Optical distortion
51341154 Corner window, rear door Scratches, score marks
513411XX Corner window, rear door
51341241 Rubber seal for corner window, rear door Poorly adapted/fitted
513412XX Rubber seal for corner window, rear door
5134XXXX Windows with manual operation at back
51350013 Window regulator, rear Broken
51350029 Window regulator, rear Sticking/jammed
51350037 Window regulator, rear Loose
51350039 Window regulator, rear Unpleasant noises
513500XX Window regulator, rear
51351601 Rear window regulator operating cable Cracked / broken / torn off
51351608 Rear window regulator operating cable Jumps out
51351639 Rear window regulator operating cable Unpleasant noises
513516XX Rear window regulator operating cable
5135XXXX Windows with power actuation, rear
51360013 Rear side window catch Broken
51360014 Rear side window catch Occasional malfunction
51360037 Rear side window catch Loose
51360041 Rear side window catch Poorly adapted/fitted
513600XX Rear side window catch
51360107 Side window Cracked
51360113 Side window Broken
51360130 Side window Blistering
51360133 Side window Optical distortion
51360137 Side window Loose
51360139 Side window Unpleasant noises
51360140 Side window Poorly adjusted / outside tolerance
51360148 Side window Leaking
51360154 Side window Scratches, score marks
513601XX Side window
51360241 Strip hinge for rear vent window Poorly adapted/fitted
513602XX Strip hinge for rear vent window
51360332 Rubber seal for rear side window Deformed / distorted / bent
51360337 Rubber seal for rear side window Loose
51360348 Rubber seal for rear side window Leaking
513603XX Rubber seal for rear side window
51360437 Surround strip for rear side window Loose
51360441 Surround strip for rear side window Poorly adapted/fitted
51360478 Surround strip for rear side window poor surface finish
513604XX Surround strip for rear side window
51360532 Outside cover strip for rear side window Deformed / distorted / bent
513605XX Outside cover strip for rear side window
51360737 Rear window guide (convertible) Loose
51360741 Rear window guide (convertible) Poorly adapted/fitted
513607XX Rear window guide (convertible)
51360841 Quarter vent, front (Z3) Poorly adapted/fitted
51360848 Quarter vent, front (Z3) Leaking
513608XX Quarter vent, front (Z3)
5136XXXX Side window, body
51410030 Door trim panel, front (incl. module carrier, front door) Blistering
51410037 Door trim panel, front (incl. module carrier, front door) Loose
51410039 Door trim panel, front (incl. module carrier, front door) Unpleasant noises
51410041 Door trim panel, front (incl. module carrier, front door) Poorly adapted/fitted
514100XX Door trim panel, front (incl. module carrier, front door)
51410101 Arm rests (incl. softpad) door trim panel, front Cracked / broken / torn off
51410136 Arm rests (incl. softpad) door trim panel, front Dented/wavy
51410137 Arm rests (incl. softpad) door trim panel, front Loose
514101XX Arm rests (incl. softpad) door trim panel, front
51410301 Inner front door handle (X5/Z8) Cracked / broken / torn off
51410313 Inner front door handle (X5/Z8) Broken
51410337 Inner front door handle (X5/Z8) Loose
514103XX Inner front door handle (X5/Z8)
51410437 Door interior strip, front Loose
51410454 Door interior strip, front Scratches, score marks
51410491 Door interior strip, front colour differences
514104XX Door interior strip, front
51410537 Door shoulder moulding Loose
51410540 Door shoulder moulding Poorly adjusted / outside tolerance
51410578 Door shoulder moulding poor surface finish
514105XX Door shoulder moulding
51419239 E46/2/C Surrounding area, door speaker, disruptive noises
5141XXXX Front door trim with armrests
51420030 Door trim panel, rear (incl. module carrier, rear door) Blistering
51420037 Door trim panel, rear (incl. module carrier, rear door) Loose
51420039 Door trim panel, rear (incl. module carrier, rear door) Unpleasant noises
51420041 Door trim panel, rear (incl. module carrier, rear door) Poorly adapted/fitted
514200XX Door trim panel, rear (incl. module carrier, rear door)
51420101 Arm rest (incl. softpad) door trim panel, rear Cracked / broken / torn off
51420137 Arm rest (incl. softpad) door trim panel, rear Loose
514201XX Arm rest (incl. softpad) door trim panel, rear
51420301 Inner rear door handle (X5) Cracked / broken / torn off
51420313 Inner rear door handle (X5) Broken
51420337 Inner rear door handle (X5) Loose
514203XX Inner rear door handle (X5)
51420437 Door interior strip, rear Loose
51420454 Door interior strip, rear Scratches, score marks
51420491 Door interior strip, rear colour differences
514204XX Door interior strip, rear
51429239 E65 E66 Vibration noise from door trim panel during audio operation
5142XXXX Rear door trim with armrests
51430030 Side trim panel, rear (two-door model only) Blistering
51430037 Side trim panel, rear (two-door model only) Loose
51430041 Side trim panel, rear (two-door model only) Poorly adapted/fitted
514300XX Side trim panel, rear (two-door model only)
51430301 Soft-top cover flap cover left/right Cracked / broken / torn off
51430337 Soft-top cover flap cover left/right Loose
51430341 Soft-top cover flap cover left/right Poorly adapted/fitted
514303XX Soft-top cover flap cover left/right
51430437 A-pillar trim panel (inner) Loose
51430441 A-pillar trim panel (inner) Poorly adapted/fitted
514304XX A-pillar trim panel (inner)
51430537 B-pillar trim panel (inner) Loose
51430541 B-pillar trim panel (inner) Poorly adapted/fitted
514305XX B-pillar trim panel (inner)
51430637 C-pillar trim panel (inner) Loose
51430641 C-pillar trim panel (inner) Poorly adapted/fitted
514306XX C-pillar trim panel (inner)
51430737 D-pillar trim panel (inner) Loose
51430741 D-pillar trim panel (inner) Poorly adapted/fitted
514307XX D-pillar trim panel (inner)
51430830 Interior strip, side trim panel, rear Blistering
51430837 Interior strip, side trim panel, rear Loose
51430854 Interior strip, side trim panel, rear Scratches, score marks
51430868 Interior strip, side trim panel, rear Peels off / detaches itself
51430891 Interior strip, side trim panel, rear colour differences
514308XX Interior strip, side trim panel, rear
51431401 Tailgate/boot lid trim panel (inner) Cracked / broken / torn off
51431437 Tailgate/boot lid trim panel (inner) Loose
51431441 Tailgate/boot lid trim panel (inner) Poorly adapted/fitted
514314XX Tailgate/boot lid trim panel (inner)
51431601 Armrest, side trim panel, rear Cracked / broken / torn off
51431637 Armrest, side trim panel, rear Loose
514316XX Armrest, side trim panel, rear
5143XXXX Side panel trim with armrests
51440001 Roof lining material/moulded roof lining Cracked / broken / torn off
51440037 Roof lining material/moulded roof lining Loose
51440041 Roof lining material/moulded roof lining Poorly adapted/fitted
51440076 Roof lining material/moulded roof lining dirty / blocked
514400XX Roof lining material/moulded roof lining
51440437 Headliner console Loose
514404XX Headliner console
5144XXXX Roof trim
51450001 Instrument panel trim, complete Cracked / broken / torn off
51450030 Instrument panel trim, complete Blistering
51450037 Instrument panel trim, complete Loose
51450039 Instrument panel trim, complete Unpleasant noises
51450041 Instrument panel trim, complete Poorly adapted/fitted
514500XX Instrument panel trim, complete
51450201 Instrument panel trim, bottom (incl. knee pad) Cracked / broken / torn off
51450237 Instrument panel trim, bottom (incl. knee pad) Loose
51450239 Instrument panel trim, bottom (incl. knee pad) Unpleasant noises
51450241 Instrument panel trim, bottom (incl. knee pad) Poorly adapted/fitted
514502XX Instrument panel trim, bottom (incl. knee pad)
51450413 Side trim, front underside (incl. footrest) Broken
51450437 Side trim, front underside (incl. footrest) Loose
51450441 Side trim, front underside (incl. footrest) Poorly adapted/fitted
51450468 Side trim, front underside (incl. footrest) Peels off / detaches itself
514504XX Side trim, front underside (incl. footrest)
51450513 Defroster nozzles, finisher Broken
514505XX Defroster nozzles, finisher
51450629 Centre console, mounting bracket, radio cover Sticking/jammed
51450641 Centre console, mounting bracket, radio cover Poorly adapted/fitted
51450665 Centre console, mounting bracket, radio cover Does not lock into position
514506XX Centre console, mounting bracket, radio cover
51450737 Finisher for module carrier (MINI) Loose
51450778 Finisher for module carrier (MINI) poor surface finish
51450791 Finisher for module carrier (MINI) colour differences
514507XX Finisher for module carrier (MINI)
51451101 Instrument panel cover, passenger airbag Cracked / broken / torn off
51451130 Instrument panel cover, passenger airbag Blistering
51451137 Instrument panel cover, passenger airbag Loose
51451139 Instrument panel cover, passenger airbag Unpleasant noises
51451141 Instrument panel cover, passenger airbag Poorly adapted/fitted
514511XX Instrument panel cover, passenger airbag
51451239 Folding mechanism, control display, front Unpleasant noises
51451252 Folding mechanism, control display, front Not opening
51451253 Folding mechanism, control display, front Not closing
514512XX Folding mechanism, control display, front
51459241 E39 Passenger airbag cover protrudes
5145XXXX Instrument panel trim
51460037 Rear window ****f (incl. support) Loose
51460039 Rear window ****f (incl. support) Unpleasant noises
51460041 Rear window ****f (incl. support) Poorly adapted/fitted
51460067 Rear window ****f (incl. support) Discoloured
514600XX Rear window ****f (incl. support)
51460137 Trim on luggage compartment partition wall Loose
51460141 Trim on luggage compartment partition wall Poorly adapted/fitted
514601XX Trim on luggage compartment partition wall
51460201 Trim on body end panel Cracked / broken / torn off
51460237 Trim on body end panel Loose
514602XX Trim on body end panel
51460401 Rear window sun roller blind Cracked / broken / torn off
51460436 Rear window sun roller blind Dented/wavy
51460439 Rear window sun roller blind Unpleasant noises
51460441 Rear window sun roller blind Poorly adapted/fitted
51460452 Rear window sun roller blind Not opening
51460453 Rear window sun roller blind Not closing
514604XX Rear window sun roller blind
51460501 Roller sun blind / curtain, rear door window Cracked / broken / torn off
51460529 Roller sun blind / curtain, rear door window Sticking/jammed
51460536 Roller sun blind / curtain, rear door window Dented/wavy
514605XX Roller sun blind / curtain, rear door window
51460637 Oddments box, rear window ****f Loose
514606XX Oddments box, rear window ****f
51469039 E46/2 Storage ****f vibration noises due to subwoofer
5146XXXX Partition wall trim panels
51470001 Sill cover strips Cracked / broken / torn off
51470041 Sill cover strips Poorly adapted/fitted
514700XX Sill cover strips
51470101 Luggage compartment trims Cracked / broken / torn off
51470137 Luggage compartment trims Loose
51470139 Luggage compartment trims Unpleasant noises
51470141 Luggage compartment trims Poorly adapted/fitted
514701XX Luggage compartment trims
51470301 Loose or fitted carpet Cracked / broken / torn off
51470341 Loose or fitted carpet Poorly adapted/fitted
51470369 Loose or fitted carpet Worn / sheared through
514703XX Loose or fitted carpet
51470401 Undertray trim (engine) Cracked / broken / torn off
51470437 Undertray trim (engine) Loose
514704XX Undertray trim (engine)
51470713 Cubby flaps (in luggage compartment) Broken
51470737 Cubby flaps (in luggage compartment) Loose
514707XX Cubby flaps (in luggage compartment)
51470801 Roller blind in luggage compartment Cracked / broken / torn off
51470813 Roller blind in luggage compartment Broken
51470829 Roller blind in luggage compartment Sticking/jammed
51470839 Roller blind in luggage compartment Unpleasant noises
514708XX Roller blind in luggage compartment
51470901 Net roller cover in luggage compartment Cracked / broken / torn off
51470929 Net roller cover in luggage compartment Sticking/jammed
51470939 Net roller cover in luggage compartment Unpleasant noises
514709XX Net roller cover in luggage compartment
51471001 Floor mats/carpet Cracked / broken / torn off
51471069 Floor mats/carpet Worn / sheared through
514710XX Floor mats/carpet
51471123 Underbody protection / air guide Incorrect / not fitted
51471137 Underbody protection / air guide Loose
514711XX Underbody protection / air guide
51471301 Floor mats/carpet fastening Cracked / broken / torn off
51471304 Floor mats/carpet fastening Screw connection torn
51471366 Floor mats/carpet fastening No effect
514713XX Floor mats/carpet fastening
51471411 Mechanical folding foot rest, rear Occasional failure
51471412 Mechanical folding foot rest, rear Permanent failure
51471439 Mechanical folding foot rest, rear Unpleasant noises
51471478 Mechanical folding foot rest, rear poor surface finish
514714XX Mechanical folding foot rest, rear
51472015 Pull-out load floor, boot (trunk) Permanent malfunction
51472039 Pull-out load floor, boot (trunk) Unpleasant noises
514720XX Pull-out load floor, boot (trunk)
51472113 Roller frame, load floor Broken
51472165 Roller frame, load floor Does not lock into position
514721XX Roller frame, load floor
51472201 Convertible top compartment trim Cracked / broken / torn off
511217XX Rear apron
511629XX Coin box
513100XX Windscreen
5144XXXX Roof trim
