الجزء العاشر :
61303314 Release switch for tailgate window Occasional malfunction
61303315 Release switch for tailgate window Permanent malfunction
61303329 Release switch for tailgate window Sticking/jammed
61303337 Release switch for tailgate window Loose
613033XX Release switch for tailgate window
61303514 Automatic rear lid switch (on inside of rear lid) Occasional malfunction
61303515 Automatic rear lid switch (on inside of rear lid) Permanent malfunction
61303529 Automatic rear lid switch (on inside of rear lid) Sticking/jammed
61303537 Automatic rear lid switch (on inside of rear lid) Loose
61303586 Automatic rear lid switch (on inside of rear lid) does not light up
613035XX Automatic rear lid switch (on inside of rear lid)
61303614 Tilt sensor, automatic rear lid Occasional malfunction
61303615 Tilt sensor, automatic rear lid Permanent malfunction
61303679 Tilt sensor, automatic rear lid incorrect connection /contact
613036XX Tilt sensor, automatic rear lid
61303714 Switch, front seat adjustment unit Occasional malfunction
61303715 Switch, front seat adjustment unit Permanent malfunction
61303729 Switch, front seat adjustment unit Sticking/jammed
61303737 Switch, front seat adjustment unit Loose
61303786 Switch, front seat adjustment unit does not light up
613037XX Switch, front seat adjustment unit
61303814 Switch, rear seat adjustment unit Occasional malfunction
61303815 Switch, rear seat adjustment unit Permanent malfunction
61303829 Switch, rear seat adjustment unit Sticking/jammed
61303837 Switch, rear seat adjustment unit Loose
61303886 Switch, rear seat adjustment unit does not light up
613038XX Switch, rear seat adjustment unit
61303914 Switch, active seat ventilation, front Occasional malfunction
61303915 Switch, active seat ventilation, front Permanent malfunction
61303929 Switch, active seat ventilation, front Sticking/jammed
61303937 Switch, active seat ventilation, front Loose
61303986 Switch, active seat ventilation, front does not light up
613039XX Switch, active seat ventilation, front
61304014 Switch, active seat ventilation, rear Occasional malfunction
61304015 Switch, active seat ventilation, rear Permanent malfunction
61304029 Switch, active seat ventilation, rear Sticking/jammed
61304037 Switch, active seat ventilation, rear Loose
61304086 Switch, active seat ventilation, rear does not light up
613040XX Switch, active seat ventilation, rear
61304114 Switch, front active seat Occasional malfunction
61304115 Switch, front active seat Permanent malfunction
61304129 Switch, front active seat Sticking/jammed
61304137 Switch, front active seat Loose
61304186 Switch, front active seat does not light up
613041XX Switch, front active seat
61304214 Switch, rear active seat Occasional malfunction
61304215 Switch, rear active seat Permanent malfunction
61304229 Switch, rear active seat Sticking/jammed
61304237 Switch, rear active seat Loose
61304286 Switch, rear active seat does not light up
613042XX Switch, rear active seat
61304314 Steptronic push-button/paddle steering wheel Occasional malfunction
61304315 Steptronic push-button/paddle steering wheel Permanent malfunction
61304329 Steptronic push-button/paddle steering wheel Sticking/jammed
613043XX Steptronic push-button/paddle steering wheel
61304414 Emergency call button Occasional malfunction
61304415 Emergency call button Permanent malfunction
61304429 Emergency call button Sticking/jammed
61304486 Emergency call button does not light up
613044XX Emergency call button
61304514 Switch, hotel position (in centre console oddments tray) Occasional malfunction
61304515 Switch, hotel position (in centre console oddments tray) Permanent malfunction
61304537 Switch, hotel position (in centre console oddments tray) Loose
61304586 Switch, hotel position (in centre console oddments tray) does not light up
613045XX Switch, hotel position (in centre console oddments tray)
61304614 Switch, roller sunblind rear doors Occasional malfunction
61304615 Switch, roller sunblind rear doors Permanent malfunction
61304637 Switch, roller sunblind rear doors Loose
61304686 Switch, roller sunblind rear doors does not light up
613046XX Switch, roller sunblind rear doors
61304714 Distribution switch (on power distribution box) Occasional malfunction
61304715 Distribution switch (on power distribution box) Permanent malfunction
61304729 Distribution switch (on power distribution box) Sticking/jammed
61304737 Distribution switch (on power distribution box) Loose
613047XX Distribution switch (on power distribution box)
61304814 Steering wheel release push-button Occasional malfunction
61304815 Steering wheel release push-button Permanent malfunction
61304829 Steering wheel release push-button Sticking/jammed
61304837 Steering wheel release push-button Loose
613048XX Steering wheel release push-button
61304914 Switch, seat backrest adjustment, rear (in luggage compartment or headliner) Occasional malfunction
61304915 Switch, seat backrest adjustment, rear (in luggage compartment or headliner) Permanent malfunction
61304937 Switch, seat backrest adjustment, rear (in luggage compartment or headliner) Loose
613049XX Switch, seat backrest adjustment, rear (in luggage compartment or headliner)
61305014 Parking brake push-button Occasional malfunction
61305015 Parking brake push-button Permanent malfunction
61305037 Parking brake push-button Loose
61305086 Parking brake push-button does not light up
613050XX Parking brake push-button
61305139 Steering column switch centre trim (E65) Unpleasant noises
61305141 Steering column switch centre trim (E65) Poorly adapted/fitted
613051XX Steering column switch centre trim (E65)
61305214 Audio unit switch, rear compartment Occasional malfunction
61305215 Audio unit switch, rear compartment Permanent malfunction
61305229 Audio unit switch, rear compartment Sticking/jammed
61305237 Audio unit switch, rear compartment Loose
61305286 Audio unit switch, rear compartment does not light up
613052XX Audio unit switch, rear compartment
6130XXXX Switches, relays, control units and small units
61310114 Indicator light switch Occasional malfunction
61310115 Indicator light switch Permanent malfunction
61310137 Indicator light switch Loose
61310165 Indicator light switch Does not lock into position
613101XX Indicator light switch
61310314 Switch for parking lights/low-beam headlights Occasional malfunction
61310315 Switch for parking lights/low-beam headlights Permanent malfunction
61310329 Switch for parking lights/low-beam headlights Sticking/jammed
61310337 Switch for parking lights/low-beam headlights Loose
61310386 Switch for parking lights/low-beam headlights does not light up
613103XX Switch for parking lights/low-beam headlights
61310414 Wiper switch Occasional malfunction
61310415 Wiper switch Permanent malfunction
61310437 Wiper switch Loose
61310465 Wiper switch Does not lock into position
613104XX Wiper switch
61310514 Dimmer for instrument lighting Occasional malfunction
61310515 Dimmer for instrument lighting Permanent malfunction
61310537 Dimmer for instrument lighting Loose
61310586 Dimmer for instrument lighting does not light up
613105XX Dimmer for instrument lighting
61310714 Switch for rear window heating Occasional malfunction
61310715 Switch for rear window heating Permanent malfunction
61310729 Switch for rear window heating Sticking/jammed
61310737 Switch for rear window heating Loose
61310786 Switch for rear window heating does not light up
613107XX Switch for rear window heating
61310814 Switch for front and rear fog lights Occasional malfunction
61310815 Switch for front and rear fog lights Permanent malfunction
61310829 Switch for front and rear fog lights Sticking/jammed
61310837 Switch for front and rear fog lights Loose
61310886 Switch for front and rear fog lights does not light up
613108XX Switch for front and rear fog lights
61310914 Switch for hazard warning flashers Occasional malfunction
61310915 Switch for hazard warning flashers Permanent malfunction
61310929 Switch for hazard warning flashers Sticking/jammed
61310937 Switch for hazard warning flashers Loose
61310986 Switch for hazard warning flashers does not light up
613109XX Switch for hazard warning flashers
61311114 Switch for window regulators Occasional malfunction
61311115 Switch for window regulators Permanent malfunction
61311129 Switch for window regulators Sticking/jammed
61311137 Switch for window regulators Loose
61311139 Switch for window regulators Unpleasant noises
61311186 Switch for window regulators does not light up
613111XX Switch for window regulators
61311214 Door-operated switch Occasional malfunction
61311215 Door-operated switch Permanent malfunction
613112XX Door-operated switch
61311314 Contact switch for engine compartment light Occasional malfunction
61311315 Contact switch for engine compartment light Permanent malfunction
613113XX Contact switch for engine compartment light
61311414 Contact switch for luggage compartment light Occasional malfunction
61311415 Contact switch for luggage compartment light Permanent malfunction
613114XX Contact switch for luggage compartment light
61311814 Brake light switch Occasional malfunction
61311815 Brake light switch Permanent malfunction
61311839 Brake light switch Unpleasant noises
613118XX Brake light switch
61311914 Switch for handbrake telltale light Occasional malfunction
61311915 Switch for handbrake telltale light Permanent malfunction
613119XX Switch for handbrake telltale light
61312014 Switch for glovebox light Occasional malfunction
61312015 Switch for glovebox light Permanent malfunction
613120XX Switch for glovebox light
61312214 Temperature switch for auxiliary electric fan Occasional malfunction
61312215 Temperature switch for auxiliary electric fan Permanent malfunction
613122XX Temperature switch for auxiliary electric fan
61312414 Temperature switch for exhaust gas recirculation Occasional malfunction
61312415 Temperature switch for exhaust gas recirculation Permanent malfunction
613124XX Temperature switch for exhaust gas recirculation
61312714 Coolant level switch Occasional malfunction
61312715 Coolant level switch Permanent malfunction
613127XX Coolant level switch
61312814 Washer fluid level switch Occasional malfunction
61312815 Washer fluid level switch Permanent malfunction
613128XX Washer fluid level switch
61313214 Hazard warning flasher relay Occasional malfunction
61313215 Hazard warning flasher relay Permanent malfunction
613132XX Hazard warning flasher relay
61314614 Lights operating unit Occasional malfunction
61314615 Lights operating unit Permanent malfunction
61314629 Lights operating unit Sticking/jammed
61314637 Lights operating unit Loose
61314686 Lights operating unit does not light up
613146XX Lights operating unit
61315114 Clutch switch Occasional malfunction
61315115 Clutch switch Permanent malfunction
61315139 Clutch switch Unpleasant noises
613151XX Clutch switch
61315414 Switch/lever for cruise control Occasional malfunction
61315415 Switch/lever for cruise control Permanent malfunction
61315437 Switch/lever for cruise control Loose
613154XX Switch/lever for cruise control
61315514 Transmission program switch Occasional malfunction
61315515 Transmission program switch Permanent malfunction
61315529 Transmission program switch Sticking/jammed
61315537 Transmission program switch Loose
61315586 Transmission program switch does not light up
613155XX Transmission program switch
61315714 Microswitch for central locking Occasional malfunction
61315715 Microswitch for central locking Permanent malfunction
613157XX Microswitch for central locking
61315814 Seat memory switch Occasional malfunction
61315815 Seat memory switch Permanent malfunction
61315829 Seat memory switch Sticking/jammed
61315837 Seat memory switch Loose
61315886 Seat memory switch does not light up
613158XX Seat memory switch
61316014 Self-levelling suspension regulating switch Occasional malfunction
61316015 Self-levelling suspension regulating switch Permanent malfunction
613160XX Self-levelling suspension regulating switch
61316114 Sunroof micro switch (SHD) Occasional malfunction
61316115 Sunroof micro switch (SHD) Permanent malfunction
613161XX Sunroof micro switch (SHD)
61316214 Seat adjustment switch, front (without memory) Occasional malfunction
61316215 Seat adjustment switch, front (without memory) Permanent malfunction
61316229 Seat adjustment switch, front (without memory) Sticking/jammed
61316237 Seat adjustment switch, front (without memory) Loose
613162XX Seat adjustment switch, front (without memory)
61316337 Airbag switch (Z3/Z4) Loose
61316379 Airbag switch (Z3/Z4) incorrect connection /contact
61316386 Airbag switch (Z3/Z4) does not light up
613163XX Airbag switch (Z3/Z4)
61316414 Clutch switch, start lock Occasional malfunction
61316415 Clutch switch, start lock Permanent malfunction
61316439 Clutch switch, start lock Unpleasant noises
613164XX Clutch switch, start lock
61316514 Space sound switch Occasional malfunction
61316515 Space sound switch Permanent malfunction
61316529 Space sound switch Sticking/jammed
61316586 Space sound switch does not light up
613165XX Space sound switch
61316614 Starter button Occasional malfunction
61316615 Starter button Permanent malfunction
61316637 Starter button Loose
613166XX Starter button
61316702 Centre console switch centre Software error / internal device fault
61316714 Centre console switch centre Occasional malfunction
61316715 Centre console switch centre Permanent malfunction
61316729 Centre console switch centre Sticking/jammed
61316737 Centre console switch centre Loose
61316786 Centre console switch centre does not light up
613167XX Centre console switch centre
61316878 Controller, front (sliding-push-rotary button in centre console) poor surface finish
61316879 Controller, front (sliding-push-rotary button in centre console) incorrect connection /contact
61316883 Controller, front (sliding-push-rotary button in centre console) incorrect or no switching action
61316886 Controller, front (sliding-push-rotary button in centre console) does not light up
613168XX Controller, front (sliding-push-rotary button in centre console)
61316978 Controller, rear (sliding-push-rotary button in rear multifunction armrest) poor surface finish
61316979 Controller, rear (sliding-push-rotary button in rear multifunction armrest) incorrect connection /co
61316983 Controller, rear (sliding-push-rotary button in rear multifunction armrest) incorrect or no switchin
61316986 Controller, rear (sliding-push-rotary button in rear multifunction armrest) does not light up
613169XX Controller, rear (sliding-push-rotary button in rear multifunction armrest)
61317014 Switch for seat heating, rear Occasional malfunction
61317015 Switch for seat heating, rear Permanent malfunction
61317029 Switch for seat heating, rear Sticking/jammed
61317037 Switch for seat heating, rear Loose
61317086 Switch for seat heating, rear does not light up
613170XX Switch for seat heating, rear
61317114 Gear selector switch (lever) Occasional malfunction
61317115 Gear selector switch (lever) Permanent malfunction
61317137 Gear selector switch (lever) Loose
613171XX Gear selector switch (lever)
61317714 Thermo-switch unit for overheat warning sensor (catalytic converter) Occasional malfunction
61317715 Thermo-switch unit for overheat warning sensor (catalytic converter) Permanent malfunction
613177XX Thermo-switch unit for overheat warning sensor (catalytic converter)
61318314 Switch for seat heating, front Occasional malfunction
61318315 Switch for seat heating, front Permanent malfunction
61318329 Switch for seat heating, front Sticking/jammed
61318337 Switch for seat heating, front Loose
61318386 Switch for seat heating, front does not light up
613183XX Switch for seat heating, front
61318914 Switch for outside mirror adjustment Occasional malfunction
61318915 Switch for outside mirror adjustment Permanent malfunction
61318929 Switch for outside mirror adjustment Sticking/jammed
61318937 Switch for outside mirror adjustment Loose
61318986 Switch for outside mirror adjustment does not light up
613189XX Switch for outside mirror adjustment
61319002 E46 (with SA 235) double rate of direction indicator in instrument cluster
61319008 E46 E39 E53 (With SE 255 + 249) Radio station/CD track jumps when volume button is pressed
61319043 E46/3 Rear window opens automatically
61319083 E46 Low beam headlight remains on
61319086 E46 Home lights malfunction (light operating unit)
61319088 E38 E39 Steering-column memory longitudinal adjustment incorrect
61319098 E46 Brightness fluctuations with seat heating switched on
6131XXXX Switch
61320114 Ignition starter switch Occasional malfunction
61320115 Ignition starter switch Permanent malfunction
61320129 Ignition starter switch Sticking/jammed
61320137 Ignition starter switch Loose
61320179 Ignition starter switch incorrect connection /contact
613201XX Ignition starter switch
61320214 Automatic starter aid Occasional malfunction
61320215 Automatic starter aid Permanent malfunction
613202XX Automatic starter aid
61320314 CAS (car access system) electronics Occasional malfunction
61320315 CAS (car access system) electronics Permanent malfunction
61320329 CAS (car access system) electronics Sticking/jammed
61320365 CAS (car access system) electronics Does not lock into position
613203XX CAS (car access system) electronics
6132XXXX Ignition starter switch
61330037 Horn Loose
61330079 Horn incorrect connection /contact
613300XX Horn
6133XXXX Horn
61340010 Cigar lighter Fallen out
61340029 Cigar lighter Sticking/jammed
61340037 Cigar lighter Loose
61340079 Cigar lighter incorrect connection /contact
61340080 Cigar lighter short circuit
61340086 Cigar lighter does not light up
613400XX Cigar lighter
61340137 12 V socket outlet Loose
61340179 12 V socket outlet incorrect connection /contact
613401XX 12 V socket outlet
6134XXXX Cigar lighter, socket outlets
61350014 Windscreen wiper function in general module / body control unit Occasional malfunction
61350015 Windscreen wiper function in general module / body control unit Permanent malfunction
613500XX Windscreen wiper function in general module / body control unit
61350114 Contact pressure control function in general module / body control unit Occasional malfunction
61350115 Contact pressure control function in general module / body control unit Permanent malfunction
613501XX Contact pressure control function in general module / body control unit
61350214 Headlight washer function in general module / body control unit Occasional malfunction
61350215 Headlight washer function in general module / body control unit Permanent malfunction
613502XX Headlight washer function in general module / body control unit
61350314 Central locking function in general module / body control unit Occasional malfunction
61350315 Central locking function in general module / body control unit Permanent malfunction
61350343 Central locking function in general module / body control unit Releases by itself
61350344 Central locking function in general module / body control unit Locks by itself
613503XX Central locking function in general module / body control unit
61350414 Interior lighting / door lock heating function in general module / body control unit Occasional malf
61350415 Interior lighting / door lock heating function in general module / body control unit Permanent malfu
613504XX Interior lighting / door lock heating function in general module / body control unit
61350514 Power window function in general module / body control unit Occasional malfunction
61350515 Power window function in general module / body control unit Permanent malfunction
613505XX Power window function in general module / body control unit
61350714 Anti-theft alarm system in general module / body control unit Occasional malfunction
61350715 Anti-theft alarm system in general module / body control unit Permanent malfunction
613507XX Anti-theft alarm system in general module / body control unit
61350814 Slide/tilt sunroof (SHD) in general module / body control unit Occasional malfunction
61350815 Slide/tilt sunroof (SHD) in general module / body control unit Permanent malfunction
613508XX Slide/tilt sunroof (SHD) in general module / body control unit
61350914 Door module for central locking Occasional malfunction
61350915 Door module for central locking Permanent malfunction
613509XX Door module for central locking
61351014 Door module for interior lighting and door lock heating Occasional malfunction
61351015 Door module for interior lighting and door lock heating Permanent malfunction
613510XX Door module for interior lighting and door lock heating
61351114 Light module, fog lights/rear fog lights Occasional malfunction
61351115 Light module, fog lights/rear fog lights Permanent malfunction
613511XX Light module, fog lights/rear fog lights
61351214 Light module, brake lights Occasional malfunction
61351215 Light module, brake lights Permanent malfunction
613512XX Light module, brake lights
61351314 Light module, parking/low beam/tail/licence plate lights Occasional malfunction
61351315 Light module, parking/low beam/tail/licence plate lights Permanent malfunction
613513XX Light module, parking/low beam/tail/licence plate lights
61351414 Electronic battery isolator switch Occasional malfunction
61351415 Electronic battery isolator switch Permanent malfunction
61351432 Electronic battery isolator switch Deformed / distorted / bent
61351446 Electronic battery isolator switch Not connected
613514XX Electronic battery isolator switch
61351514 Relay module for wipers Occasional malfunction
61351515 Relay module for wipers Permanent malfunction
613515XX Relay module for wipers
61351614 Relay module for central locking Occasional malfunction
61351615 Relay module for central locking Permanent malfunction
61351643 Relay module for central locking Releases by itself
61351644 Relay module for central locking Locks by itself
613516XX Relay module for central locking
61351914 Door module for window regulators Occasional malfunction
61351915 Door module for window regulators Permanent malfunction
61351975 Door module for window regulators corroded
613519XX Door module for window regulators
61352114 Safety relay function in general module / body control unit Occasional malfunction
61352115 Safety relay function in general module / body control unit Permanent malfunction
613521XX Safety relay function in general module / body control unit
61352314 Wipe-wash/intermittent/intensive wash control unit Occasional malfunction
61352315 Wipe-wash/intermittent/intensive wash control unit Permanent malfunction
61352337 Wipe-wash/intermittent/intensive wash control unit Loose
613523XX Wipe-wash/intermittent/intensive wash control unit
61352714 Relay module for headlight cleaning Occasional malfunction
61352715 Relay module for headlight cleaning Permanent malfunction
613527XX Relay module for headlight cleaning
61353114 Check control module Occasional malfunction
61353115 Check control module Permanent malfunction
61353118 Check control module Incorrect/incomplete reading
613531XX Check control module
61353302 Trailer module Software error / internal device fault
61353314 Trailer module Occasional malfunction
61353315 Trailer module Permanent malfunction
61353337 Trailer module Loose
613533XX Trailer module
61353614 Anti-trapping function in general module / body control unit Occasional malfunction
61353615 Anti-trapping function in general module / body control unit Permanent malfunction
613536XX Anti-trapping function in general module / body control unit
61353714 Anti-trapping strip, door module Occasional malfunction
61353715 Anti-trapping strip, door module Permanent malfunction
613537XX Anti-trapping strip, door module
61353814 Control unit for sunroof anti-trapping strip Occasional malfunction
61353815 Control unit for sunroof anti-trapping strip Permanent malfunction
613538XX Control unit for sunroof anti-trapping strip
61353914 Light module, headlight vertical aim control Occasional malfunction
61353915 Light module, headlight vertical aim control Permanent malfunction
613539XX Light module, headlight vertical aim control
61354014 Light module, check control function Occasional malfunction
61354015 Light module, check control function Permanent malfunction
613540XX Light module, check control function
61354114 Head restraint control unit Occasional malfunction
61354115 Head restraint control unit Permanent malfunction
613541XX Head restraint control unit
61354214 Control unit for automatic rear lid Occasional malfunction
61354215 Control unit for automatic rear lid Permanent malfunction
613542XX Control unit for automatic rear lid
61354314 Automatic boot lid function in general module / body control unit Occasional malfunction
61354315 Automatic boot lid function in general module / body control unit Permanent malfunction
613543XX Automatic boot lid function in general module / body control unit
61354414 Central locking control unit Occasional malfunction
61354415 Central locking control unit Permanent malfunction
61354437 Central locking control unit Loose
613544XX Central locking control unit
61354914 Control unit for electromechanical/electrohydraulic soft-top Occasional malfunction
61354915 Control unit for electromechanical/electrohydraulic soft-top Permanent malfunction
61354937 Control unit for electromechanical/electrohydraulic soft-top Loose
613549XX Control unit for electromechanical/electrohydraulic soft-top
61355002 Control unit for sunroof (SHD) Software error / internal device fault
61355014 Control unit for sunroof (SHD) Occasional malfunction
61355015 Control unit for sunroof (SHD) Permanent malfunction
61355037 Control unit for sunroof (SHD) Loose
613550XX Control unit for sunroof (SHD)
61355214 Control unit for window regulators Occasional malfunction
61355215 Control unit for window regulators Permanent malfunction
61355237 Control unit for window regulators Loose
613552XX Control unit for window regulators
61355314 Control unit for rear window roller blind Occasional malfunction
61355315 Control unit for rear window roller blind Permanent malfunction
61355337 Control unit for rear window roller blind Loose
613553XX Control unit for rear window roller blind
61355714 Rain sensor control unit Occasional malfunction
61355715 Rain sensor control unit Permanent malfunction
613557XX Rain sensor control unit
61355837 Rain sensor control unit cover Loose
613558XX Rain sensor control unit cover
61355937 Rain sensor control unit cable duct Loose
613559XX Rain sensor control unit cable duct
61356014 Vehicle immobilizer (EWS) control unit Occasional malfunction
61356015 Vehicle immobilizer (EWS) control unit Permanent malfunction
613560XX Vehicle immobilizer (EWS) control unit
61356112 Vehicle immobilization (EWS) function in general module / body control unit Permanent failure
613561XX Vehicle immobilization (EWS) function in general module / body control unit
61356214 Vehicle immobilization (EWS) key transponcer Occasional malfunction
61356215 Vehicle immobilization (EWS) key transponcer Permanent malfunction
613562XX Vehicle immobilization (EWS) key transponcer
61356314 Vehicle immobilizer (EWS) ring antenna Occasional malfunction
61356315 Vehicle immobilizer (EWS) ring antenna Permanent malfunction
61356337 Vehicle immobilizer (EWS) ring antenna Loose
613563XX Vehicle immobilizer (EWS) ring antenna
61356414 Vehicle immobilizer (EWS) transceiver module Occasional malfunction
61356415 Vehicle immobilizer (EWS) transceiver module Permanent malfunction
613564XX Vehicle immobilizer (EWS) transceiver module
61356514 Light module, turn signal indicators Occasional malfunction
61356515 Light module, turn signal indicators Permanent malfunction
613565XX Light module, turn signal indicators
61356614 Light module, high beam/reversing light Occasional malfunction
61356615 Light module, high beam/reversing light Permanent malfunction
613566XX Light module, high beam/reversing light
61356714 Outside mirror, folding mirror control unit (E46) Occasional malfunction
61356715 Outside mirror, folding mirror control unit (E46) Permanent malfunction
613567XX Outside mirror, folding mirror control unit (E46)
61356814 Integrated universal remote control (garage door opener) Occasional malfunction
61356815 Integrated universal remote control (garage door opener) Permanent malfunction
61356886 Integrated universal remote control (garage door opener) does not light up
613568XX Integrated universal remote control (garage door opener)
61356914 Control unit for seat adjustment Occasional malfunction
61356915 Control unit for seat adjustment Permanent malfunction
61356937 Control unit for seat adjustment Loose
613569XX Control unit for seat adjustment
61357011 Load cutout function in general module / body control unit Occasional failure
61357012 Load cutout function in general module / body control unit Permanent failure
613570XX Load cutout function in general module / body control unit
61357112 Boot lid automatic soft-close function (SCA) in general module / body control unit Permanent failure
613571XX Boot lid automatic soft-close function (SCA) in general module / body control unit
61357211 Servotronic general module (control unit) Occasional failure
61357212 Servotronic general module (control unit) Permanent failure
613572XX Servotronic general module (control unit)
61357312 Radio remote closing function in general module / body control unit Permanent failure
613573XX Radio remote closing function in general module / body control unit
61357414 Door module for mirror adjustment Occasional malfunction
61357415 Door module for mirror adjustment Permanent malfunction
613574XX Door module for mirror adjustment
61357514 Door module for mirror heating Occasional malfunction
61357515 Door module for mirror heating Permanent malfunction
613575XX Door module for mirror heating
61357614 Door module for mirror memory Occasional malfunction
61357615 Door module for mirror memory Permanent malfunction
613576XX Door module for mirror memory
61357711 Active seat control unit Occasional failure
61357712 Active seat control unit Permanent failure
613577XX Active seat control unit
61357812 Electronic switch for electric fuel pump EKP (M-models) Permanent failure
613578XX Electronic switch for electric fuel pump EKP (M-models)
61358037 General module, housing Loose
613580XX General module, housing
61358137 Relay module, housing Loose
613581XX Relay module, housing
61358237 Door module, housing Loose
613582XX Door module, housing
61358337 Lamp Control Module, housing Loose
613583XX Lamp Control Module, housing
61358437 Trailer module, housing Loose
613584XX Trailer module, housing
61358514 Control unit for multifunction steering wheel (MFL) Occasional malfunction
61358515 Control unit for multifunction steering wheel (MFL) Permanent malfunction
61358599 Control unit for multifunction steering wheel (MFL) Fault code stored in diagnosis fault code memory
613585XX Control unit for multifunction steering wheel (MFL)
61359012 E46/2 Window raising function inoperative while closing door
61359014 E38 E39 E46 Rain sensor, various malfunctions
61359018 E53 Check control "Check oil" incorrect display
61359115 E38 E39 Car/key memory malfunction - general module fault
61359122 E36/7 EWS control unit, correcting vehicle data
61359202 E65 E66 Various electrical problems
61359265 E46 (with SA 459) Outside mirror reset inaccurate
61359318 E39 M54 B25 Coding data LCM - "Check engine oil level" in instrument cluster
61359322 E53 M54 Outside mirror does not fold in when reverse gear is engaged
61359502 E53 Outside mirror remains in folded-in position
6135XXXX Control units, modules and housings
61360114 Motor relay, rear lid Occasional malfunction
61360115 Motor relay, rear lid Permanent malfunction
61360137 Motor relay, rear lid Loose
613601XX Motor relay, rear lid
61360214 Relay, A/C compressor Occasional malfunction
61360215 Relay, A/C compressor Permanent malfunction
61360237 Relay, A/C compressor Loose
61360299 Relay, A/C compressor Fault code stored in diagnosis fault code memory (no warning lamp)
613602XX Relay, A/C compressor
61360314 Relay, windscreen wipers Occasional malfunction
61360315 Relay, windscreen wipers Permanent malfunction
61360337 Relay, windscreen wipers Loose
613603XX Relay, windscreen wipers
61360414 Starter interlock relay/module Occasional malfunction
61360415 Starter interlock relay/module Permanent malfunction
61360437 Starter interlock relay/module Loose
613604XX Starter interlock relay/module
61360514 Low beam relay Occasional malfunction
61360515 Low beam relay Permanent malfunction
61360537 Low beam relay Loose
613605XX Low beam relay
61360614 Fanfare horn relay Occasional malfunction
61360615 Fanfare horn relay Permanent malfunction
61360637 Fanfare horn relay Loose
613606XX Fanfare horn relay
61360714 Unloader relay, headlight/heating Occasional malfunction
61360715 Unloader relay, headlight/heating Permanent malfunction
61360737 Unloader relay, headlight/heating Loose
613607XX Unloader relay, headlight/heating
61360814 Relay, fog lights Occasional malfunction
61360815 Relay, fog lights Permanent malfunction
61360837 Relay, fog lights Loose
613608XX Relay, fog lights
61360914 Relay, start valve Occasional malfunction
61360915 Relay, start valve Permanent malfunction
61360937 Relay, start valve Loose
613609XX Relay, start valve
61361014 Relay, auxiliary fan Occasional malfunction
61361015 Relay, auxiliary fan Permanent malfunction
61361037 Relay, auxiliary fan Loose
613610XX Relay, auxiliary fan
61361114 Relay, high beam Occasional malfunction
61361115 Relay, high beam Permanent malfunction
61361137 Relay, high beam Loose
613611XX Relay, high beam
61361214 Relay, pressure sensor Occasional malfunction
61361215 Relay, pressure sensor Permanent malfunction
61361237 Relay, pressure sensor Loose
613612XX Relay, pressure sensor
61361514 Relay, power windows Occasional malfunction
61361515 Relay, power windows Permanent malfunction
61361537 Relay, power windows Loose
613615XX Relay, power windows
61361614 Relay, level control Occasional malfunction
61361615 Relay, level control Permanent malfunction
61361637 Relay, level control Loose
613616XX Relay, level control
61361714 Relay, sunroof (SHD) Occasional malfunction
61361715 Relay, sunroof (SHD) Permanent malfunction
61361737 Relay, sunroof (SHD) Loose
613617XX Relay, sunroof (SHD)
61361814 Relay, heater/air conditioner blower Occasional malfunction
61361815 Relay, heater/air conditioner blower Permanent malfunction
61361837 Relay, heater/air conditioner blower Loose
613618XX Relay, heater/air conditioner blower
61361914 Relay, heated rear window Occasional malfunction
61361915 Relay, heated rear window Permanent malfunction
61361937 Relay, heated rear window Loose
613619XX Relay, heated rear window
61362014 Relay, pop-up headlights Occasional malfunction
61362015 Relay, pop-up headlights Permanent malfunction
61362037 Relay, pop-up headlights Loose
613620XX Relay, pop-up headlights
61362114 Relay, wiper pressure control Occasional malfunction
61362115 Relay, wiper pressure control Permanent malfunction
61362137 Relay, wiper pressure control Loose
613621XX Relay, wiper pressure control
61362214 Relay, parking light cold scan Occasional malfunction
61362215 Relay, parking light cold scan Permanent malfunction
61362237 Relay, parking light cold scan Loose
613622XX Relay, parking light cold scan
61362314 Battery isolating relay Occasional malfunction
61362315 Battery isolating relay Permanent malfunction
61362337 Battery isolating relay Loose
613623XX Battery isolating relay
61362414 Relay, intensive wash Occasional malfunction
61362415 Relay, intensive wash Permanent malfunction
61362437 Relay, intensive wash Loose
613624XX Relay, intensive wash
61362514 Relay, air suspension Occasional malfunction
61362515 Relay, air suspension Permanent malfunction
61362537 Relay, air suspension Loose
613625XX Relay, air suspension
6136XXXX Relay
61370014 Safety switch (for rear windows) Occasional malfunction
61370015 Safety switch (for rear windows) Permanent malfunction
61370029 Safety switch (for rear windows) Sticking/jammed
61370037 Safety switch (for rear windows) Loose
613700XX Safety switch (for rear windows)
61370102 Centre console control unit, front Software error / internal device fault
61370114 Centre console control unit, front Occasional malfunction
61370115 Centre console control unit, front Permanent malfunction
613701XX Centre console control unit, front
61370202 Centre console control unit, rear Software error / internal device fault
61370214 Centre console control unit, rear Occasional malfunction
61370215 Centre console control unit, rear Permanent malfunction
613702XX Centre console control unit, rear
61370314 Battery sensor (IBS) Occasional malfunction
61370315 Battery sensor (IBS) Permanent malfunction
613703XX Battery sensor (IBS)
61370414 Sport switch (driving dynamics control) Occasional malfunction
61370415 Sport switch (driving dynamics control) Permanent malfunction
61370429 Sport switch (driving dynamics control) Sticking/jammed
61370437 Sport switch (driving dynamics control) Loose
61370486 Sport switch (driving dynamics control) does not light up
613704XX Sport switch (driving dynamics control)
61370502 Control unit for steering wheel electronics Software error / internal device fault
61370514 Control unit for steering wheel electronics Occasional malfunction
61370515 Control unit for steering wheel electronics Permanent malfunction
61370579 Control unit for steering wheel electronics incorrect connection /contact
613705XX Control unit for steering wheel electronics
61370614 Connection socket AV Occasional malfunction
61370615 Connection socket AV Permanent malfunction
613706XX Connection socket AV
61370714 Connection socket, headset Occasional malfunction
61370715 Connection socket, headset Permanent malfunction
613707XX Connection socket, headset
6137XXXX Switch
61380014 Control unit (micro) power module (MPA) Occasional malfunction
61380015 Control unit (micro) power module (MPA) Permanent malfunction
613800XX Control unit (micro) power module (MPA)
61380114 Passive entry (comfort access) Occasional malfunction
61380115 Passive entry (comfort access) Permanent malfunction
613801XX Passive entry (comfort access)
61380214 Passive go (comfort access) Occasional malfunction
61380215 Passive go (comfort access) Permanent malfunction
613802XX Passive go (comfort access)
61380314 Passive exit (comfort access) Occasional malfunction
61380315 Passive exit (comfort access) Permanent malfunction
613803XX Passive exit (comfort access)
6138XXXX Control units, modules
61610434 Wiper connecting rod Stiff to move
61610439 Wiper connecting rod Unpleasant noises
616104XX Wiper connecting rod
61610513 Wiper shaft bearing with crank Broken
61610521 Wiper shaft bearing with crank Worn
61610539 Wiper shaft bearing with crank Unpleasant noises
616105XX Wiper shaft bearing with crank
61610639 Wiper arms Unpleasant noises
61610640 Wiper arms Poorly adjusted / outside tolerance
616106XX Wiper arms
61610756 Wiper blade Poor running characteristics / friction
616107XX Wiper blade
6161XXXX Windscreen wipers
61620421 Rear window wiper shaft bearing Worn
616204XX Rear window wiper shaft bearing
61620539 Rear window wiper arm Unpleasant noises
61620540 Rear window wiper arm Poorly adjusted / outside tolerance
616205XX Rear window wiper arm
61620656 Rear window wiper blade Poor running characteristics / friction
616206XX Rear window wiper blade
61620714 Rear wiper coupling Occasional malfunction
61620715 Rear wiper coupling Permanent malfunction
616207XX Rear wiper coupling
61629037 E53 Covering cap of rear window wiper loose
6162XXXX Rear window wiper
61660137 Windscreen washer system, washer fluid reservoir Loose
61660148 Windscreen washer system, washer fluid reservoir Leaking
616601XX Windscreen washer system, washer fluid reservoir
61660213 Windscreen washer system, lines/valves/connectors Broken
61660248 Windscreen washer system, lines/valves/connectors Leaking
616602XX Windscreen washer system, lines/valves/connectors
61660337 Windscreen washer system, spray nozzles Loose
61660340 Windscreen washer system, spray nozzles Poorly adjusted / outside tolerance
61660348 Windscreen washer system, spray nozzles Leaking
61660376 Windscreen washer system, spray nozzles dirty / blocked
616603XX Windscreen washer system, spray nozzles
61660437 Windscreen washer system, auxiliary reservoir for intensive wash Loose
61660448 Windscreen washer system, auxiliary reservoir for intensive wash Leaking
616604XX Windscreen washer system, auxiliary reservoir for intensive wash
61660611 Windscreen washer system, spray nozzle heating Occasional failure
61660612 Windscreen washer system, spray nozzle heating Permanent failure
616606XX Windscreen washer system, spray nozzle heating
61660701 Windscreen washer system, fluid reservoir cover Cracked / broken / torn off
616607XX Windscreen washer system, fluid reservoir cover
6166XXXX Windscreen washer system
61670113 Headlight cleaning system, lines/valves/connectors Broken
61670137 Headlight cleaning system, lines/valves/connectors Loose
61670148 Headlight cleaning system, lines/valves/connectors Leaking
616701XX Headlight cleaning system, lines/valves/connectors
61670229 Headlight cleaning system, spray/stroke nozzle Sticking/jammed
61670237 Headlight cleaning system, spray/stroke nozzle Loose
61670240 Headlight cleaning system, spray/stroke nozzle Poorly adjusted / outside tolerance
61670248 Headlight cleaning system, spray/stroke nozzle Leaking
61670276 Headlight cleaning system, spray/stroke nozzle dirty / blocked
616702XX Headlight cleaning system, spray/stroke nozzle
61670313 Headlight cleaning system, water tank Broken
61670337 Headlight cleaning system, water tank Loose
61670348 Headlight cleaning system, water tank Leaking
616703XX Headlight cleaning system, water tank
61670401 Headlight cleaning system, cap for water tank Cracked / broken / torn off
616704XX Headlight cleaning system, cap for water tank
61679023 E46 S54 (with SA 502) false indication of wash water level
6167XXXX Headlight cleaning system
61680137 Rear window washer system, washer fluid reservoir Loose
61680148 Rear window washer system, washer fluid reservoir Leaking
616801XX Rear window washer system, washer fluid reservoir
61680329 Rear window washer system, spray nozzle Sticking/jammed
61680337 Rear window washer system, spray nozzle Loose
61680340 Rear window washer system, spray nozzle Poorly adjusted / outside tolerance
61680348 Rear window washer system, spray nozzle Leaking
61680376 Rear window washer system, spray nozzle dirty / blocked
616803XX Rear window washer system, spray nozzle
61680401 Rear window washer system, washer fluid reservoir cover Cracked / broken / torn off
616804XX Rear window washer system, washer fluid reservoir cover
61689014 E36/7 coupe malfunction in rear window washer system
6168XXXX Rear window washer system
61XXXXXX General vehicle electrics
62100102 Electronic body module (EKM) (E31) Software error / internal device fault
621001XX Electronic body module (EKM) (E31)
6210XXXX Instrument cluster
62110013 Instrument cluster, housing/glass cover Broken
62110037 Instrument cluster, housing/glass cover Loose
621100XX Instrument cluster, housing/glass cover
62110618 Fuel gauge Incorrect/incomplete reading
621106XX Fuel gauge
62110718 Coolant temperature gauge Incorrect/incomplete reading
621107XX Coolant temperature gauge
62111118 Outside temperature display Incorrect/incomplete reading
621111XX Outside temperature display
62111414 Encoding connector, instrument cluster Occasional malfunction
62111415 Encoding connector, instrument cluster Permanent malfunction
621114XX Encoding connector, instrument cluster
62111714 Automatic LCD rheostat function Occasional malfunction
62111715 Automatic LCD rheostat function Permanent malfunction
621117XX Automatic LCD rheostat function
62111811 Distance recorder reset knob Occasional failure
62111812 Distance recorder reset knob Permanent failure
621118XX Distance recorder reset knob
62111911 Check-Control button Occasional failure
62111912 Check-Control button Permanent failure
621119XX Check-Control button
62112011 LCD display Occasional failure
62112086 LCD display does not light up
621120XX LCD display
62112314 Acoustic transmitter in instrument cluster Occasional malfunction
62112315 Acoustic transmitter in instrument cluster Permanent malfunction
621123XX Acoustic transmitter in instrument cluster
62112612 Tachometer early warning zone Permanent failure
621126XX Tachometer early warning zone
62112718 Power reserve indicator (residual torque indication) Incorrect/incomplete reading
621127XX Power reserve indicator (residual torque indication)
62119002 E46 ASC+T cannot be deactivated or faulty indication
62119080 E36/7 I-Instrument cluster, various fault patterns - short circuit, connector X16
62119518 E46 Fuel gauge incorrect (faulty coding data)
62119618 E39 E53 Oil level warning indicator - LCM encoding data error
62119683 E46 S54 Continuous tone on engaging reverse gear
62119718 E65 E66 Clock wrong
6211XXXX Instrument cluster
62120013 Speedometer Broken
62120018 Speedometer Incorrect/incomplete reading
62120037 Speedometer Loose
621200XX Speedometer
62120118 Distance recorder Incorrect/incomplete reading
621201XX Distance recorder
62120318 Total trip recorder Incorrect/incomplete reading
621203XX Total trip recorder
6212XXXX Speedometer and input shaft
62130013 Tachometer Broken
62130018 Tachometer Incorrect/incomplete reading
62130037 Tachometer Loose
621300XX Tachometer
62130118 Clock (analogue) Incorrect/incomplete reading
62130186 Clock (analogue) does not light up
621301XX Clock (analogue)
62130318 Digital clock Incorrect/incomplete reading
62130386 Digital clock does not light up
621303XX Digital clock
62130414 Clock controls (analogue) Occasional malfunction
62130415 Clock controls (analogue) Permanent malfunction
62130486 Clock controls (analogue) does not light up
621304XX Clock controls (analogue)
62130511 Service interval indicator reset Occasional failure
62130512 Service interval indicator reset Permanent failure
621305XX Service interval indicator reset
62130618 Voltmeter Incorrect/incomplete reading
621306XX Voltmeter
62131018 Economy control (energy control) Incorrect/incomplete reading
621310XX Economy control (energy control)
62131118 Service interval indicator / condition ****d service (CBS) indicator Incorrect/incomplete reading
621311XX Service interval indicator / condition ****d service (CBS) indicator
62131318 Oil temperature gauge Incorrect/incomplete reading
621313XX Oil temperature gauge
62131414 Control elements for digital clock Occasional malfunction
62131415 Control elements for digital clock Permanent malfunction
62131486 Control elements for digital clock does not light up
621314XX Control elements for digital clock
62131511 Multi-imformation display (MID) Occasional failure
62131512 Multi-imformation display (MID) Permanent failure
62131518 Multi-imformation display (MID) Incorrect/incomplete reading
62131586 Multi-imformation display (MID) does not light up
621315XX Multi-imformation display (MID)
62131614 Controls for multi information display (MID) Occasional malfunction
62131615 Controls for multi information display (MID) Permanent malfunction
62131686 Controls for multi information display (MID) does not light up
621316XX Controls for multi information display (MID)
62132011 MID telephone functions Occasional failure
62132012 MID telephone functions Permanent failure
621320XX MID telephone functions
62132114 MID clock functions Occasional malfunction
62132115 MID clock functions Permanent malfunction
621321XX MID clock functions
62132214 MID on-board computer functions Occasional malfunction
62132215 MID on-board computer functions Permanent malfunction
621322XX MID on-board computer functions
62132314 MID radio functions Occasional malfunction
62132315 MID radio functions Permanent malfunction
621323XX MID radio functions
62132418 Boost pressure indicator (Cooper S) Incorrect/incomplete reading
621324XX Boost pressure indicator (Cooper S)
6213XXXX Tachometer, clock and similar items
62140018 Speed range program display Incorrect/incomplete reading
6131XXXX Switch
61330037 Horn Loose
613300XX Horn
6133XXXX Horn
6136XXXX Relay
6137XXXX Switch
616106XX Wiper arms
621106XX Fuel gauge
621300XX Tachometer
621306XX Voltmeter
