# Provides for relaxed highway travel at preset speeds
# Features safe, reliable performance that improves gas mileage and fuel economy
# Avoid unintentional speeding and driving fatigue
# Easy installation
# VSS compatible, requires no additional accessories for vehicles manufactured from 1985-97
# Dash mounted command switch
# On/Off Switch
# Set Speed-Locks in predetermined speed with a touch of a button
# Coast-Reduce and/or reset cruise to lower speed
# Resume- Braking disengages the cruise, pressing the 'resume' function accelerates vehicle to the previous set speed
# Accel- Press and hold automatically accelerates the vehicle
# Disengage- 3 Methods; tap brake or depress clutch pedal, press 'off', or turn off engine Options
# OE Handles - A variety of handles with OE cosmetics and features can replace the dash-mounted control switch
# CCS-202 Vacuum Canister for use on vehicles with small engines that require an artificial vacuum source
# Easy installation
# On/Off Switch
