زينون ديجيتال (ياباني 100%)
  • زينون ديجيتال (ياباني 100%)
    LIMITED TIME SALE OFFER
    High Intensity Discharge (HID) is the latest technology in automotive lighting. It replaces the filament of the light bulb with xenon gas by utilizing the gas discharge principle, an arc of light is created between two electrodes in a small capsule filled with a mixture of xenon gas and halide salts. When high voltage is applied, the gas is ignited to produce an arc of light.
    Xenon HID outputs three times the amount of light compared to a standard halogen bulb. The lamps also glow at a higher light temperature and gives it its distinct color and appearance.
    VOLT HID CONVERSION KIT (Japanese parts only)
    Volt HID Kits offer the latest in High Intensity Discharge (HID) Xenon technology. Volt HID utilizes ultra slim-line ballasts with next generation patented Digital+ technology for optimal light output and ballast efficiency. This exclusive HID conversion kit is the leader in digital ballast technology and will provide you with a level of performance and quality that is unmatched by similar digital HID products found on the market today. Volt HID Digital+ ballasts are the smallest and lightest ballasts manufactured today. This new ultra-slim design will enable the product to be used in a wider variety of applications.
    - Patented Digital+ technology for optimal light output & ballast efficiency
    - Ultra-slim design and light weight ballasts
    - Quality Japanese parts
    - CE, UL, and E4 certified OEM Grade Xenon HID Components
    - Rubber injected waterproof/shockproof ballasts
    - Laser aligned HID Xenon Bulbs to ensure optically correct beam patterns
    - Full 1 year replacement warranty
    BALLAST SPECIFICATIONS:
    -These ballasts are equipped with next generation Digital+ Technology allowing the ballast to exert greater control over electrical flow to the bulb. As a result, the voltage output to the bulb is more consistent and stable, resulting in constant lumen output, brightness stability, with no flickering unlike some thin ballast designs on the market.
    - Automatic reverse polarity protection.
    - Dual EMI Filter protection Circuit shielding.
    - Ultra-slim design and light weight: Our ballast measures 3" x 2 5/8" x 9/16" (7.6cm x 6.6cm x 1.4cm), and weighs only 7 oz (200 g).
    - Volt Digital+ ballasts are uniquely designed for aftermarket applications as they are rubber injected to protect against harsh weather conditions
    To ensure optimal light output, the Volt HID Kit uses laser calibrated bulbs so that the focal point of the HID bulb matches the focal point of the corresponding halogen bulb. This will result in both proper fitment and optically correct beam patterns. These bulbs are rated at approximately 2500 hours of use – same rating as high end Philips and Osram bulbs. Industry leading AMP style connectors are used to ensure proper water tight connections. Volt HID is manufactured in an industry leading high tech facility. Due to stringent manufacturing standards, this product line carries ISO certification, CE and UL safety listed, and is E4 certified. This product carries a one year legitimate warranty.
    https://www.facebook.com/GearOneForCarAccessories
    ها ؟؟؟؟!!!!
      المطلوب كام و المكان فين ؟
      [FONT=Comic Sans MS]Life is about yes & no, we choose when[/FONT]
        يا باشا كل الكلام دة صيني الأحسن انك تشتري من هنا بضمان عشان لو أي حاجة باظت تلا بديل، أنا جربت أنواع كتير أفضل حاجة الحاجات البتنزل أصلي فالعربية بعد كدة كل ذي بعد
