Tiida 2015 or Renault Megane 2015?
  • Tiida 2015 or Renault Megane 2015?
    Which do you recommend Tiida 2015 or Renault Megane 2015
    from point of view of:
    - Spares prices & availability
    - Car performance
    - Air condition
    - Resale value
    - Tawkeel & maintenance
    - Running cost
    noting than i dun see Megane in streets at all,feelig that i like it but it's risky to buy it due to this & the fact of lot of sensors in it? so is getting Tiida is more into safe side?
    the brand new Megane got the engine of the Tiida (hr16de) as well as the (X-tronic CVT) gearbox which means more reliability with the beauty of French cars and a bit more efficient AC, the megane has a good handling feeling in leanings and turns and also has a better suspension system which means good stability during manoeuvres ... If I were you I'd never hesitate to get the brand new megane and to release the confusion you can test drive both cars to make the decision a bit easier
      المشاركة الأصلية كتبت بواسطة ENG.MaRk مشاهدة المشاركة
      But i dun see Megane at all in streets, although i knew it's available since almost 2010 ! which is a question mark for me ?
        المشاركة الأصلية كتبت بواسطة Naa22 مشاهدة المشاركة
        العربيه بدأت تنتشر جدا خصوصا في جامعتي حاليا 5 غيري معاهم و بشوفها بشكل ملحوظ في الشارع الفتره الأخيرة و في فرق بين ميجان 2010 و 2015 , 6 سرعات CVT بدل 4 و موتور نيسان 117HP
        بالنسبة للمقارنة مش عشان هي معايا بس فعلا متتقارنش بالتيدا العربية ثابته جدا و شكلها ملفت اكتر جوه و بره انا مش بقلل من التيدا بس ده رأيي بصراحه
        لو تتقارن يبقي بفورد فييستا او سيات ليون و لو اني مش بفضل الليون عشان الفتيس dsg
          prevalence is not the only evidence you need to prove that a specific car is good !!!
          BTW the Megane is a copy from the Fluence but more beautiful and hatchback instead of being a sedan, If you really intend to get one of them then regardless peoples' opinions you are the only judge :)
          FYI Tiida is not widespread also :D
            المشاركة الأصلية كتبت بواسطة MazenSamyZayed مشاهدة المشاركة
            howa vitesse CVT of Megane mawgood from year kam in it?
            Seat Leon kanet 3agbaany gedan bas mawdoo3 el DSG & Turbo motor wa2afny
            El fekra eny mesh bakaren only shakl,, momken Tiida matkonsh a7la shakl bas Tiida optimum f kolooo,, 3arabeya has good reputation, mafeeshash moshkela aw 3eeb major,, good performace, good tawkeel,, reasonable prices,, fa el howa optimum f kolo, plus lama etfaragt 3aleeha quality gowa w 2aflet el bab mat2elesh 3an el Megane
            Since u have Megane, momken te2oly el tawkeel eh el nezaam w tedeeny fekra 3an prices?
              Tida
                Asl mawdoo3 el copy may7elesh el moshkela le sabab,, spare parts momken teb2a different w bema enaha mesh montashera fa 7ato3od testana le7ad ma el tawkeel yegeeb el spares w mesh 7ate3raf tegebha men barra
                New Tiida mesh montashera awwwy bas still mawgooda aktar b keteer men Megane,,w heya delwa2ty entasharet nesbeyan laken Megane ana almost shoft 2 in real fel street mesh aktar fa deh 7aga te2le2, plus megane bey2olo feha sensors w technology 3alyaa
                w bardo for comparison Resale el Tiida akeed much more btetter than Megane
                El fekra en el mawdoo3 mo7ayer la2en ana shadaany awwy el Megane bas khayfa agebha atdabbes aw andam fa ba2ool akhaleny fel safe side with Tiida
                  بصراحه مش متأكد اوي بس اعتقد دي اول سنه cvt للميجان
                  توكيل رينو محترم , و هوضحلك اسعار الصيانه في الصورة
                  بصي من الأخر عشان اكون امين معاكي العربيه فعلا مبسوط بيها جدا كأداء و ثبات و شكل و عاليه علي المطبات و مع ان ااجنط 17 بس مش هتحسي برزع بالعكس العربيه ناعمه و بعد 15.000كم مفيش غير 1-صوت السماعات مش قد كده بالنسبالي يعني مش زي سيات و فورد و اوبل مش مبسوط اوي بيها 6\10
                  2-تيل الفرامل فيه مشكله و هيصفر معاكي بسرعه و التوكيل بينضفه كل ما اروح و يصفر تاني
                  3-الكاوتش الكونتينينتال 205\55 ٌR17 مش متوفر في السوق ( سألت في اسكندريه بس ) لو حصل حاجه هتضطري تجيبي نوع تاني
                  4-المرايات مش ضم كهرباء و الكلاكس صوته مستفز جدا بالنسبالي
                  بس دي مش مشاكل بسيطه عموما
                  الملفات المرفقة
