ارجو الافادة فى تعديل لادا 2107 موديل 2004 روسىcarputor
  • ارجو الافادة فى تعديل لادا 2107 موديل 2004 روسىcarputor
    الفلاتر الرياضية
    البوجيهات ال3 شمعة ايه نظامها
    سوست و مساعدين رياضية
    دبرياج رياضى
    فين احسن مكان لتركيب
    electric windows
    i know many q?
    and how much and where
    to get these item
    thank you for every thing
    Hi ...talkin about the air filter you can go with k&n for carb engines....it will add more noisy sound and a little HP increase and for the sparks plugs use the manual recommended type anything above will be a waste of money and you are asking about a sport suspension system for a lada !!! it will have a negative side more than positive one that you will feel more unstable at lower speeds and as i know lada is not that fast car ...only in case you speed more
    than 120 kph and you feel problems
    THERE IS NO SPORT CLUTCH FOR LADA 2107
    [URL="http://www.forumbars.co.uk/details.php?image_id=1091"][IMG]http://www.forumbars.co.uk/data/media/13/8553.png[/IMG][/URL]
    [I][COLOR=royalblue]I Love Anything Fast Enough To Do Something Really Stupid With It[/COLOR][/I]
      thank you dear boss
      but i need to know spark plug don"t make anything why
      electric effect or not
      and what it suitable size to tear
      thank you for your knowledge
        where
          I'LL try to make it clear to you
          as i understand you you were asking a question about using the 3 ground electrodes spark plug with the car first of all every type of car have a limit so if your car uses a 2 ground electrodes so the manufacturer realize that it will burn the whole mix of gas &air
          so there will be no reason for pushing the engine to BURN MORE GAS more than BURN THE CURRENT GAS WITH
          efficiency >>as i believe you will be consuming more gas which may fake the effect of more horse power
            if you mean the racing spark plugs ...which in my mind increase performance for good...those are not made for a street car but if you want to install them anyway??okay ..those spark plugs are made for heavy duty work
            They are not affected by higher heat levels
            which mean they made for engines that fine-tuned to produce maximum horse power(which mean high engine temp
            AND THEY work good under heavy vibration level that made by turbo charged engines
            they increase performance of the car
            they don't create a performance
            hope that helped
              with my thousands of thanks for you effort
              but i"d like to know the suitable tear to my front and rear and electric windows effect or not
                المشاركة الأصلية كتبت بواسطة day22222222 مشاهدة المشاركة
                Didn't get what did you mean exactly
                totally confused
                  يا راجل لو دماغك ف التعديل لاسعه اوي كدا غيّر العربيه وأبتدي من الاول
                  لان الصرف على اللادا حراااااااام لو عايز أداء!!
                  [FONT="Book Antiqua"][I][glow1=#7a3131]Dr.Ahmed AlSherif[/glow1][/I][/FONT]
                    thank you
                    with more respect for pilot replay
                      Yeah It's very hard to work on a lada
                      it made me wonder what could be used in An engine swap
                      NOTHING!!
