Performance Pack 1 Astra G 1.6/1.8/2.0
Gives gains of 5bhp + over standard, and also lays the foundation for the other upgrades.
We recommend the fitment of this stage before any other modifications take place.
FREE fitting!
Pack Includes :
-NGK Spark Plugs (Pictured)
-Magnecor Leads
-Adjustable Fuel Pressure Reg.
Performance Pack 2 Astra G 1.6/1.8/2.0
With FREE Fitting!
Gives Increases of 12bhp + From Standard.
Kit Includes :
-Software
-Induction kit
-Exhaust System
The Software vastly improves drivability and throttle response while the induction kit and exhaust help the engine to breathe better, also improving throttle response and the car will feel much more eager to rev!
Performance Pack 3 Astra G 1.6/1.8/2.0
Gives Gains of 20bhp+ over Standard
Pack Includes :
-New Performace Camshafts
-4 Branch Manifold (Pictured)
-Gas Flowed Head
The Camshaft profile has been specifically chosen to give maximum torques and response while retaining a good standard of idle. Camshaft Vernier pullys are also available to aid setting up and accurate valve timing.
The Regal cylinder heads are gas flowed and have polished and ported internals with heavier poundage springs.
Performance Pack 4 Astra G 1.6/1.8/2.0
Gains of over 30 bhp from Standard.
The Ultimate Performance Package, Includes the Fitment of Dbilas Throttle Bodies.
-Simple Self Fit (3 hours)
-Retains OE Air Mass Meter and wiring and ECU to retain all OBD diagnosis
-4 x 45mm Throttles (one per cylinder)
-Retains a smooth clean idle, even with large cams
-Full RPM control load adjustment
-Good Economy
-Good Cold Starting
-Meets all E2 Emissions standards and MOT/TUV approved
-For further power, larger injectors, cams and ECU modifications are also available on request.
مطلوب تعليق الخبراء مع بعض الشرح إن أمكن
FREE fitting!
Pack Includes :
-Magnecor Leads
With FREE Fitting!
Kit Includes :
-Software
-Induction kit
-Exhaust System
Pack Includes :
-Gas Flowed Head
-Good Economy
-Good Cold Starting
