معادله صعبه nos + ecu !!
  • معادله صعبه nos + ecu !!
    سلام عليكم
    عندي مشكله
    عاوز اركبPiggy back ECU لعربيتي مع العلم ان عليها نايترس و معروف انه مينفعش علشان ال ECU بياخر الشراره و ده مينفعش مع النايترس الي بيحتاج شراره متقدمه !!
    مع العلم اني محتاج ال ECU جدا علشان تعديلات معينه و مستحيل اتنازل عن ال NOS !
    يا تري الاقي حل للمعادله الصعبه دي!
    I think that you Can Adjust the ignition Timing using a piggyback , I saw it before in a YouTube video, The guy in the video Adjust the ignition Timing By connecting the piggyback to a laptop.
    I will search for further info about this subject
    Peace Out
    [CENTER][aldl]http://i.imagehost.org/0676/38027_444496797153_505567153_5939847_1278553_n.jpg[/aldl] [CENTER] One mans trash is another mans treasure one mans pain is the next mans pleasure ! [/CENTER]
      Thanks Ignition
      there is some kinds of ECUs with this option specially the stand alone ECUs but it's very expensive
      I need to install piggy back for major tuning which already in hand now
      looking further for more information
        المشاركة الأصلية كتبت بواسطة Evo مشاهدة المشاركة
        سلام عليكم
        عندي مشكله
        Hello Evo
        After Reading a lot about this, here's my conclusions ,
        1st- You need to Retard the ignition timing not to advance it !!
        2nd- Stand alone Ecu is your best Choice but it is kinda expensive.
        3rd- Get more information about" e-manage ultimate " It is a piggy back which can actually control the ignition Timing Separate from you Stock ECU
        4th- Performance chips will do the trick too
        All the luck Man
        And keep me updated
          Q: Can I have a performance "chip" in my ECU while using my nitrous system?
          A: Generally the answer is NO. Most performance "chips" on the market advance ignition timing to gain additional horsepower. This additional timing, when using nitrous, can cause engine damaging detonation. The only exception to this are "chips" that have been specifically programmed for nitrous use.
          Ignition
          That was the answer from the ZEX NOS Sysytems tech help engineers on there ... site !!
            stand alone ecus but it's very expensive
            دا الحل الوحيد المضمون !!!
            it is recommended that you
            retard the ignition timing 2 degrees for every 50 hp worth of nitrous used
            [CENTER][B]عليها السلام[/B]
              Ignition
              Evo, I am Talking about a Custom made performance Chip Which can be modified specifically for your Car ,not a Generic one !!!
                المشاركة الأصلية كتبت بواسطة Ignition مشاهدة المشاركة
                [OVERLINE]
                [OVERLINE]
                That's exactly the point i want to avoid
                The main reason that is my car's ECU dosn't accept any add on's chips only Piggy backs to be connected or to be replaced completely with stand alone whis is very expensive.
                So simply i cann't have customized chip also i don't need stand alone ECU
                The only option available for me is piggy back .
                MOMO1000
                than'ks for you post and nice ride too
                [/OVERLINE]
                [/OVERLINE]
                  Check out the " E-manage ultimate " , Get more info about it
                  Sorry for being not too helpful, But i have done My best
                  Peace out And Good luck
                    انا عندي استفسار بسيط
                    يعني المنتدي عربي ييبقي نكتب عربي
                    صبرني يارب
                    انا انسان عادي جداا.مسلم . اخطيء .واصيب . مرجعيتي هي القران والسنة وفقه الائمة الاربعة يعني انا ...[B][/B]
                      [OVERLINE] [/OVERLINE][OVERLINE][/OVERLINE][OVERLINE]
                      [OVERLINE]
                      [OVERLINE]
                      Ignition انا متشكر جدا
                      انا عارف الE-manage و معروض عليا واحد فعلا لكن كان لازم اعرف هىنفع الاول ولا لاء
                      عموما شكرا امجهودك الرائع و شكلها هترسي على Stand alone
                      mrwho1982
                      متزعلش كده و ادينى رديت بلعربي علشان خاطرك
                      [/OVERLINE]
                      [/OVERLINE]
                      [/OVERLINE]
                        المشاركة الأصلية كتبت بواسطة mrwho1982 مشاهدة المشاركة
                        صبرني يارب
                        نص الكلام اللى مكتوب ملوش مصطلحات فى ااعربى اساسا
                        [/URL][/CENTER]
                        [/URL]
                          Evo باشا .... اخبار الملي معاك اية ؟ .... فلوس كام ؟؟
                            انجليزي ده يا مرسي؟
                            يا شباب الحمد لله معظم الناس اللي في نايل موتورز ناس تعليمها عالي يعني بيفهموا انجليزي
                            المنتدي زي ما هو واضح باللغة العربية يبقي لازمتها ايه بقي الانجليزي ؟
                            اعتزوا بنفسكم وبلغتكم يا جماعة ولو فيه اي مصطلحات انجليزية يتعذر ترجمتها اكتبوها زي ما هي مش معضلة يعني
                            [CENTER][URL="http://www.nilemotors.net/Nile/70645-131.html"][SIZE=2]البوم صور 131[/SIZE][/URL][/CENTER]
                            [CENTER][URL="http://www.nilemotors.net/Nile/67141-a.html"][SIZE=2]لغة الكلاكسات[/SIZE][/URL][/CENTER]
                            [CENTER][URL="http://www.nilemotors.net/Nile/70929-a.html"][SIZE=2]استمع لاذاعة القرآن الكريم[/SIZE][/URL][/CENTER]
                              [OVERLINE]
                              [OVERLINE]
                              [/OVERLINE]
                              [/OVERLINE]
                              [/OVERLINE]
                              المشاركة الأصلية كتبت بواسطة tabeb مشاهدة المشاركة
                              انجليزي ده يا مرسي؟
                              المشاركة حتبقى بالمنظر دة... تحيل كل كلمتين تقلب عربى و بعدها انجليزى و بعدها عربى... يعنى لو عايز تكتب رد محترم و فية شوية شرح كويسين حتشتغل محولجى بين العربيى و الانجليزى لحد ما يجيلك استبحس
                              [/URL][/CENTER]
                              [/URL]
