please help
  • please help
    بحس بتخبيط مثل صوت القلة البنشرب منها
    بحس بيها بعد ال90كم
    خاصا وانا دايس بنزين جامد اما لما اسيب البنزين وانا على نفس السرعة الصوت بيختفى
    السيارة سينا
    ياريت تزويدنا بسنة صنع السياره......وآخر شغل فى العفشه .....وعدد الكيلومترات المقطوعه للآن.....ولو فيه أى صيانه تانيه أتعملت....ياريت نعرفها برضه
      seina 2002
      92000
      all shock absorbers is changed all rubber brushing
      and a good mentaince
      in tawkeel
      in 90000
      some one told me it is the exuast pipe at high speed air move it so it may rock under the car spicaily when you press the gasoline pedal
        الصوت ده بيظهر من الشكمان ؟
        [CENTER]:11_5_14[1]:[/CENTER]
          what i can do what i can tell to the omatra tawkeel to do so as not to pay much
          i never make anything outside tawkell sorry asl ana mwsws
          we lsa h3ml mawdo3 ala tlme3 al car becasue i am comletley different and aslo a chemist sorry but most users here in nile motores tell us wrong things or harmful or may be old technolgy
          like used silicone products or vasline on rubber all this is old and harmful on your rubber
          but you must use water based serfactant this is an example
          pleas help to fix
            all rubber brushing
            [if this item did not put will (i.e good fitting)......in there control arms .....this case well happend with you........
