رانجلير 2010
  • رانجلير 2010
    النهاردة كنت عند الطارق (سيتي سنتر الإسكندرية) وشوفت رانجلر الجديدة سعرها 240 ألف
    بس بصراحة فاجرة , ونقلة كبير عن الشكل القديم بالذات من حيث الوسع و طول الشاسية تقريبا بقيت قد الهامر H3
    وأدي صورة بتبين حجمها بالنسبة للجراند شيروكي
    ENGINE
    Engine Order Code
    EGT
    Engine Type
    Gas V6
    Displacement
    3.8L/231
    Fuel System
    SMPI
    SAE Net Horsepower @ RPM
    205 @ 5200
    SAE Net Torque @ RPM
    240 @ 4000
    TRANSMISSION
    Drivetrain
    2-Wheel Drive
    Trans Order Code
    DGV
    Trans Type
    4
    Trans De......ion Cont.
    Automatic
    First Gear Ratio (:1)
    2.84
    Second Gear Ratio (:1)
    1.57
    Third Gear Ratio (:1)
    1.00
    Fourth Gear Ratio (:1)
    0.69
    Reverse Ratio (:1)
    2.21
    Final Drive Axle Ratio (:1)
    3.73
    MILEAGE
    Fuel Economy Est-Combined (MPG)
    17 (2009)
    EPA Fuel Economy Est - City (MPG)
    15
    EPA Fuel Economy Est - Hwy (MPG)
    20
    ELECTRICAL
    Cold Cranking Amps @ 0° F (Primary)
    600
    Maximum Alternator Capacity (amps)
    140
    COOLING SYSTEM
    Total Cooling System Capacity (qts)
    13.4
    WEIGHT INFORMATION
    Base Curb Weight (lbs)
    4100
    TRAILERING
    Dead Weight Hitch - Max Trailer Wt. (lbs)
    3500
    Dead Weight Hitch - Max Tongue Wt. (lbs)
    350
    Wt Distributing Hitch - Max Trailer Wt. (lbs)
    3500
    Wt Distributing Hitch - Max Tongue Wt. (lbs)
    525
    SUSPENSION
    Suspension Type - Front
    Live Axle
    Suspension Type - Rear
    Live Axle
    Suspension Type - Front (Cont.)
    w/Coil Springs
    Suspension Type - Rear (Cont.)
    w/Coil Springs
    Shock Absorber Diameter - Front (mm)
    - TBD -
    Shock Absorber Diameter - Rear (mm)
    - TBD -
    Stabilizer Bar Diameter - Front (in)
    - TBD -
    Stabilizer Bar Diameter - Rear (in)
    - TBD -
    BRAKES
    Brake Type
    Power
    Brake ABS System
    4-wheel
    Disc - Front (Yes or )
    Yes
    Disc - Rear (Yes or )
    Yes
    Front Brake Rotor Diam x Thickness (in)
    11.9 x 1.1
    Rear Brake Rotor Diam x Thickness (in)
    12.4 x 0.5
    TIRES
    Front Tire Order Code
    TRM
    TUF
    Rear Tire Order Code
    TUF
    TRM
    Spare Tire Order Code
    TBB
    Front Tire Size
    P225/75R16
    Front Tire Size
    P255/75R17
    Rear Tire Size
    P255/75R17
    Rear Tire Size
    P225/75R16
    Spare Tire Size
    P225/75R16
    Spare Tire Size
    P255/75R17
    WHEELS
    Front Wheel Size (in)
    16 x 7.0
    17 x 7.5
    Rear Wheel Size (in)
    17 x 7.5
    16 x 7.0
    Spare Wheel Size (in)
    16 x 7.0
    17 x 7.5
    Front Wheel Material
    Steel
    Aluminum
    Rear Wheel Material
    Steel
    Rear Wheel Material
    Aluminum
    Spare Wheel Material
    Steel
    Aluminum
    STEERING
    Steering Type
    Power
    Steering Ratio (:1), Overall
    14.7
    Lock to Lock Turns (Steering)
    3.5
    Turning Diameter - Curb to Curb (ft)
    41.2
    Turning Diameter - Wall to Wall (ft)
    - TBD -
    FUEL TANK
    Fuel Tank Capacity, Approx (gal)
    22.5
    EXTERIOR DIMENSIONS
    Wheelbase (in)
    116.0
    Length, Overall (in)
    173.4
    Width, Max w/o mirrors (in)
    73.9
    Height, Overall (in)
    - TBD -
    70.8
    Track Width, Front (in)
    61.9
    Track Width, Rear (in)
    61.9
    Min Ground Clearance (in)
    10.0
    8.7
    Rear Door Opening Height (in)
    37.1
    Rear Door Opening Width (in)
    58.7
    Liftover Height (in)
    31.4
    CARGO AREA DIMENSIONS
    Cargo Area Length @ Floor to Seat 1 (in)
    - TBD -
    Cargo Area Length @ Floor to Seat 2 (in)
    - TBD -
    Cargo Area Width @ Beltline (in)
    - TBD -
    Cargo Box Width @ Wheelhousings (in)
    44.7
    Cargo Box (Area) Height (in)
    - TBD -
    Cargo Volume to Seat 1 (ft³)
    86.8
    Cargo Volume to Seat 2 (ft³)
    46.4
    INTERIOR DIMENSIONS
    Passenger Capacity
    5
    Passenger Volume (ft³)
    103.9
    Front Head Room (in)
    41.3
    Front Leg Room (in)
    41.0
    Front Shoulder Room (in)
    55.8
    Front Hip Room (in)
    55.6
    Second Head Room (in)
    40.4
    Second Leg Room (in)
    37.2
    Second Shoulder Room (in)
    56.8
    Second Hip Room (in)
    56.7
    صور الجراند شيروكي مش عاوز تبان على العموم أدي الصفحة اللي بتقارن بينهم
    Comparo: 2010 Jeep Wrangler VS 2002 Jeep Grand Cherokee | Drive Arabia : Dubai / Abu Dhabi [UAE, Saudi, Bahrain, Qatar, Kuwait, Oman & GCC]
      [youtube]http://www.youtube.com/watch?v=IX3At7O_OvI&feature=fvw[/youtube]
        مشكور
        واوعدنا يارب انا وانت وكل الاخوة
        [CENTER][SIGPIC][/SIGPIC][gdwl][gdwl][SIZE=4][COLOR=RoyalBlue][B][FONT=Arabic Transparent]( ربنا [FONT=Arabic Transparent]افتح بيننا[/FONT] وبين قومنا بالحق وانت خير الفاتحين )[/FONT][/B][/COLOR][/SIZE][/gdwl][/gdwl][/CENTER]
          العربيه دي ملهاش حل و دي انسب عربيه بالنسبه لشوارعنا الجميله وانا علي فكره جربتها عند عز العرب و ده انطباعي عنها
            المشاركة الأصلية كتبت بواسطة yasserit مشاهدة المشاركة
            طيب ما تحكلنا عن تجربتك ؟؟
            أخبار العفشة إيه صحيح أتحسنت عن الرانجلر القديمة (كانت بشعة) ؟؟؟
              بصوا يا جماعه بمنتهي الامانه العربيه دي اتغيرت كتير عن الاول انا اول لما شوفتها من بره حسيت فعلا اني قدام هامر و خصوصا اللون الاسود فيها و بعدين لما تركبها تحس انك مالك كل الطريق حواليك و مسيطر عليه و بالنسبه للعفشه انا دخلت بيها في طريق اوف رود هما اصلا بيجربوا العربيه فيه عشان يوضحوا للناس امكانيات العربيه و هيا بسم الله ما شاء الله ناعمه في المطبات و المدقات مش زي الاول كانت ناشفه قوي و التحكم بالعربيه و الثبات حلو جدا في حدود تجربتي البسيطه بيها لكن انا دوست بيها جامد زي ما قالولي خد راحتك و ما خيبتش ظني فيها خالص
                انا معايا جيب رانجلر من 15 سنه و عمري ما فكرت اغيرها حتى بعد ما اتجوزت و بقى عندي عيله .. بفكر اغير لرانجلر برضو بس الشكل الجديد ال 4 باب
                  العربية دى من سنتين شفتها كانت فى السخنه من ساعتها هيا حلم بالنسبالى عمليه لاقصى الحدود ربنا يستر و تطلع خاليه من عيوب صعبه .
                  [SIZE=4][COLOR=Blue]اللهم أرنا الحق حقا و أرزقنا اتباعه و ارنا الباطل باطلا و أرزقنا أجتنابه و لا تجعله ملتبسا علينا فنضل [/COLOR][/SIZE]
                    الرانجلر الجديده يا جماعه مختلفه كليا و تماما عن الرانجلر القديمه.. الموديل الجديد(التي جي) مختلف في نظام العفشه و الفرامل الاي بي اس و الايرباج و الكراسي و كل حاجه .. انا ان شاء الله هغير عربيتي القديمه و اجيب الجديده .. بس موضوع العيله هو اللي مخليني متردد شويه
                      المشاركة الأصلية كتبت بواسطة sava مشاهدة المشاركة
                      وأنت حتلاقي أكبر من كده إيه للعيلة ؟؟؟ أنا شايف إنها عائلية جدا
                        يا باشا هاتها وانتا مطمن انا ركبتها و سوقتها كذا مره في عز العرب اصلهم هناك كلهم اصحابي العربيه زي الفل و عفشتها احسن من الشيروكي خالص و كمان انا ركبت النهارده قدام و رجعت الكرسي و ظهر الكرسي علب الآخر معلش بقي دي سواقتي اللي متعود عليها في كل العربيات اللي سوقتها و جيت اقعد ورا لقيتها لسه براح و قعدت مرتاح مع العلم اني مش قصير ١٨٤ سم فا متخافش من الناحيه دي و علي العموم انا حجزتها النهارده خلاص
                          ياترى هل تقفيلها المصري كويس وانا شايف احلى لون الاحمر بس شكلها مش حلو اوي وياريت حد يقوللى استهلاك البنزين كام
                            المشكله كلها في الضريبه هتبقي سفح
                            تويوتا السياره الاعتماديه رقم 1 و الاكثر مبيعا في العالم
                            [SIZE=4][COLOR=#2336b0]محمد مجدي الفنتي[/COLOR][/SIZE]
                              المشاركة الأصلية كتبت بواسطة memoz مشاهدة المشاركة
                              لو هيمشوها بنظام ال2% ... يبقا الضريبة هتكون في حدود 4800 جنيه.... أرحم من الشيروكي الجديدة اللي ضريبتها 6380 جنيه....
                              اعذروني عشان مش بقدر افتح المنتدى كتير
                              ده الايميل و هيجيلي مباشرة على التليفون لأي استفسار
                              [email]mina.nilemotors@gmail.com[/email]
                              و السكايب
                              mina.nilemotors
