Opel again sends a clear signal in the SUV segment with the Opel Antara, which combines dynamic, elegant design with robust four-wheel drive as standard. The technologically sophisticated compact five-seat crossover boasts the handling of a passenger car, generous interior space despite compact exterior dimensions, high levels of functionality, a raised seat position and innovative transport features such as the "Flex-Fix" carrier system, which pulls out from the rear bumper. The interior echoes the style and elegance of a top-of-the-line sedan, and with its electronically networked chassis, precise speed-dependant power steering and active four-wheel drive, the Opel Antara is at home in the city or off-road.
The Opel Antara is available with two gasoline and two diesel engines. The entry-level gasoline engine is the 2.4-liter, 103 kW/140 hp four-cylinder gasoline unit. Its double overhead camshafts and balance shaft with two rotating counterweights ensure rapid response and refinement. The most refined engine is the 3.2-liter gasoline V6 with 167 kW/227 hp, which produces 297 Nm of torque. The two-liter 93 kW/127 hp CDTI ECOTEC diesel engine is an alternative to the Antara's popular 2.0 CDTI ECOTEC unit with 110 kW/150 hp. The two-liter common-rail turbo-diesel unit produces 320 Nm of torque at 2000 rpm and has become the top-selling Opel Antara engine. All engines are transversally mounted and coupled to a five-speed manual transmission. The one exception is the V6 engine, which comes with a newly developed five-speed automatic transmission (optional for 150 hp turbo-diesel unit) for top driving comfort.
