[sor2]http://www7.0zz0.com/2010/06/24/13/862151037.jpg[/sor2]
ktm صانع الدراجات النمساوي الشهير و المعروف بدراجاته لل off road المنافسة في الراليات المختلفة قرر الدخول في مجال دراجات السرعة بالرائعة ال rc8 ذات المحرك ذو سعة 1198 cc و بتصميم إيروديناميكي جرئ ليكون قادرا على منافسة عمالقة الدراجات السريعة الهوندا و الكاوازاكي و السوزوكي و الدوكاتي .
إليكم مواصفات الرائعة
ENGINE
Engine: 2-Cylinder, 4-Stroke, V 75°
Displacement: 1148 cc
Bore x Stroke: 101 x 62.4 mm
Performance: 100 kW / 9600 rpm
Max. torque: 103 Nm / 7300 rpm
Compression ratio: 11.8 : 1
Starter: E-starter
Transmission: 6 gears, dog clutch engagement
Fuel: 95 ROZ
Mixture conditioning: Electronic fuel injection
Control: DOHC
Valve: Spur-gear driven tooth-type chain
Lubrication: Pressure circulation lubrication
Engine oil: Motorex Power Synt 4T, SAE 10W-50
Primary drive: 67 : 35
Cooling: Liquid cooling
Clutch: Wet multi-disc clutch, hydraulically operated
Ignition: Denso battery ignition
Spark plug: NGK DCPR 8 E
Chassis
Frame: Chromium molybdenum tubular space frame, powder-coated
Subframe: Aluminium
Handlebar: Aluminium clip-ons
Suspension front: WP-USD 48 Multi Adjuster PA
Suspension rear: WP - Multi Adjuster
Suspension travel front/rear: 120 / 125 mm
Brake front: Double disc Ø 305 mm
Brake rear: Disc Ø 210 mm
Rim front/rear: 3.5 x 17 " / 5.5 x 17"
Tire front/rear: 120/70 - 17" / 190/50 - 17"
Transmission ratio: 17:38
Battery: 12V / 12 Ah
Steering head angle: 67.3°
Wheelcaster: 89 mm
Wheelbase: 1399 mm
Ground clearance: (unloaded) 150 mm
Seat height: (unloaded) 835 mm
Tank capacity: approx. 17 l
Dry weight: approx. 175 kg
Starter: E-starter
Fuel: 95 ROZ
Control: DOHC
Chassis
Subframe: Aluminium
Wheelcaster: 89 mm
Wheelbase: 1399 mm
و إليكم بعض الصور و الفيديو
[sor2]http://www10.0zz0.com/2010/06/22/16/770118359.jpg[/sor2]
[sor2]http://www7.0zz0.com/2010/06/22/15/435710769.jpg[/sor2]
[sor2]http://www10.0zz0.com/2010/06/22/23/721410666.jpg[/sor2]
[sor2]http://www7.0zz0.com/2010/06/22/15/262414900.jpg[/sor2]
[sor2]http://www10.0zz0.com/2010/06/22/23/391325945.jpg[/sor2]
[sor2]http://www12.0zz0.com/2010/06/23/00/256308686.jpg[/sor2]
[sor2]http://www9.0zz0.com/2010/06/24/12/595967178.jpg[/sor2]
[sor2]http://www10.0zz0.com/2010/06/23/00/408968506.jpg[/sor2]
[sor2]http://www10.0zz0.com/2010/06/23/00/851285318.jpg[/sor2]
[sor2]http://www9.0zz0.com/2010/06/24/12/945745899.jpg[/sor2]
[sor2]http://www9.0zz0.com/2010/06/24/12/447805631.jpg[/sor2]
[sor2]http://www9.0zz0.com/2010/06/24/12/134118732.jpg[/sor2]
[sor2]http://www9.0zz0.com/2010/06/24/13/185588265.jpg[/sor2]
[sor2]http://www9.0zz0.com/2010/06/24/13/938795570.jpg[/sor2]
[sor2]http://www9.0zz0.com/2010/06/24/13/538043052.jpg[/sor2]
[sor2]http://www9.0zz0.com/2010/06/24/13/895134984.jpg[/sor2]
[sor2]http://www9.0zz0.com/2010/06/24/13/599707971.jpg[/sor2]
[sor2]http://www9.0zz0.com/2010/06/24/13/332570712.jpg[/sor2]
[sor2]http://www7.0zz0.com/2010/06/24/13/826564053.jpg[/sor2]
هههههههه
ده أول سوبر بايك أمريكي![Oc Sun1[1]](https://www.nilemotors.net/Nile/core/images/smilies/Oc_sun1[1].gif)
