honda 400 rr all model
  • honda 400 rr all model
    History, Specifications And Technical Information
    History
    First manufactured in 1988 the Honda CBR400RR, or 'BabyBlade', is the smaller sibling of the Fireblade or CBR900RR series even though it preceded the 900cc Fireblade by several years. It was manufactured for the Japanese home market and from its release stormed straight to the top of the sales charts. The CBR400RR engine was a development from that of the CBR400 Aero, but had gear driven cams, an aluminium frame, a 17 inch front wheel and brand new styling complete with a twin headlamp fairing. It was referred to as either the ‘Tri-Arm’, a reference to its triangulated swingarm, or the NC23, its factory code. This domination of the Tri-Arm was continued in 1990 by the next generation of CBR400RR, the ‘L’ model, also known as the ‘Gull-arm’, or its factory designation the ‘NC29’. In spite of the superficial similarities between the Tri-Arm and the Gull-Arm, the Gull-Arm was in fact a completely new machine whose parts had much in common with the VFR400, including 17 inch wheels, front and rear. The name ‘Gull-Arm’ came from the bikes new swing arm design, derived from the, then, current race design a year after the swing arm was seen on the race track.
    When the 900cc FireBlade hit the worlds markets and revolutionised the sports bike market in 1992 the Gull-Arm got the same paintwork and the FireBlade sticker on the fairing. Even though the 400 was the earlier design, it was christened the Baby Blade and went on to become probably the best selling ‘grey import’ in the UK.
    Model Classifications, Dimensions And Weights
    Model, Code and Production Year - CBR400RR-J (1988)
    Frame Numbers - NC23-1020001 to 1036454
    Engine Numbers - NC23E-1020001 to 1036510
    Carburettor Number - VG04A
    Wheelbase - 1370mm
    Overall length - 2020mm
    Overall width - 690mm
    Overall height - 1110mm
    Ground clearance - 120mm
    Weight (dry) - 179kg
    Model, Code and Production Year - CBR400RR-K (1989)
    Frame Numbers - NC23-1090001 to 1098116
    Engine Numbers - NC23E-1090001 to 1098123
    Carburettor Number - VG04B
    Wheelbase - 1380mm
    Overall length - 2202mm
    Overall width - 675mm
    Weight (dry) - 182kg
    Model, Code and Production Year - CBR400RR-L (1990 and 1991)
    Frame Numbers - NC29-1000001 to 1010598
    Engine Numbers - NC23E-1300001 to 1310636
    Carburettor Number - VP01A
    Wheelbase - 1365mm
    Overall length - 1990mm
    Overall width - 670mm
    Overall height - 1080mm
    Ground clearance - 125mm
    Weight (dry) - 180kg
    Model, Code and Production Year - CBR400RR-N (1992 and 1993)
    Frame numbers - NC29-1050001 on
    Engine Numbers - NC23E-1420001 on
    Wheelbase - 1365mm
    Model, Code and Production Year - CBR400RR-R (1994 - on)
    Frame Numbers - NC29-1100001 on
    Engine Numbers - NC23E-1500001 on
    Carburettor Number - VP01B
    Wheelbase - 1365mm
    Ground clearance 125mm
    Specifications CBR400RR-N
    Type Four-stroke, dohc, in-line four cylinder
    Capacity 399cc
    Bore & Stroke 55.0mm x 42mm
    Compression Ratio 11.3:1
    Valve Train Gear Driven DOHC; 4 valves per cylinder
    Cooling System - Liquid cooled, radiator with cooling fan
    Clutch - Wet multi plate
    Clutch operation - Cable operated
    Transmission - 6-speed
    Primary reduction - 2.117 : 1 (72/34)
    Final reduction (sprockets) 2.600 : 1 (39/15)
    Transmission - 6 speed constant mesh
    Final drive chain - 102 links, split
    Frame Twin spar, box-section aluminium
    Front Suspension - Oil-damped telescopic forks
    Rear Suspension - Single shock absorber with 3-way linkage
    Front brakes - Double floating disc; 2-piston Nissin sliding callipers
    Rear brake - Single solid disc; single-piston Nissin sliding calliper
    Fuel tank capacity - 15.0 liters (4.0 U.S. gal., 3.5 Imp gal.)
    Ignition system - Digitalized full transistor ignition
    Starting system - Electric
    Battery Type - YTX7L-BS
    Charging system - Triple phase output alternator
    Regulator/rectifier type - SCR Shorted/triple phase full wave rectification
    Recommended engine oil -SAE 10W-40
    Engine oil capacity at oil filter change - 3.4 litres
    Idle speed - 1,300 +/- 100 rpm
    Cold tire pressure (driver only, front) - 33 psi (2.25 bar)
    Cold tire pressure (driver only, rear) - 33 psi (2.25 bar)
    Cold tire pressure (driver & pass., front) - 33 psi (2.25 bar)
    Cold tire pressure (driver & pass., rear) - 36 psi (2.50 bar)
    Spark plug (standard) - NGK CR8EH-9 or equivalent
    Spark plug (racing) - NGK CR9EH-9 or equivalent
    Spark plug gap - 0.8-0.9mm
    [CENTER][I][U][SIZE=3][COLOR=black][SIGPIC][/SIGPIC][/COLOR][/SIZE][/U][/I][/CENTER]
    [CENTER][I][U][COLOR=black][SIZE=7][COLOR=magenta]i love my[/COLOR] [COLOR=magenta]car[/COLOR][/SIZE][/COLOR][/U][/I][/CENTER]
    الحمد لله انا معايا 250 وعادة كمان .........اقل فئة بس قشطة بردوا تماااااامو
    [shr71=http://im67.gulfup.com/kmfq5O.jpg]cbr 600rr 2013 this is my bick[/shr71]
    لا تعتمد كثيرا على أحد فى هذه الدنيا فحتى ظلك يتخلى عنك فى الظلام
      شكرا ع المجهود
        مجهود رائع حيفيد ناس كتير بس يا رب يفهموا
        [CENTER][FONT=Comic Sans MS][B][FONT=Courier New][SIZE=5][COLOR=Blue]MTG[/COLOR][/SIZE][/FONT][SIZE=4][COLOR=Silver]
        [COLOR=Black]Rush[/COLOR][/COLOR][/SIZE][/B][/FONT][B][FONT=Comic Sans MS][SIZE=4][COLOR=DarkOrange]»«[/COLOR][COLOR=Black]Liker[/COLOR][/SIZE][/FONT][/B][COLOR=#000000]
        [/COLOR] [COLOR=Gray][B]يا صابت :S_thum1[1]:يا خابت:stink[1]: و سيبها بظروفها:vctry: ده ربك الي بيعدلها [/B]
        [/COLOR]
        [mtohg=#003df5]http://www.nilemotors.net/Nile/signaturepics/sigpic64762_5.gif[/mtohg]
          الله ينور
          مشكووور
          [SIGPIC]http://www.nilemotors.net/Nile/signaturepics/sigpic21802_5.gif[/SIGPIC]
