2011_new honda cbr 250r
  • 2011_new honda cbr 250r
    2011__ HONDA CBR 250R
    CBR250R ABS
    Specifications
    ENGINE
    ENGINE
    Engine Type
    249.4cc liquid-cooled single-cylinder four-stroke
    Bore And Stroke
    76mm x 55mm
    Induction
    PGM-Fi, 38mm throttle body
    Ignition
    Computer-controlled digital transistorized with electronic advance
    Compression Ratio
    10.7:1
    Valve Train
    DOHC; four valves per cylinder
    DRIVE TRAIN
    DRIVE TRAIN
    Transmission
    Six-speed
    CHASSIS / SUSPENSION / BRAKES
    Front Suspension
    37mm fork
    Rear Suspension
    Pro-Link single shock with five positions of spring preload adjustability
    Front Brake
    Single 296mm disc/Combined ABS
    Rear Brake
    Single 220mm disc/Combined ABS
    Front Tire
    110/70-17 radial
    Rear Tire
    140/70-17 radial
    DIMENSIONS
    DIMENSIONS
    Rake
    (Caster Angle): 25.0 degrees
    Trail
    95mm (3.74 inches)
    Wheelbase
    53.9 inches
    Seat Height
    30.5 inches
    Curb Weight
    368 pounds. includes all standard equipment, required fluids and full tank of fuel-ready to ride.
    Fuel Capacity
    3.4 gallons
    OTHER
    OTHER
    Model Id
    CBR250R ABS
    Emissions
    Meets current EPA standards. Models sold in California meet current CARB standards and may differ slightly due to emissions equipment.
    Available Colors
    ....llic Black, Red/Silver
    Note
    Specifications subject to change without notice.
    [CENTER][U][B][FONT=Arial Black]bikes don't kill people
    people kill people[/FONT][/B][/U]
    هوندا بتهرج هترجعنا تانى لى 250 والواحد سلندر انا من راىى اسواء ما صنعة هوندا ....
      بايك سيء بكل المقاييس
        اللي بيروح مابيرجعش تاني
          سعره كام ؟
          [SIZE=3]SHERIFE EL ETR[/SIZE]
            Honda cbr 250r 2011
            سعر المكنة 4000$ بس السؤال 250cc يركبلها ABS ليه ؟
            Stop with Confidence
            The option of Honda’s Anti-lock Brake System (ABS) is a perfect matchup with a bike like the new CBR250R. ABS helps you cope with unanticipated challenges and stop with added confidence.
              لا داهية تكون تبريد هواء كمان
              [shr71=http://im67.gulfup.com/kmfq5O.jpg]cbr 600rr 2013 this is my bick[/shr71]
              لا تعتمد كثيرا على أحد فى هذه الدنيا فحتى ظلك يتخلى عنك فى الظلام
                لايا خالد باشا المكنة تبريد سائل ...بس انت ايه رائيك...
                  يا bobo جامد الموضوع جامد
                    انا من رأى انهم كويس انهم عملوا 250تانى لان معظم الى بيبدا بيبقى عايز حاجه بسيطه يتعلم عليها
                    وده حيبقى ليه شريحه معينه من الناس طبعا يعنى معظم الى حيتعلم او حتى الى جايبه بس مش علشام جرى
                    [SIZE=5]اللهم لا اله الا انت سبحانك انى كنت من الظالمين[/SIZE]
                      انا كنت عامل الموضوع ده قبل كده بس اتمسح لما سيرفر المنتدى ضرب وكنت هانزله تانى بس انت سبقتنى ......
                      https://t.me/pump_upp
                        اسف ياباشا والله ،،، وبعدين انا الموضوع بتاعى يزيد لما تكون حضرتك عملتو قبل كد و ان شاء الله اشوفلك موضوع اجمد من كده
                        بس انت مقولتليش ايه رائيك فى المكنة...
                          ولا يهمك ياغالى واحد .
                            اناسمعت 4000 يورو مش دولار بس مش اكيد
